Fixing "yellowed" headlights.... - Kawasaki Versys Forum
 2Likes
  • 2 Post By fasteddiecopeman
post #1 of 9 (permalink) Old 01-24-2016, 12:45 PM Thread Starter
Yesterday I was on a 'mission' to fix the yellowed headlights
on my wife's car (this 'fix' will apply to plastic motorcycle headlights TOO!), so I stopped at a NAPA store, and asked where I'd find 'kits' to fix that problem.
A fellow paying for his stuff called out..."Use baking soda - it WORKS!". The salesman took me to an aisle - NOTHING, but said to try Walmart, so I headed down the road to try them. I went to the baking section first, where I found baking soda at 82 cents for a pretty good sized container. I bought it for 86 cents OTD, then rode home, got some water, an old gym sock, a stool to sit on, then poured a bit of the baking soda into a plastic lid, dampened the sock, picked up a goodly amount of the baking soda on it, then started rubbing the driver's side light w/ it. Only a few minutes later it looked like this
so I started the same on the other light. In a TOTAL time of LESS than 15 minutes I had accomplished this (and probably used only 2 or 3 cents worth of the 'soda'). I'm impressed....
WORTHWHILE for any do-it-yourselfers out there!
weljo2001 and Arion like this.
post #2 of 9 (permalink) Old 01-24-2016, 01:02 PM
looks good .Don't laugh but I started cleaning my oven this morning using baking soda.
turn8a is online now
post #3 of 9 (permalink) Old 01-24-2016, 05:06 PM
Biz
Biz's Avatar
I bought the Meguire's plastic polish and then use a buffer pad on my drill. It brings them back about 85%, but never as good as new, and they seen to decay back into dull in about a year.
Biz is offline
post #4 of 9 (permalink) Old 01-24-2016, 07:23 PM
Yep Baking soda is powerful stuff!
Headlight Kits include a sealant that replaced the UV coating you just polished off.
You need to now apply this sealant or the plastic headlights will crack and craze in the sunlight.
Gigitt is offline
post #5 of 9 (permalink) Old 01-24-2016, 09:22 PM
I've used basic toothpaste in the past, with surprisingly good results.
'09 Versys
Jmason is offline
post #6 of 9 (permalink) Old 01-25-2016, 08:10 AM
kohburn's Avatar
baking soda and toothpaste(with baking soda) is just a mild abrasive. cheap polishing compound.
kohburn is offline
post #7 of 9 (permalink) Old 01-26-2016, 12:55 PM Thread Starter
I've used those kits in the past (in Canada), but I don't recall seeing something to seal them after.... I've used Maguires kits, among others.
post #8 of 9 (permalink) Old 01-26-2016, 01:14 PM
1stversys's Avatar
I had heard before that toothpaste would fix 'foggy' headlights. Good to know other things work too! Thanks Eddie
14 Kawasaki Versys 650 ABS (kawi green)
1stversys is offline
post #9 of 9 (permalink) Old 01-27-2016, 12:46 PM
Lours_Polaire's Avatar
I'm with Giggit on this one
I bought a kit last summer and it did have a sealant to be applied after all the polishing was done
Not sure if the reason is uv protection to avoid cracking and yellowing, but it makes a lot of sense
Also, that sealant has a hardener in it (says the manufacturer) that will delay in time the need for another polishing (gee I hate that sentence ...)
LOP
Lours_Polaire is offline
