Replacement bearings. - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 11-09-2010, 04:38 PM Thread Starter
angst's Avatar
Any suggestions for non-oem bearings?
Cheers!
angst is offline
post #2 of 14 (permalink) Old 11-09-2010, 05:13 PM
If you are referring to wheel bearings any bearing shop can find replacements (probably most auto parts places as well).
jcctx is offline
post #3 of 14 (permalink) Old 11-09-2010, 05:17 PM
All Balls
T Cothron is offline
post #4 of 14 (permalink) Old 11-09-2010, 05:51 PM Thread Starter
angst's Avatar
He he he
Originally Posted by T Cothron View Post
All Balls
No brains?
Cheers!
angst is offline
post #5 of 14 (permalink) Old 11-09-2010, 06:04 PM
Boca Bearing has all kinds and prices.
Todd
tapntx is offline
post #6 of 14 (permalink) Old 11-09-2010, 06:59 PM Thread Starter
angst's Avatar
Finally
Todd
Thank you for a reasonable answer.
Cheers!
angst is offline
post #7 of 14 (permalink) Old 11-09-2010, 09:13 PM
Front hub bearings: 2 x 6004 (C3) with rubber seal on both sides.
Rear hub bearings: 2 x 6204 (C3) with rubber seal on both sides, 1 x 6205 (C3) with rubber seal on both sides.
Search bearing # : http://www.vxb.com/Merchant2/merchant.mvc?
post #8 of 14 (permalink) Old 11-09-2010, 11:34 PM
Invader for the info.
Checkout here if Timken, SKF or NSK had those specs.
Angst for posting.
post #9 of 14 (permalink) Old 11-09-2010, 11:48 PM
Front wheel bearings: 6004 (C3) x 2
Rear wheel bearings: 6204 (C3) x 2, 6205 (C3) x 1
Putting aside the Kawa Service Manual Recommendation, what will be the KM/Miles to replace front and back bearings.
Your call sir on bearing replacement to be safe before bearing failure.
post #10 of 14 (permalink) Old 11-10-2010, 12:11 AM
Bicyclebob's Avatar
Regardless of the manufacturer a cheap bearing is just that....cheap. The higher quality (more expensive) versions have harder and more highly polished bearing surfaces and are worth the extra cost. In bicycles I use ceramic bearings as they are the smoothest that I have found.
That's my two cents worth.
Bicyclebob is offline
post #11 of 14 (permalink) Old 11-10-2010, 12:21 AM
It varies... Replace them whenever neccessary.
Since the hub bearings are made to extremely close tolerances, the clearance can not normally be measured. Do not remove any bearings for inspection. If any bearings are removed, they will need to be replaced with new ones.
•Turn each bearing in the hub back and forth while checking for plays, roughness or binding. If bearing play, roughness or binding is found, replace the bearing.
•Examine the bearing seal for tears or leakage. If the seal is torn or is leaking, replace the bearing.
post #12 of 14 (permalink) Old 11-10-2010, 12:29 AM
Thanks Invader.
Will keep in mind the next time I get the wheels off.
post #13 of 14 (permalink) Old 11-11-2010, 03:55 AM
+++ for ceramic bearings
ninogui is offline
post #14 of 14 (permalink) Old 11-12-2010, 03:46 AM
Cost about USD 21 for all 5 SKF bearings.
Thanks, Invader.
