Bike won’t start, need some help - Kawasaki Versys Forum
Like Tree2Likes
  • 1 Post By weljo2001
  • 1 Post By Fastoman
post #1 of 6 (permalink) Old 05-22-2020, 01:51 PM Thread Starter
maine_man's Avatar
So my V has been sitting for quite a while because of quarantine. I tried to go for a ride yesterday and it started up, then stalled before I pulled away from my parking space. Then it would not restart. I thought maybe the fuel was bad so I got a fuel additive to help with water degradation in the gas, and I bought a new battery while I was at it.
This is a video of what happens now (turn on audio):
https://www.dropbox.com/s/lp97abne5r..._2719.MOV?dl=0
Any ideas?
stand up tall, pretend you’re strong, in the hope that you can be
maine_man is offline
post #2 of 6 (permalink) Old 05-22-2020, 03:07 PM
ToSlow's Avatar
give it some throttle
Living Large
ToSlow is offline
post #3 of 6 (permalink) Old 05-22-2020, 03:22 PM Thread Starter
maine_man's Avatar
Tried that, thanks though.
post #4 of 6 (permalink) Old 05-22-2020, 06:06 PM
Sounds similar to Vehicle Down sensor on 650 Versys
Section 3-68 starts the description, error code 31. The thing is, the sensor will cause all kinds of grief without throwing a code. We have a work around in this thread https://www.kawasakiversys.com/forum...ont-start.html Some of the symptoms are what you show in the video, the ECU has a delay to allow starting, however once it completes a scan if the voltage in from the VDS is below setting, it kills the stick coils, the fuel pump and the injectors. I looked at the drawing, the voltage is slightly higher than the specs for the 650 but that voltage divider by dddd should work.
post #5 of 6 (permalink) Old 05-22-2020, 07:32 PM
What's your idle RPM's set at...To adjust just look at the red circle in the photo...
Versys 1000 Moto Werk's Goodies by weljo2001, on Flickr
Smiley likes this.
post #6 of 6 (permalink) Old 05-22-2020, 09:05 PM
Was your bike resting out the Lockout on side stand, if so give it some lub/WD40 and a few up and downs and try staring your bike. I had similar problem on my 09 way back when i didn't have the center stand.
Smiley likes this.
