Best grips for vibrations - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By rayj
  • 2 Post By Smiley
  • 1 Post By ronheater70
post #1 of 15 (permalink) Old 06-30-2016, 07:22 AM Thread Starter
Started using ESI extra chunky grips after reading about them on a street triple forum. They helped a ton with my street triple in making the vibes bearable.
Well purchased them for my 15 versys 650 and put them on yesterday. These on the 15 versys make vibes virtually non existent. Huge improvement.
CreatureCore is offline
post #2 of 15 (permalink) Old 06-30-2016, 11:20 AM
Excuse my ignorance, but how do these install/mount, attach and secure in place. Thanks, they are of interest to me.
cjcintucson is offline
post #3 of 15 (permalink) Old 06-30-2016, 11:58 AM
ronheater70's Avatar
Assuming they are like my grip puppies, I simply dunked them in mild warm soapy water and forcefully slid on over top my stock grips.
Once dry, they are tight with zero movement. BTW I noticed and improvement with the grip puppies as well.
ronheater70 is offline
post #4 of 15 (permalink) Old 06-30-2016, 12:05 PM
kohburn's Avatar
I might do something like this when I switch rom heated grips to heated gloves.
kohburn is offline
post #5 of 15 (permalink) Old 06-30-2016, 01:01 PM
Sounds good. I thought maybe you had to remove the stock grips. I have baseball bat anti vibration tape on mine with OK results. I will probably try these in place of the tape. Thanks.
post #6 of 15 (permalink) Old 06-30-2016, 05:40 PM Thread Starter
You need to remove stock grips. There is a chance you can get them on over but will be tough.
post #7 of 15 (permalink) Old 06-30-2016, 05:53 PM
MrSchaeferPants's Avatar
Good deal man! I was hoping soon kuryakyn will make their ISO grips with throttle boss. Loved those on my last bike.
2015 Versys 650 ABS
MrSchaeferPants is offline
post #8 of 15 (permalink) Old 07-01-2016, 11:42 AM
I started using the Grip Buddies last year over the stock grips. These were originally known as Beemer Buddies, but fit over our grips fine. They cost about the same as the Grip Puppies, but are reusable. They attach with a small strip of industrial strength tape, and Velcro. I took them off when I put on the Oxford Heaterz grips this winter, and reinstalled them over the new grips. Word of caution when taking off your original grips, watch out for cutting the throttle sleeve that is under the right hand grip. And yes, you can still get good heat from the Heaterz through the Grip Buddies.
Smiley likes this.
rayj
2009 Versys (Mine's Green)
rayj is offline
post #9 of 15 (permalink) Old 07-01-2016, 11:48 AM Thread Starter
I found the stock grips slide right off with rubbing alcohol, no reason to cut them unless you're sure you won't use them again.
post #10 of 15 (permalink) Old 07-01-2016, 11:52 AM
Well, it looks like the ESI grips are made for bicycles, which would explain why you have to remove your stock grips to mount them. The Grip Puppies are made for going over your stock grips. I think I will remove my baseball bat tape and try the Grip Puppies. Thanks again to both of you for the information.
post #11 of 15 (permalink) Old 07-01-2016, 03:19 PM Thread Starter
They are made for bicycles, but work so much better then grip puppies. Grip puppies are made of some foam like material, these are made from silicone. Its a huge difference IMO.
post #12 of 15 (permalink) Old 07-01-2016, 03:26 PM
Yeah, never mind the band-aids and gimmicks, and the ridiculous and dangerous thick foam grips... Stock hand grips, tapered aluminum handlebars on aluminum adapters. Problem solved.
invader is online now
post #13 of 15 (permalink) Old 07-02-2016, 08:22 AM
Many vibration fixes. Silicone caulk in the bars helps a good deal! Proper setup so there's no grip force seemed the most effective for me. Thanks for the bat tape concept!
Dr. Toaster: Guzzi 1400 California, VStrom 1000
Mrs. Toaster: 2009 Versys 650
Located 50 miles W of Deals Gap aka Dragon
toaster404 is offline
post #14 of 15 (permalink) Old 07-05-2016, 10:40 AM
Smiley's Avatar
Yeah, never mind the band-aids and gimmicks, and the ridiculous and dangerous thick foam grips... Stock hand grips tapered aluminum handlebars on aluminum adapters. Problem solved.
Those stock grips are not compatible with all hand sizes. They caused my huge hands to cramp constantly. Grip Buddies increased the diameter to suit my hands and, no, they are in no way dangerous.
Ridiculous? How can a practical solution be ridiculous? I find top boxes to be very unpleasing aesthetically but 'ridiculous' is an opinion I would not apply.
binderline and ronheater70 like this.
Smiley is offline
post #15 of 15 (permalink) Old 07-05-2016, 10:56 AM
This was my thoughts as well. the small diameter and grips would cramp my hands after a bit. The new grips helped a lot, and dampened the vibrations.. so a win, win for me anyway.
Smiley likes this.
