2015 650 Centerstand Question - Kawasaki Versys Forum
Like Tree1Likes
  • 1 Post By fasteddiecopeman
post #1 of 11 (permalink) Old 07-06-2016, 01:33 PM Thread Starter
I cleaned and lubed my chain for the first time, and it was a pain not having the tire lifted. I'm thinking about getting a centerstand so I can do it while touring.
I know that the kickstand interferes with the centerstand sometimes, but does anyone know if the SW-Motech centerstand is compatible with the MotoWerk Flatfoot? I'd imagine it'll make the interference worse, but I'm not sure.
rjs111 is offline
post #2 of 11 (permalink) Old 07-06-2016, 02:53 PM
Cheftyler's Avatar
Make yourself a crutch stand like FastEddie did and you're set.
Cheftyler is offline
post #3 of 11 (permalink) Old 07-06-2016, 04:02 PM
Here's what Tyler's referring to:
jdscrotch likes this.
post #4 of 11 (permalink) Old 07-06-2016, 05:56 PM
I have the SW-Motech centerstand and the Motowerk flatfoot installed. They do not interfere.
The minor problem is that you must put the centerstand up before raising the sidestand; otherwise, the centerstand does not go all the way up and could drag the ground when cornering.
trialsbug is offline
post #5 of 11 (permalink) Old 07-07-2016, 01:30 AM
Did you have an opportunity to test whether the centerstand lowers ground clearance? Does it scrape before the pegs when leaning? Do you have to be more careful when navigating tall curbs?
2015 Versys 650
_Big_Mac_ is offline
post #6 of 11 (permalink) Old 07-07-2016, 01:07 PM Thread Starter
Cheftyler & fasteddie,
Thanks for your responses. I thought about doing something like the packjack, but I just like the idea of having a permanent centerstand better. Although I do like the price and the fact that I wouldn't have to install it.
Perfect. Exactly what I was looking for. Thanks!
rjs111 is offline
post #7 of 11 (permalink) Old 07-07-2016, 01:14 PM
The price of the Kawasaki stand is ridiculous. I purchased a center stand for my Honda NC700x, it was around $200 I believe. And it even worked perfectly with the side stand!
A major failure on Kawasaki's engineering, I believe.
I will use a rear stand at home, and plan to purchase something like a packjack for traveling.
zirconx is offline
post #8 of 11 (permalink) Old 07-08-2016, 11:10 AM
I tried to get a couple pics at the same angle as the bike to show the center stand and how it affects ground clearance.
If the stand hits a curb then the beefy bracket that ties both sides together probably just saved your muffler.
post #9 of 11 (permalink) Old 07-08-2016, 12:32 PM
TRZ Charlie's Avatar
Trialsbug,
Is your bike stock or lowered?
Cheers,
Charlie
TRZ Charlie is offline
post #10 of 11 (permalink) Old 07-08-2016, 12:47 PM
Originally Posted by TRZ Charlie View Post
Trialsbug,
Bike is stock
post #11 of 11 (permalink) Old 07-08-2016, 12:59 PM
Thanks, mine is lowered so I suspect if I did get one I'd have to cut off the legs to match the Moto Werks lowering block.
Cheers,
Charlie
