firstgear heated jacket liner and gloves - Kawasaki Versys Forum
post #1 of 7 (permalink) Old 11-19-2013, 10:13 PM Thread Starter
Anyone have experiece with these? Thinking about ordering them along with a dual controller.
adurbin is offline
post #2 of 7 (permalink) Old 11-19-2013, 10:28 PM
Warm & Safe make the heated gear and gloves for FirstGear. Warm & Safe have a lifetime warranty. You would be better purchasing directly from them if you like the gear. Gerbings and Powerlet are also highly recommended.
post #3 of 7 (permalink) Old 11-19-2013, 10:32 PM Thread Starter
Thanks Two. Ill check them out.
adurbin is offline
post #4 of 7 (permalink) Old 11-19-2013, 10:52 PM
Gerbings which I have also have the lifetime warranty on the electronics. You need this as the connectors can be an issue. Gerbings and Warm & Safe use the same connectors. Gerbings warranty coverage is excellent. Do consider the purchase of a dual channel heat controller with gloves and heated jacket liner. The use of a single channel for both does not work well. The liner needs to fit tight over just a long sleeve T shirt to transfer heat effectively. With a heat controller it works best if it is accessible while riding - I use the optional controller pouch hooked to my belt while riding.
post #5 of 7 (permalink) Old 11-20-2013, 05:06 AM
walter's Avatar
Been using the First Gear jacket liner and gloves for a couple of years now and definitely recommend them. Warm & Safe, the manufacturer, has been great to deal with whenever I had questions. I use the dual mounted controllers on both bikes ('09 Versys and '12 Connie). Little more work to do the install but once complete, a lot less hassle to use IMO than the wireless stuff. The jacket liner works best with a snug fit, I'm 5'10 and 182 lbs and the medium fits me just right.
Walter
IBA# 55188
2009 Versys
Givi V35 sidecases w/ Admore lights
SW-Motech rear rack
Givi windscreen
First Gear dual heat-troller
Thermo-Bob
Denali D2D LED driving lights
walter is offline
post #6 of 7 (permalink) Old 11-20-2013, 06:11 PM Thread Starter
After doing some further research, the Firstgear stuff will suit me just fine for the price. I ordered just a few minutes ago, should be there this coming week.
adurbin is offline
post #7 of 7 (permalink) Old 11-21-2013, 07:55 PM
Had one and yes I highly recommend it. It will keep you warm in winter but safe enough while riding.
kive-rider is offline
