2015 V650 LT handguards rubbing - Kawasaki Versys Forum
Like Tree5Likes
  • 2 Post By TRZ Charlie
  • 1 Post By Green Streak
  • 1 Post By Fly-Sig
  • 1 Post By fasteddiecopeman
post #1 of 19 (permalink) Old 07-21-2016, 08:36 PM Thread Starter
Other people with the 15+ V650 LT, do you handguards rub against the dash plastic when you turn the handlebars all the way in one direction? Mine creak against the plastic, and I'm wondering if they were installed improperly.
zzzoren is offline
post #2 of 19 (permalink) Old 07-21-2016, 09:17 PM
TRZ Charlie's Avatar
No, mine are OEM I have the hand guard bottoms even with the bottom of my levers and they don't even come close to the dash. Are yours OEM or aftermarket. Do they hit on just one side or both? If they hit on one side your bars are not centered.
turn8a and unstable_rider like this.
Cheers,
Charlie
TRZ Charlie is offline
post #3 of 19 (permalink) Old 07-21-2016, 09:32 PM
james75's Avatar
Mine hit the dash a little bit on both sides. OEM guards on 2016 LT.
james75 is offline
post #4 of 19 (permalink) Old 07-22-2016, 12:18 AM Thread Starter
Yep, they are OEM. They hit on both sides, not a hard hit, just a creak when I have the wheel turned all the way to one side and am pushing the bike.
zzzoren is offline
post #5 of 19 (permalink) Old 07-22-2016, 07:00 AM
My 2015 guards do not even come close to the dash. I think that whoever assembled the bike did not adjust the handlebar (or hand guard) position correctly.
turn8a likes this.
Green Streak is offline
post #6 of 19 (permalink) Old 07-22-2016, 08:30 AM
I also had to adjust my guards after riding it away from the dealer.
woodyburns is offline
post #7 of 19 (permalink) Old 07-22-2016, 03:38 PM Thread Starter
Can you take a photo of the positioning of the hand guards for me? I should probably adjust them.
zzzoren is offline
post #8 of 19 (permalink) Old 07-22-2016, 06:16 PM
Fly-Sig's Avatar
The position of the handlebars rotated up or down can make a difference. When I rotate mine upwards for standing on the pegs the handguards do contact the windshield. You can also adjust the handguards relative to the handlebars. Just push them up a little bit and see if they stop rubbing.
zzzoren likes this.
Fly-Sig is offline
post #9 of 19 (permalink) Old 07-22-2016, 06:31 PM
I agree that it's just the 'set-up' - I spent probably TWO hours getting mine right....
post #10 of 19 (permalink) Old 07-22-2016, 10:32 PM
MLJ
MLJ's Avatar
I think that adjustment must be the answer here, my 2015 650 LT's stock handguards don't touch anything, including my Givi shield. Some people find them bumping aftermarket shields too.
MLJ - 2015 Versys 650 LT
There are more important things than things.
MLJ is offline
post #11 of 19 (permalink) Old 07-23-2016, 09:09 PM Thread Starter
So I adjusted the hand guards, and lo and behold, they no longer rub! My only concern now is that the clutch cable is running over top of the handguard bracket and looks like there's some upward pressure on it. Is the clutch cable running ABOVE or BELOW the handguard bracket on your bike? I've attached a photo of how mine is run.
zzzoren is offline
post #12 of 19 (permalink) Old 07-24-2016, 12:47 AM Thread Starter
Rotated the guards down a bit, the cable is clear and the guards still don't hit the dash.
zzzoren is offline
post #13 of 19 (permalink) Old 07-24-2016, 06:46 AM
james75's Avatar
Can you post a picture from the side, so I can see where exactly you moved them? In the pic you posted, mine look to be in about the exact same spot and still hit the dash up by where you would install the power outlet and gear indicator. I haven't tried moving mine yet, but I'm having trouble seeing how adjusting them will keep them from hitting and still be effective.
james75 is offline
post #14 of 19 (permalink) Old 07-24-2016, 08:36 AM
On a side note: did Kawasaki figure out a better spot for the power outlet for 2016? With the 2015, you obviously cannot have something plugged in there with the LT handgaurds in place. I put my power outlet inside the left fairing, so it's no big deal to me, just wondering if they solved that.
Todd
White 2015 650 LT
Apple Valley, Minnesota
Squishman is offline
post #15 of 19 (permalink) Old 07-24-2016, 12:02 PM
james75's Avatar
No, the 2016 is exactly the same as the '15. I'm going to do what I saw someone else do on these forums. Install a USB power plug, then buy a short USB extension cable with a 90 degree connector on the end that plugs in. The handguards will clear it then.
james75 is offline
post #16 of 19 (permalink) Old 07-24-2016, 03:03 PM
Your pic looks like the way MY '15 is....
zzzoren likes this.
post #17 of 19 (permalink) Old 07-24-2016, 03:07 PM Thread Starter
Here ya go, James75. Hope this helps. As you can see, it just barely clears the dash.
Edit: Of course I missed the "from the side" part of your post... will grab another shot.
zzzoren is offline
post #18 of 19 (permalink) Old 07-24-2016, 03:12 PM Thread Starter
Side view.
zzzoren is offline
post #19 of 19 (permalink) Old 07-25-2016, 07:31 AM
james75's Avatar
Awesome, thank you.
james75 is offline
