Cheap mod time - Kawasaki Versys Forum
Like Tree11Likes
  • 2 Post By 52Degrees
  • 1 Post By SteveJ
  • 2 Post By dadsafrantic
  • 1 Post By Cantab
  • 2 Post By Modene
  • 1 Post By kardan
  • 2 Post By kawimassgirl
post #1 of 15 (permalink) Old 01-14-2020, 06:08 PM Thread Starter
52Degrees's Avatar
Cheap mod time
Bought a cheapy wind deflector I found on ebay. It's extraordinarily meh.
Fastoman and weljo2001 like this.
2016 KLZ1000GBFAL
No mods yet
52Degrees is offline
post #2 of 15 (permalink) Old 01-14-2020, 07:31 PM
I bought the same thing and thought the same thing, until I flipped it upside down and set it up like a Laminar Lip or similar. It really quieted down the buffeting.
52Degrees likes this.
'15 KLE650LT
'98 KLR650
And most of Canada too, eh?
SteveJ is offline
post #3 of 15 (permalink) Old 01-14-2020, 08:11 PM Thread Starter
52Degrees's Avatar
So, at the bottom of the windshield?
2016 KLZ1000GBFAL
No mods yet
post #4 of 15 (permalink) Old 01-14-2020, 08:37 PM
dadsafrantic's Avatar
flip the little wind screen to point downwards. it shouldn't be much higher than the screen itself. then move it in and out and tip it at different angles until you get the wind/noise where you want it.
SteveJ and 52Degrees like this.
Dadsafrantic
2018 versys 650 lt
0 miles- 8/15/19
dadsafrantic is offline
post #5 of 15 (permalink) Old 01-14-2020, 08:39 PM Thread Starter
52Degrees's Avatar
Cool. I'll try it. Thanks.
2016 KLZ1000GBFAL
No mods yet
post #6 of 15 (permalink) Old 01-14-2020, 10:16 PM
Cantab's Avatar
How do you 'like' a post ?
Cantab is offline
post #7 of 15 (permalink) Old 01-14-2020, 10:29 PM Thread Starter
52Degrees's Avatar
If you use Tapatalk, there's a button at the bottom of each post.
2016 KLZ1000GBFAL
No mods yet
post #8 of 15 (permalink) Old 01-15-2020, 02:50 AM
Cantab's Avatar
Cheers 52Degrees, i have just seen onewizards post about this.
Cantab is offline
post #9 of 15 (permalink) Old 01-15-2020, 02:51 AM Thread Starter
52Degrees's Avatar
I didn't realize there was an issue with likes until I saw it as well.
2016 KLZ1000GBFAL
No mods yet
post #10 of 15 (permalink) Old 01-19-2020, 07:56 AM
Craigar's Avatar
52Degrees, how's the cheap new mod working out for you after adjusting?
It's been swell, but the swelling has gone down.
Craigar is offline
post #11 of 15 (permalink) Old 01-19-2020, 09:04 AM Thread Starter
52Degrees's Avatar
It's still just meh.
2016 KLZ1000GBFAL
No mods yet
post #12 of 15 (permalink) Old 01-19-2020, 11:12 AM
Just donít tighten the screws too tight on the mount that slides onto your big screen,it will make small cracks. Thatís even with the two small metal shims in place & rubber part. The last bike I put it on I really couldnít tell the difference. I have no intention of using it on my Versys with my PUIG Touring screen.
HoosierFordMan and 52Degrees like this.
Modene is offline
post #13 of 15 (permalink) Old 01-19-2020, 11:18 AM Thread Starter
52Degrees's Avatar
Can't tighten it too much or the stupid shims slide out to the sides. They really did a mediocre job designing this.
2016 KLZ1000GBFAL
No mods yet
post #14 of 15 (permalink) Old 01-19-2020, 01:14 PM
kardan's Avatar
I didn't have problem with my wind deflector on my V650.
It is on same place where I put them before 9 months
I just clean on windscreen place where it be with alcohol, and rubber also with alcohol.
2 screws which are on front part, I added threadlocker glue, and really gentle tight them.
Other 4 screws I added threadlocker tape, and tight enough to not move ( also i have all time in my wallet allen key for case if some screws loose tightness )
I have that deflector last 10 000km, and my top speed was 190 km/h, and didn't move from place where I put them.
Angle which I choose is best for me, and didn't change since first day, no matter how fast i ride.
Buffeting is 99.9% gone.
Cantab likes this.
Gas for heating, diesel for plowing, electricity for cooking, petrol for driving
kardan is offline
post #15 of 15 (permalink) Old 02-07-2020, 06:01 PM
kawimassgirl's Avatar
I love my cheap Ebay deflector. The rubber bits that came with it were way too soft. So what I did was cut up some pieces of a thick, wide rubber band. Also cut up a rubber bracelet, (like you would get for free on a Benefit run).
After layering up some of these rubber pieces behind the original soft rubber I was able to crank the screws down on the mounting bracket.
You can also see the yellow rubber band that I used in between the shield and metal bracket.
Sent from my SM-G955U using Tapatalk
Fastoman and 52Degrees like this.
kawimassgirl is offline
