11.3mm Tire Valve Question - Kawasaki Versys Forum
 5Likes
  • 2 Post By CuddyBuddy
  • 1 Post By fasteddiecopeman
  • 1 Post By AuroraTom
post #1 of 10 (permalink) Old 05-03-2018, 06:48 AM Thread Starter
At the local shop, I had them install a 90 degree tire valve on the rear wheel. This is to accommodate the tire monitor on my Doran TPMS. Most of my riding is country roads, so I rarely hit a high speed. However, the other day I was on the highway, doing 120-130 km/hr. And I was losing air out of the rear tire. I pulled over, made sure the Doran monitor was screwed tightly on the tire valve, and filled the tire with air. Back up to the same speed, and started losing air again. Put air in, back on the highway, and started losing air a third time. Rode home on smaller roads, no air loss.
Back in the garage for a couple of days now, and no air pressure loss. And no nails or anything that I could see in the tire. However, this morning I pushed the 90 degree metal tire valve a bit to the side, and I could hear air leaking out. So the issue is the tire valve.
My question to the forum, is what could this mean? Maybe the shop didn't use an 11.3mm tire valve? Maybe it's just simply loose? (There is a nut to tighten it. If that's the culprit though, and I tighten it, it'll probably come loose again).
The service manager at the shop is a good guy, and he'll respond right away when I contact him. But I'd like to make some helpful suggestions to him.
TIA!
Paul
2012 Kawasaki Versys 1000
2012 Honda Gold Wing 1800
CuddyBuddy is offline
post #2 of 10 (permalink) Old 05-03-2018, 11:49 AM
I might be wrong but i don't think you are suppose to use 90 degrees valves with the TPMS Caps. When i got mine on my 09 V-650 it said to use straight metal valve stems...
post #3 of 10 (permalink) Old 05-03-2018, 01:58 PM
I put some rubber 90 degree stems (pull-throughs from the bottom) on my '08 but replaced them after suffering a loss of air along the sides. Since I replaced them w/ mag-wheel metal 90s, the nut holds them securely.
post #4 of 10 (permalink) Old 05-03-2018, 11:01 PM
motorboy's Avatar
If your 90 degree stems don't have a nut on the out side of the rim change them out now-the ones that use a nut on the inside there is no way to tighten them and by moving the stem it is now loose-also there are several sizes
Deep in Cajun Country
motorboy is offline
post #5 of 10 (permalink) Old 05-04-2018, 05:41 PM Thread Starter
All is good. The dealer replaced the 90 degree metal tire valve with a much more sturdy straight up metal tire valve. Rode home at 130 kph, didn't lose an ounce of air.
weljo2001 and motorboy like this.
Paul
post #6 of 10 (permalink) Old 05-04-2018, 06:16 PM
Indelibility's Avatar
Kurveygirl valve stems are the way to go.
Indelibility is offline
post #7 of 10 (permalink) Old 05-04-2018, 07:52 PM
Bought Kurveygirl valve stems for my 09 V-650 and FJR.....This time i bought a set of the chinese valve stems off eBay for less than 3 bucks...They work just as good...https://www.ebay.com/itm/90-Degree-C...4023%7Ciid%3A1
post #8 of 10 (permalink) Old 05-05-2018, 05:19 PM
...This time i bought a set of the chinese valve stems off eBay for less than 3 bucks...They work just as good....
I have the same ones for each of my Vs....
weljo2001 likes this.
post #9 of 10 (permalink) Old 08-16-2018, 08:48 AM
Valve stems
Thanks Weljo
Order placed.
Tom
AuroraTom is offline
post #10 of 10 (permalink) Old 08-16-2018, 01:47 PM
Originally Posted by AuroraTom View Post
Thanks Weljo
Order placed.
Tom
FWIW - I BELIEVE I used some blue Loctite so the nut wouldn't loosen on mine.
AuroraTom likes this.
