'13 1k valve shim - Kawasaki Versys Forum
Like Tree4Likes
  • 2 Post By weljo2001
  • 2 Post By invader
post #1 of 5 (permalink) Old 09-18-2019, 07:03 PM Thread Starter
'13 1k valve shim
Anyone know what the diameter of the shims is? My dealer is refusing to tell me (knows doing the work my self).
I'm think 7.48mm
Thanks!
Jesse
bc_versys is offline
post #2 of 5 (permalink) Old 09-18-2019, 08:04 PM
Yep, 7.48 ..............https://www.ebay.com/itm/Hot-Cams-7-....c100854.m4779
Fastoman and funflyingguy like this.
post #3 of 5 (permalink) Old 09-19-2019, 12:27 PM
Valve Shim
I'm think 7.48mm
Thanks!
Jesse
If you follow the 650 valve shim post on this forum, you will discover that many of us just sand the shims to the size we need, that many shims are not what the value as listed when you buy them. The most important is the tools you use, go no go feeler gauges and a 3 decimal micrometer . There is a whole list of tools needed in those posts, Between my posts and fast Eddie, over 6 valve shims have been done using this method, one huge advantage is I set all my clearances at maximum clearance by sanding, some have commented on case hardening, no worries , you will never reach the depth of the hardening, also there is no wear on these as they are truly a spacer.
Also FYI, make sure you do the checking per bucket / shim, 1 at a time or make sure you use something like a egg carton to make sure the bucket return to their original location, the bucket shim combo needs to be observed as like each shim the total thickness of the buckets is not identical.Others have purchased shims to find the dimension stated is not what is measured, usually you have tight valves so the existing shim is too thick, some have been able to swap shims between valve locations, this can lead to making mistakes. The other thing that some have done is take the tight shims to the dealer with your micrometer and swap with the service department with the measured values you need, not all shops are willing to do this, for me it is a PITA, since the drive to and from the dealer equals my total time in sanding all the shims, minus all the frustration at the dealer
post #4 of 5 (permalink) Old 09-19-2019, 11:57 PM
They usually need to be slightly thinner than original. I thinned and switched some shims around, to set all my inlet and exhaust valves' clearances at middle of spec range. I used wet fine emery cloth on a flat wood surface to thin some of my original shims.
If you're not up to the task, you can get 7.48 mm diameter shims (same as Versys 650/1000) in 0.025 mm increments (instead of only 0.050 mm increments) in 2.50 mm to 3.50 mm thicknesses from your Kawasaki dealer.
Kawasaki 2006-2011 KX-250F shims - 0.025 mm increments $11.50 each.
(Versys 1000 shims - 0.050 mm increments $15.12 each)
Shim ------ Kawasaki #
2.800mm - 92180-0179
2.825mm - 92180-0180
2.850mm - 92180-0181
2.875mm - 92180-0182
2.900mm - 92180-0183
2.925mm - 92180-0184
2.950mm - 92180-0185
2.975mm - 92180-0186
3.000mm - 92180-0187
3.025mm - 92180-0188
3.050mm - 92180-0189
3.075mm - 92180-0190
3.100mm - 92180-0191
onewizard and Fastoman like this.
post #5 of 5 (permalink) Old 09-22-2019, 05:03 PM Thread Starter
Wow. Thanks for such great info and advice!
Really appreciate it.
Gonna go slow and takey time 😂
