Electrical Question - Kawasaki Versys Forum
 2Likes
  • 2 Post By Claude.
post #1 of 10 (permalink) Old 08-30-2018, 02:34 PM Thread Starter
Wiring Question
On my 2013 V1000 I have Barkbuster Handguards with LED turn signals (shown below). With a bit of creative wiring, can I modify the turn signals so they become running lights? And then operate as turn signals when needed?
Paul
2012 Kawasaki Versys 1000
2012 Honda Gold Wing 1800
CuddyBuddy is offline
post #2 of 10 (permalink) Old 08-30-2018, 03:14 PM
Jay_Chicago's Avatar
I've bumped into this video the other day while thinking about doing it. It may help.
www.youtube.com/watch?v=qTcDc85d1Q0
Jay_Chicago is offline
post #3 of 10 (permalink) Old 08-30-2018, 05:54 PM
Similar
I used 2 relays SPDT , triggered off the signal lights. Normally closed is the running light, NO is the signal.Total cost including sockets and 2 new 40 amp 5 pin relays, about $12 total
onewizard is online now
post #4 of 10 (permalink) Old 08-31-2018, 11:27 AM Thread Starter
I ended up ordering the Barkbuster Storm running lights. https://fortnine.ca/en/barkbusters-l...ing-led-002-wh
Thanks guys for your help.
File Type: jpg led-white-light-position-running-led-002-wh[1].jpg (20.2 KB, 3 views)
Paul
post #5 of 10 (permalink) Old 08-31-2018, 12:13 PM
sgtmango333's Avatar
Ouch...pricey! Revzilla is much cheaper.
https://www.revzilla.com/motorcycle/...tic-handguards
sgtmango333 is offline
post #6 of 10 (permalink) Old 08-31-2018, 12:24 PM
Don't forget that you are comparing CDN vs US currencies.
FortNine usually have very good prices and an incredible service.
onewizard and Smiley like this.
Claude. is offline
post #7 of 10 (permalink) Old 08-31-2018, 12:29 PM
[U]...With a bit of creative wiring, can I modify the turn signals so they become running lights? And then operate as turn signals when needed?
I gave a lot of thought at this and only found two ways.
1) Buy after-market turn signals that have three wires (then two intensities) (this is the way I choose).
2) Buy Signal Dynamics module (link below). I know it is for rear turn signals but you simply have to not use the brake wire.
Tri-Star? XP Turn Signal To Brake Light and Running Light Conversion Module - Signal Dynamics
The easiest way I originally intended was to replace the sockets inside the OEM turn signals but it is molded in the inner plastic parts so it is a no go.
Claude. is offline
post #8 of 10 (permalink) Old 08-31-2018, 05:12 PM
Signal / Running Lights
Going to keep this short, I chose the Barkbuster location for two reasons, one from driving a service truck for over 40 years and depending solely on mirrors for side and rear view. With the led on the barkbuster , my lighted width is the same as the signal lights but 1 foot higher at 3.5 feet.
As to modifying strictly your front signal lights, if you install the superbright LED bulbs in the original sockets. You can convert to exactly what you want , very simple, same price as I said in my previous post, 2 relays and socket. Using the same circuit for the signal lights.
https://www.amazon.ca/MICTUNING-5-Pr...t+40+amp+relay Make sure you get a 5 prong , several guys have been stuck with the 4 prong which is a normally open
Basically the left turn signal wire Green and right turn signal Grey get cut as far away from the signal light as possible. Grey to relay #1 pin 87a, brown with yellow tracer at the flasher gets taped and connected to pin #30, pin #85 goes to black / yellow ( ground), original grey from harness goes to #86.
Relay #2 , Green ( from left signal light) to pin 87a, brown /yellow to pin #30 same wire as relay #1, pin#85 to black / yellow same wire as relay #1, original green wire from harness to #86.
What you will find is the on sequence on the rear lights to be the off cycle of the front, everything will work as original including the emergency flasher circuit.
Didn't read the post correctly, still need two relays and instead of cutting the the green and grey, you tap the green and grey, green to left running relay #2 pin 86 and grey to relay #1 right turn signal pin 86. Power source goes to pin 30, ground to pin 85, pin 87a from relay #1 to right barkbuster, pin 87a relay #2 to left barkbuster. Leave grounds as is.
post #9 of 10 (permalink) Old 09-02-2018, 05:51 AM Thread Starter
Not so. When you convert $US to $Canadian, and add shipping to Canada, Revzilla is $111.70 and FortNine is $93.78.
Paul
post #10 of 10 (permalink) Old 09-02-2018, 12:33 PM
Re Read Post
So I took another look and realized that you had the barkbuster LED. I edited my post #8.
