Gen 1 fairing bracing - Kawasaki Versys Forum
post #1 of 8 (permalink) Old 02-12-2016, 10:51 AM Thread Starter
So as I found in my windshield installation http://www.kawasakiversys.com/forums...indscreen.html the factory mount for the front fairing leaves a lot to be desired. Putting a big screen led to the whole fairing, gages and all, flexing a lot more than I was comfortable with. I promised myself that when I had a couple days that I knew I wouldn't be riding I'd take it all apart and weld some braces into it. I had big plans of this and that, adding metal here, etc. Well, since we had a big snowstorm the other day I decided to get to it.
Took off all the plastic and tried to figure out what the problem really was. Mostly turned out to be just the design isn't meant to carry any torque. This is what the stock mount looks like, the little arm off to the side attaches to the frame on the right side, and the little dingus in the middle bottom bolts to the steering neck. That's the only attachment points for the whole fairing and windshield. Ugh.
whodat is offline
post #2 of 8 (permalink) Old 02-12-2016, 10:55 AM Thread Starter
So the problems are many with this design. It uses a single attachment point at the bottom to support all the weight, and there's a lot of stuff packed into the small area. not much room for bracing within the structure. So I had a lucky thought and figured 'why not outside the structure?"
I had a couple old chair backs my wife had me cut off of some stools, which were exactly the right shape and size to scab onto the stock brace without making it look like ass. I added one long brace on the left side, running from the upper section of the stock mount back to a bolt on the frame. Immediately became much stiffer.
whodat is offline
post #3 of 8 (permalink) Old 02-12-2016, 10:56 AM Thread Starter
Then I grabbed some more metal and ran a brace from that down to the bottom left side. This new triangle made the whole thing rock solid.
whodat is offline
post #4 of 8 (permalink) Old 02-12-2016, 10:57 AM Thread Starter
Then for good measure I added a bottom brace to the right side existing brace, again making a triangle. Triangle=strong, H=weak.
whodat is offline
post #5 of 8 (permalink) Old 02-12-2016, 10:59 AM Thread Starter
I considered adding another upper brace on the right side, but sometimes overkill is just overkill. All of this fits behind the stock plastic, none is particularly visible, nothing touches or rubs on anything, and it's still 100% removable. I claim success. Now there's almost no movement in the windscreen even if a lot of force is used, and the little that there is is clearly coming from the rubber mounting of the screen itself. Total cash outlay: 0$.
Oh yeah, all welding was done on the bike with spare welding gloves acting as my welding blanket. I could have made the welds prettier if I took it off, but like I said, there's a lot going on inside that front end and it wasn't worth the hassle.
whodat is offline
post #6 of 8 (permalink) Old 02-12-2016, 12:26 PM
I assume you electrically welded it...? Were you at all concerned about transients affecting the computor?
post #7 of 8 (permalink) Old 02-12-2016, 01:40 PM Thread Starter
Yup, used my medium mig. I was pretty much not worried at all about the computer. I won't go so far as to claim 'old wives tale' but I've never seen somebody actually prove that welding damaged their computer. To begin with, auto electronics are pretty highly hardened and motorcycle electronics even more so. Next, although it does make a pretty arc the mig uses DC current so no big danger of stray AC. Finally, common sense good welding practice was employed, having the ground as close to the weld point as possible, clean bare metal for the ground, etc. That's not to say that I didn't have just the teeniest bit of relief when I fired the bike up afterwards for a functions check.
whodat is offline
post #8 of 8 (permalink) Old 02-14-2016, 01:15 PM
Thanks.
