Repsol Semi-Synthetic Oil Change - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > General Kawasaki Versys Discussions
General Kawasaki Versys Discussions For discussions on anything and everything related to the Kawasaki Versys.
Thread Tools Display Modes
  #1
Old 05-29-2010, 02:10 PM
weljo2001 weljo2001 is online now
Default Repsol Semi-Synthetic Oil Change
Had the oil changed after my st.louis trip. Went with the Repsol Semi-Synthetic Oil. Bike has 3800 miles on it and first off i noticed how the gear changes were getting smooth as butter on the ride home. anyones input on the oil would be appreciated.
__________________
2009 Blue Versys. Sold
My Farkles......http://www.kawasakiversys.com/forums...ad.php?t=20013
My Video Channel http://www.youtube.com/user/weljo2001?feature=mhee
My Photos...http://www.flickr.com/photos/54181788@N06/sets/
Old 05-29-2010, 04:27 PM
Bear on a bicycle Bear on a bicycle is offline
Default
Are you kidding??? Asking for input on oil on a motorcycle forum???
  #3
Old 05-29-2010, 07:43 PM
invader invader is offline
Default
Repsol semi-synthetic Moto Racing 4T 5W-40. It aint so bad... How much did you pay per litre?
https://imagenes.repsol.com/es_en/RP...t09_EN_ypf_REV[1]_tcm11-560009.pdf
http://www.repsol.com/es_en/producto...t/default.aspx
  #4
Old 05-30-2010, 05:55 AM
naz's Avatar
naz naz is offline
Default
what about the clutch?
repsol is considered a reliable brand here in eastern europe.if its price is good it may worth a try
  #5
Old 05-30-2010, 08:34 AM
maddjack's Avatar
maddjack maddjack is offline
Default
Banned
__________________
AMA EAA STN
  #6
Old 05-30-2010, 09:52 AM
oxman's Avatar
oxman oxman is offline
Default
I run the Repsol Full Syn oil in my V with no problems at all ....
__________________
  #7
Old 05-31-2010, 03:49 PM
Default
Had it changed at the dealership. Was charged just a little over $7.00 a quart
__________________
  #8
Old 05-31-2010, 05:10 PM
Spackler's Avatar
Spackler Spackler is offline
Default
I used Mobil 1 10W-40 last time. I also noticed smoother shifting. I'm switching to Rotella 15W-40. It meets the JASO spec, if that's important to anyone. Some seem to be hung up on that. I'm not so much, I just think it's a good oil.
  #9
Old 05-31-2010, 06:04 PM
naz's Avatar
naz naz is offline
Default
here in greece temperature rise dramatically last week.about 30 celsius atm....
so i am moving to amsoil 15-50 so as to replace same brand 10-40 i am running through winter.
  #10
Old 05-31-2010, 08:23 PM
buffamazon's Avatar
buffamazon buffamazon is offline
Send a message via Yahoo to buffamazon
Default
Um, someone help me out here. Is the oil in your gearbox even the same oil as the engine? I will claim "girl" here if I am wrong. Aren't synthetics for high compression high temperature applications?? Somebody edumacate me here.
__________________
09 Versys In Go-Fast Green
Acerbis Pro Pack Handguards
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
Wolo Bad Boy Air horn
Trackside 12 volt power adaptor
  #11
Old 05-31-2010, 08:45 PM
bigaussie's Avatar
bigaussie bigaussie is offline
2007 Kawasaki Versys
Default
Excuse me BuffAmazon - I have trouble imagining you playing the coy little girl for any reason!
__________________
"The happiest people donít have the best of everything, they just make the best of everything."
  #12
Old 05-31-2010, 08:58 PM
Default
Engine oil is also the gearbox and wet-clutch oil. There are synthetic oils for all applications, be it automobile, motorcycle, racing... 10W-40 JASO MA (high friction applications) motorcycle oil is the standard recommended for Versys. 5W-40 and even 0W-40 have a lower viscosity for easier cold starts and quicker circulation, and have the same viscosity as 10W-40 at operating temperatures. 10W-50, 15W-50, or 20W-50 JASO MA oil can be used in hotter climates to maintain proper viscosity.
  #13
Old 05-31-2010, 09:07 PM
buffamazon's Avatar
Default
Big Aussie...I think you just called me out...ROFL
Invader, thank you for the elegant explanation. I guess if using a synthetic yields obvious results, that makes the choice obvious. Bottom line for me, does the extra cost show me some increased performance?
I may be curious enough to try some out.
__________________
Ogio Tailbag
Ogio Saddlebags
Vortex 44T Sprocket
  #14
Old 06-01-2010, 12:07 AM
Fastoman Fastoman is offline
2009 Kawasaki Versysy
Default
Invader
Using 15W/50 Motul and bike is fine under tropical heat. Question is , How is the alternator lubricated and if using 15W/50 does it have any ill effect on the Alternator lubrication?
  #15
Old 06-01-2010, 12:42 AM
Default
Alternator is oil cooled, not lubricated. Nothing to worry about... Are you using Motul's semi-synthetic 5100 4T 15W50, or 'Technosynthese' 3100 GOLD 4T 15W50?
  #16
Old 06-01-2010, 12:48 AM
Default
Invader.
Using Semi Syn 5100 4T 15W50-hope its ok and thanks for the feedback.
  #17
Old 06-01-2010, 04:34 AM
Default
Motul's semi-synthetic (ester) 5100 4T 15W50 is great stuff... How hot is it there?
http://www.motul.com.my/eng/product_...4stroke16.html
There's also 100% synthetic (ester) 300V 4T FACTORY LINE 15W50.
http://www.motul.com.my/eng/product_...4stroke07.html
  #18
Old 06-01-2010, 04:40 AM
Default
Invader.
Temp can go up to 36~37 deg C on a normal day. Payment temp can be in the 40++. So we run hot here all year long, only when its the mosoon season does the Temp drop but we dont ride in the rain.
I think I will stick to Motul SS (ester) 5100 4T 15W50. I change oil/filter every 5K kilometers.
Thanks for the feedback and
  #19
Old 06-01-2010, 10:02 AM
Hardware's Avatar
Hardware Hardware is offline
Default
... I will claim "girl" here if I am wrong...
LOL
__________________
~~ Live Like You're Dying ~~
  #20
Old 06-02-2010, 10:06 AM
Pretbek's Avatar
Pretbek Pretbek is offline
2008 Kawasaki Versys
Default
In my experience, synthetic oil lasts longer before shifting becomes a little more notchy than dino oil. With dino I would change oil more often (3k-4k miles) than I do with synthetic (5k+ miles).
If the synthetic oil still costs more per mile than dino, I will write off that difference to the peace of mind I get from the superior lubricating properties of synthetic vs dino.
YEMV.
Forum Jump
Advertisements
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
