Lowering a Versys - Kawasaki Versys Forum
post #1 of 14 (permalink) Old 01-28-2008, 11:13 AM Thread Starter
jnor's Avatar
Lowering a Versys
I am interested in buying a Versys. My only problem is that my wife will probably ride it a bunch, as well as me. I have a 05FZ1, she has a Triumph Speedmaster which she is getting rid of.
I love the Versys, but it's just plain too tall for either of us, (I could probably live with it). Leaving it stock seat height 33" is NOT an option.
Has anyone lowered their's, if so how? I have seen a rear shock mount advertised, and also saw where someone cut a coil off of the rear shock spring. The front isn't a problem, just slide the fork tubes up.
'15 DL1000
jnor is offline
post #2 of 14 (permalink) Old 01-28-2008, 11:57 AM
This is just speculation from the research I've done on the topic but here goes:
1. Kawasaki has a 50mm-lower gel seat as an OEM accessory... Might wanna check that out...
2. You could use the Er6n's rear shock and lower the front triple clamp to bring the bike lower.. Total height reduction in this case would be about 5-10cm
Hope this helps...
newvs is offline
post #3 of 14 (permalink) Old 02-01-2008, 06:50 AM
I've read that people are happy with the lower gel seat, except for the price they ask. Expensive.
At 5' 7" I wondered if I could live with the high seat too, but I found I got used to it and lowered the spring setting to the lowest.
Most the time I just put my left foot down but sometimes both as I am on the balls of my boots. Again, I don't even think of it anymore and I like sitting high to get an advantage of seeing a lot more when in traffic.
The nice thing is that the bike is so light and you're not fighting a top heavy bike.
You may find it not as bad as you thought, but if you do something, go with the lower seat, IMHO.
atgatt is offline
post #4 of 14 (permalink) Old 02-07-2008, 07:16 PM Thread Starter
jnor's Avatar
A while back someone had a rear shock bracket that lowered the rear, I can't find the link anymore.
Has anyone seen it?
'15 DL1000
jnor is offline
post #5 of 14 (permalink) Old 02-14-2008, 06:04 PM Thread Starter
jnor's Avatar
Lowering Bracket For Rear Shock
I've bought the bracket to lower the rear 2", slid the fork tubes down in the triple trees, and ordered the 2" lower gel seat.
The Versys is a great bike, but the stock 33" seat height my wife (it's her's), or me (i'll ride it more ) couldn't live with.
Here's a pic of the rear shock lowering bracket.
'15 DL1000
jnor is offline
post #6 of 14 (permalink) Old 02-18-2008, 11:57 AM
psc
So can you list the source of this bracket?
Peter
psc is offline
post #7 of 14 (permalink) Old 02-18-2008, 12:25 PM Thread Starter
jnor's Avatar
Here's the ebay item number, you can still find it: 120219765339
the sellers ebay id is: sportbikedetails
Jim
'15 DL1000
jnor is offline
post #8 of 14 (permalink) Old 03-08-2008, 09:34 AM
Hi JNOR:
I too just ordered the lowering link, haven't received it yet. Did you install and or ride with it yet? Can't wait to get my feet on the ground. Let me know if you notice any handling difference.
Thanks,
Pulllll
Pulllll is offline
post #9 of 14 (permalink) Old 03-10-2008, 08:52 AM
Well I just installed the rear lowering link, it lowered the seat apx. 1 1/4", perfect for me. Took the bike out of a quick test ride, it seems to be slightly less responsive in handling, however there were 30mph winds and 30 degree temperature so I couldn't give it a solid test yet. I plan on lowering the front 1/2" to even out the bike's geometry.
I'll post the results when it's done and hopefully warmer.
Pulllll
Pulllll is offline
post #10 of 14 (permalink) Old 03-10-2008, 11:41 AM Thread Starter
jnor's Avatar
I lowered mine about the same in the front also, by sliding the forks through the triple trees. I had to shorten the kickstand after lowering both ends.
I have ridden it over 100 miles since lowering it, and can see no difference in the handling.
I did crank the rear spring up a little, I had it in the lowest setting to get the bike to settle some before I lowered it.
'15 DL1000
jnor is offline
post #11 of 14 (permalink) Old 03-10-2008, 11:49 AM
How much did the link lower your bike, and how much did you lower the front end? I too cranked up the rear shock as I also had it on it's lowest setting. Thanks for the info.
Pulllll
Pulllll is offline
post #12 of 14 (permalink) Old 03-10-2008, 04:25 PM Thread Starter
jnor's Avatar
It looks like about 2", hard to tell, I had to cut 3/4" off of the kickstand.
'15 DL1000
jnor is offline
post #13 of 14 (permalink) Old 03-14-2008, 04:53 PM
Lowered and comfortable
I have lowered my bike 1 1/2" it now fits me, much more comfortable at a stop, even getting on and off I don't feel like I'm going to drop the bike. Installed the lowering link on the rear shock then cranked up the spring to setting 7 (was at 1 in attempt to lower), Then I removed all the front tupperware to access triple clamp without damaging anything else, loosened the triple clamp and lowered the front end 1". Reassembled and riding much more comfortable. Handling is the same as before adjustments. Now I need to shorten the kickstand 1" and I'm done and ready for some warm weather.
Pulllll
Pulllll is offline
post #14 of 14 (permalink) Old 05-30-2008, 10:14 PM
If you use a lowered seat you will find that your knee's will cramp up. but you can lower your pegs with an adaptor.
Colorado is offline
Similar Threads
Lowering kit for Versys. Speedy Gonzalez Modifications - Performance - V-650 236 10-18-2012 02:29 AM
lowering? indydave General Discussions - V-650 5 02-10-2010 12:49 AM
Lowering kit for Versys. Speedy Gonzalez Modifications - Cosmetic - V-650 36 02-08-2009 05:05 PM
Inexpensive Lowering Kit for V WillieFlo General Discussions - V-650 12 10-02-2008 10:16 PM
Lowering the V Godfather Modifications - Performance - V-650 5 07-24-2008 06:29 PM
