1000 Brake caliper heat shields? - Kawasaki Versys Forum
Like Tree4Likes
  • 1 Post By Skypilot 69
  • 1 Post By bnucci24
  • 1 Post By fasteddiecopeman
post #1 of 9 (permalink) Old 01-26-2020, 04:47 PM Thread Starter
Updating
I got the wrong parts in the right box off Amazon so the Galfer 1371 are correct for 2015 Versys 1000LT. I was sent a Galfer with 1375KBA61197 and 103-71-0181 barely visible. Ceramic sintered but can't find what they would fit.
Thank you
Brian
Hi Guys
Looking for info on the rear brake caliper heat shield piece that is between the caliper piston and the pads. I rebuilt the rear brake cylinder as I think I jammed corrosion in there pushing the piston back to put my rear wheel back on. Seemed like it was dragging pretty bad even without the chain attached.
I have some EBC FA174HH but they don't supply the heat shield part that has a white sheet under the steel part with clip ons.
I can't find this part listed anywhere so maybe it comes on the OEM pads if you want to pay ~ $65 a pair.
Yes I will move the old ones over but would like to have an option to put all new parts in since its rebuilt.
Thanks Much
Brian
bnucci24 is offline
post #2 of 9 (permalink) Old 01-26-2020, 04:52 PM
52Degrees's Avatar
Originally Posted by bnucci24 View Post
Hi Guys
Plan was to replace rear pads since the piston was clean so it could be pushed in while spotless to fit new pads. Galfer lists the wrong ones 1371 for the 2015 Versys 1000LT.
Thanks Much
Brian
Shown should be OEM pads drawing then the Galfer 1371 (which seem to be for the 650?) shown with the EBC then the Galfer incorrect ones alone.
That's an anti squeal shim. You can use contact cement or rtv in its place if you have brake noise.
2016 KLZ1000GBFAL
No mods yet
52Degrees is offline
post #3 of 9 (permalink) Old 01-26-2020, 07:59 PM
52degrees is right. The squeal is caused from vibration between the caliper and the pads. you can put a thin layer of RTV on the back of the pads, let it dry, then install the pads. They also make a brake pad anti squeal compound. https://search.yahoo.com/search;_ylt...fr=sfp&iscqry=
52Degrees likes this.
Skypilot 69 is offline
post #4 of 9 (permalink) Old 01-26-2020, 08:44 PM Thread Starter
Thanks very much guys!
I was reading conflicting data that this slotted metal and white shim combo was to block heat from the pads from entering the piston and heating up the caliper and fluid, which seemed reasonable as "they" sell Titanium shims that claim to block the heat but perhaps that was a Porsche site...
I do remember in the old days we used to just put some type of specific stuff on car pads when 002 Auto parts sold them.
I will go with a dab of some of the mentioned stuff and abandon the older clip on squeal thing.
Best to all
bnucci24 is offline
post #5 of 9 (permalink) Old 01-26-2020, 09:22 PM
You can still use the old shims if you like.
post #6 of 9 (permalink) Old 01-27-2020, 03:50 PM
I use "DISC BRAKE QUIET" from CRC when I do car brakes, but haven't tried it on a motorcycle.
post #7 of 9 (permalink) Old 01-27-2020, 03:55 PM
52Degrees's Avatar
It was a big problem when I worked at Chevy. Corporate had us using various products over a few years and finally settled on rtv for a cheap, effective fix on the worst cases... Mostly single piston calipers on heavier vehicles.
The CRC stuff is OK, though.
2016 KLZ1000GBFAL
No mods yet
post #8 of 9 (permalink) Old 02-01-2020, 11:57 AM Thread Starter
Thanks again to all that replied I appreciate it very much.
Swapped the rear pads to EBC FA174HH and moved over the anti squeal plates. Permatex brake grease on pins. Caliper got new seals and piston, (destroyed the old one taking it out) and all seated with DOT 4 no special piston grease. Fluid fill and flush. Did the front fluid swap also. So new Conti Road Attack 3 rubber on the 1k with fresh brake pads and fluid and waiting for a decent day here in NJ. Last time I did a bunch of work on the Versys i left it idle on the kickstand and it fell over in the driveway. I guess - Stay humble, ride for yourself, not others.
Old pads were NIssin TT2182FF with about 2-2.5mm left and worn evenly at 13k miles. The work was due to me shoving the dirty caliper in while fitting the tires back on and it was binding up or seemed to be.
Best to all
Brian
bnucci24 is offline
post #9 of 9 (permalink) Old 02-01-2020, 12:00 PM
52Degrees's Avatar
Best to all
Brian
I swapped my fronts to EBC HH pads a couple months ago and couldn't be happier. They don't seem to bake to the rotors like the factory pads do, which caused a brake pulsation for me.
2016 KLZ1000GBFAL
No mods yet
