V 1000 / Bike wont turn over, dead after a day - Page 5 - Kawasaki Versys Forum
Like Tree33Likes
post #81 of 87 (permalink) Old 10-01-2019, 01:27 PM
quexpress's Avatar
We're looking at the V1k here, which idles at 1000 rpm.
Sorry. I had taken for granted that this was about 650s because this thread is in the 650 section of the forum.
52Degrees likes this.
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #82 of 87 (permalink) Old 10-01-2019, 01:34 PM
52Degrees's Avatar
Yeah. The OP started the thread on this section on accident.
2016 KLZ1000GBFAL
No mods yet
52Degrees is online now
post #83 of 87 (permalink) Old 10-01-2019, 03:03 PM
edited Thread / Moved to V1000
No worries, many of us responded the same way, it is now obvious.
quexpress and 52Degrees like this.
post #84 of 87 (permalink) Old 10-02-2019, 04:58 PM Thread Starter
With that said, I can attest to having no issues with running the full lighting package while idling. I don't make a habit of if it, but the bike has idled long enough to activate the cooling fan a number of times with the high beam on, and no trouble lights or guage fluctuations were noted. This was also with my fog lights on high.
I have since replaced the incandescent low beam with an led unit.
I am interested in upgrading the low beam on my V1k as well.
Sorry for the delay in posting testing results, I am working on some stuff at work that sucks up my life and brain.
onewizard and 52Degrees like this.
JackImpact is offline
post #85 of 87 (permalink) Old 10-03-2019, 11:20 AM
LEd specific Lighting
My understanding is the headlight on the V1000 is similar to the V650, I can tell you if it is better lighting and the reflectors are the same, you are wasting your time, I did install a LED on the low beam, it reduces my base load by about 45 watts ( I was running a Osram 65 watt which is closer to 100 watts at 14.2 volts). I installed the Denali 2.0 led and run on high beam 97% of the time.Both are aimed for distance, the right side is aimed into the ditch, the left is slightly right of center and forward about equal to the center of my high beam Osram 65 watt.
Since the V1000 appears to have more wattage available than the V650 , and I haven't heard of one stator failure to date, my thought is it would be a waste of time and $$$. Add aux. lighting instead.My aux. lighting can be on while my main lighting is off ( key on bike not running or running )
post #86 of 87 (permalink) Old 10-03-2019, 11:32 AM
52Degrees's Avatar
The led I installed improved night driving quite a bit, but that may have more to do with the reflectivity of lane markers in my area and less to do with an actual increase in brightness. The main reason I did it was to improve bulb life.
Also, the whiter light does compete better with the ultra-bright headlights on cars around here, not to mention the idiots constantly driving with their high beams on in traffic.
2016 KLZ1000GBFAL
No mods yet
post #87 of 87 (permalink) Old 10-06-2019, 02:13 PM Thread Starter
Quick update, busy weekend.
Measured draw with the tender and lights, and it was still .17mA.
Put the phone charger on and it was over 4.00mA
Left the phone charger unhooked for now. Bikes been starting fine all week with no riding.
Didnt get a chance to measure recharge system yet.
