Rear Axle Nut Alternative - Page 2 - Kawasaki Versys Forum
Like Tree23Likes
post #21 of 29 (permalink) Old 05-01-2019, 12:10 PM Thread Starter
.. and yes, i had noticed that the nut hadnt moved. thats always good to see !!
funflyingguy is offline
post #22 of 29 (permalink) Old 05-01-2019, 01:35 PM
Torque / Lubed / Dry
Originally Posted by funflyingguy View Post
certainly over-torquing could cause that.
but what about following the book spec torquing as was my second thought?
after more thought:
book torquing lubricated threads might be the same as over-torquing. maybe thats your point, quexpress? i wasnt aware of the PDF document posted by Onewizard.
what i like is that this whole discussion might benefit some not only for axle nut tightening, but for tightening any nut on the bike. some things you can read about, some things you know from experience. sure would rather read about it than break something.....
https://www.kawasakiversys.com/forum...41-post18.html
https://www.engineeringtoolbox.com/t...ts-d_1693.html
funflyingguy likes this.
post #23 of 29 (permalink) Old 05-01-2019, 01:39 PM
quexpress's Avatar
Thumbs up
after more thought:
Voilą! You got it!
I don't have time to look for it right now but if no one points it out, I'll look for it later.
Good stuff!
onewizard and funflyingguy like this.
I still have a full deck.
I just shuffle slower.
quexpress is offline
post #24 of 29 (permalink) Old 05-01-2019, 01:41 PM
One Step Ahead
Originally Posted by quexpress View Post
Voilą! You got it!
Good stuff!
As in the title.
post #25 of 29 (permalink) Old 05-01-2019, 01:47 PM Thread Starter
most excellent. thank you!!
post #26 of 29 (permalink) Old 05-01-2019, 02:20 PM
Just maybe that's the reason the rear axle-nut is a castellated one - the cotter-pin keeps it secure, pretty much whether it's been torqued TOO hi, TOO lo, or to the correct value.
SouthernCruizer likes this.
post #27 of 29 (permalink) Old 05-01-2019, 04:50 PM
quexpress's Avatar
Red face
I agree ... but if a person decides to get rid of cotter pins, the torque on the replacement lock nut is very important.
post #28 of 29 (permalink) Old 05-01-2019, 04:52 PM
quexpress's Avatar
Red face
As in the title.
I can't locate the PDF file but hopefully these 2 attached images should/could help.
post #29 of 29 (permalink) Old 05-01-2019, 05:28 PM Thread Starter
quite a few bikes use the self-locking nut, as was mentioned here previously. nothing inherently wrong with the concept: just different approaches. the torque is important with both and discussing it can reinforce that. either way, its important to know what will work, how it works, and what works for you...
these posted charts are good reference info. i have saved a couple for my own future use. thanks for posting them...
quexpress likes this.
Similar Threads
Stupid axle nut! naudan Technical Discussion - V-650 12 08-13-2012 09:15 PM
Locked Rear Axle Nut (HELP!!!) pdpleog Technical Discussion - V-650 23 07-05-2012 08:23 PM
Rear axle nylon nut Pismocycleguy Technical Discussion - V-650 21 05-03-2012 03:19 PM
Axle Nut sharrison56 Technical Discussion - V-650 5 11-06-2008 03:47 PM
