The Science and Black Magic of Suspension Setup - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 07-09-2008, 10:53 PM
Gustavo Gustavo is offline
Default The Science and Black Magic of Suspension Setup
OK, there really isn't any black magic involved. No, really.
The suspensions main task, from a performance perspective is to keep the wheels in contact with the ground as much as possible and minimize the bike's movement, or at least keeping those movements under control. There are several adjustments when you are dealing with high quality suspensions (unfortunately, neither end on the Versys qualifies as such) and they all work together. Adjusting only one element is going to have limited effect.
First you have to understand what each component and adjustment does for your suspension:
Despite the common (mis)use in motorcycle language, preload does not affect spring stiffness, but you will see thousands of references to "making the suspension stiffer/softer" by changing preload. In reality, preload affects mainly at which point in the suspension travel you are in equilibrium (static or race sag, depending on whether you measure with/without the rider) and therefore, ride height. Setting the correct preload puts the suspension in it's optimal working range (too much preload and it tops out easily because you start very high on the suspension stroke; not enough preload and you are down towards the lower half of the suspension travel, making it easier to bottom out) but also puts more/less load on the front and rear, which means you have more/less weight acting on that particular spring. Unfortunately, colloquially, people refer to adding/removing preload as stiffening or softening the suspension, so many riders actually think that is a direct effect of adding or removing preload, instead of thinking of it as a suspension travel adjustment (and indirectly ride height).
Damping is what controls the spring movement. If there was no damping the bike would keep bouncing up and down uncontrollably (think old American cars...). Compression damping is what slows down the suspension movement as it compresses (yeah, I know, duh!) to absorb a bump. It can also be broken into low and high speed damping (referring to fork/shock movement, not actual vehicle speed). Low speed damping affects what happens most of the time when you ride on relatively good roads, the fork moves up and down at a low rate to deal with road changes. When you hit a sharp bump, the forks compress rapidly and that's when high speed damping comes into play. Sophisticated suspensions have a secondary circuit that opens when the pressure rises rapidly, making the fork/shock more compliant. Most OEM setups are not that sophisticated, so you have more oil trying to rush through the same orifices, resulting in a hydraulic lock of sort, creating harsh feeling suspension.
Rebound damping controls the shock/fork movement as it expands. Low rebound will allow the suspension to extend rapidly and create a lot of movement as the bike bounces back. Too much rebound will keep the fork/shock from fully extending fast enough to deal with the next road irregularity with the full suspension stroke. So, if you set rebound damping low, the bike will move around more, but it's not "softer" because rebound doesn't really affect what happens when you first hit a sharp bump, that's handles by the spring and compression damping.
It's important to note that when doing any suspension work, it's best to do one thing at a time, make one change and go out to test it. Use the same loop under the same conditions when testing. Take notes of the changes you make. This will make it easier to compare changes and also allow you to easily dial it back to the starting point if you don't like the result.
OK, great, but what do I do with all this information?
Using this information you can understand what happens when you set the sag and damping rates on your bike.
Measuring sag is simple, you'll need an assistant (two is better), a measuring tape (I always recommend a metric one, it's easier figure out the differences with decimal units) a note pad and a simple calculator (if you are not good doing math in your head).
Lets define some measurements:
L1 = Total suspension travel
L2 = Available travel
L3 = Rider Sag (L1-L2)
Total suspension travel is usually given in the bike's specs (for the Versys - 150mm), but the actual available distance from the bottom of the forks is a little longer than that - you can measure it by leaning the bike on the side stand and pulling until there is no load on the front wheel. Obviously, this requires at least two people for safety reasons (both yours and the bike's). If are measuring on your own, use the manufacturers specs plus 20mm. Note that there will be a small discrepancy between the measured full extension and the spec as there always is some slack in the fork when it's fully extended. If you are getting what seems like little sag, check the fully extended length of the lower fork.
If you have two assistants:
- Sit on the bike with your typical riding gear.
- Have one of the assistants hold the bike up so you can put both your feet on the pegs and sit in your normal riding position.
If like me, you have no friends, you can use a zip-tie loosely fastened around the fork lower to measure displacement. In that case, push the zip-tie all the way against the fork seal, carefully straighten the bike and sit on it taking care to not move the suspension up or down.
Try to balance for a second or two, again, taking care to not bounce the suspension up and down as you do so. I recommend you try this several times, as it takes a little practice to balance for more than an instant without needlessly moving the suspension. When you get off the bike, again, take care not to bounce the suspension around. You should see something like this:
- Measure how much the front suspension is compressed (easy to do directly on forks, you simply measure from the length of exposed inner tube from the dust seal to the top of the axle holder or from the zip-tie to the top of the axle holder). The difference between available travel (exposed length, L2) and the total travel (L1) is your sag.
- Measuring rear sag is similar, but can't be done directly due to the setup, so what we measure is the distance the rear axle travels and use that. In order to have meaningful measurements you need to get a baseline measurement that tell you the distance between some point on the rear axle (I often use the center or top of the axle nut) and some fixed point on the rear subframe, that is located vertically above that spot on the axle (when you are looking at the bike it's a lot simpler than it sounds). The bolting point for the passenger pegs to the subframe is close enough to vertical that you can use that, or any other spot on the rear subframe would work too, as long as you consistently use that same spot when you measure.
- An easy way to measure the fully extended length in the rear is pull the bike toward you when you are standing on the left side of the bike (with bike on side stand), until the rear wheel starts coming off the ground (of course, if you are measuring a bike that has a center stand, this is trivial, you just set it on the stand and the rear wheel is in the air). Measure the distance between your selected two spots. This is your L1*.
- Now sit on the bike again, have one of your assistants hold the bike up, put your feet on the pegs as you would while riding and have the second assistant measure the distance between those two spots again. This is L2*. The difference between L1* and L2* is your sag (Sag = L1*-L2*).
The range for sag on a Versys should be -
Front - 25%-33% compression (or 37.5-49.5mm out of a total of 150mm travel available)
Rear - 25%-35% compression (or 36-51mm out of a total of 145mm travel available)
If your measurements fall within this range and you are satisfied with how the bike feels, you are done (at least as far as preload is concerned). If your measurements are outside these ranges, you need to adjust preload and measure again. If you don't have enough compression, remove preload (forks - clockwise adds preload, counterclockwise removes it, rear shock - 1 is min preload, 7 max preload), if you have too much compression add more preload.
As I mentioned above, the initial sag setup are good starting points, but you can set it anywhere in that range and still have good suspension performance. Some people like their bikes to ride taller, others lower with more or less damping. I start at the middle of the range (useful to write down what settings you started with, so you can go back later if you don't like the changes you make over time) and usually go towards the upper end, i.e. less sag because I like to keep clearance at maximum.
Hope this helps, feel free to ask for clarifications if I lost you somewhere in the process...
Gustavo
Old 07-09-2008, 11:19 PM
08 Versys's Avatar
08 Versys 08 Versys is offline
Send a message via AIM to 08 Versys Send a message via Yahoo to 08 Versys
Default
This is a good reminder that I need to adjust mine. Thanks for the post.
__________________
Hear my custom exhaust, I am selling these for $135 complete including shipping!
http://forums.kawasakiversys.com/showthread.php?t=578
See my Driving Light Installation Tips
http://forums.kawasakiversys.com/showthread.php?t=747
  #3
Old 07-10-2008, 11:26 AM
AlexDz AlexDz is offline
Default
Yo, DMC51! Yeah, it was a great post--great enough for you to quote in its entirety I'm not so sure, but great nonetheless!
  #4
Old 07-10-2008, 09:00 PM
Docteric Docteric is offline
Default
Gustavo, Thanks for a great post. I've read half a dozen articles on suspension setting and never understood a bit of it. I think I finally understand enough to do some checking of mine. Now if I just had some friends to help ...
__________________
A diamond is just a hunk of coal
that didn't quit under pressure
  #5
Old 07-10-2008, 11:13 PM
dmc51 dmc51 is offline
Post Gustavo,s Post
Thanks again for your great post with the pictures, it seems
that I may have posted a comment about your post in the wrong
place or something. I certainly did,nt mean to. I quess I can mess
up anything sometimes. Just to let everyone know, I don,t know
anything about the V,s suspension and my hat is off to Gustavo.
A very knowledgeable person.
Trying to learn about this posting stuff and thanks for keeping me
straight.
My apologies
dmc51
  #6
Old 07-10-2008, 11:58 PM
Default
Thanks AlexDz
Thanks for pointing out my screw up. I was trying to complement Gustavo for
his great post. I did not mean to or try to duplicate it, my apologies. Once
I seen what I had done I got it off as fast as possible.
Thanks
dmc51
  #7
Old 07-11-2008, 10:11 AM
Default
DMC, thanks for the comments, I am glad it helped. While Alex has a point about trimming the replies, you can always just edit your post after you notice the issue, no need to delete the whole post either.
Gustavo
  #8
Old 01-17-2009, 03:51 PM
Chicken Little's Avatar
Chicken Little Chicken Little is offline
Default
Geez, what a great post. Crystal clear and everybody, even the friendless, can do it. Thanks!
  #9
Old 03-14-2009, 05:22 PM
thecreeper77's Avatar
thecreeper77 thecreeper77 is offline
2008 Kawasaki Versys
Default
Ok Iím dense...I looked at the service manual 13-9 and 13-20 about suspension. The default suspension settings on the bike are for a rider at 150 lbs.
So with those default settings how would you adjust to a rider at lets say 250 lbs....and a rider who is 250 and a passenger who is letís say 200?
__________________
08 Versys (Red)
Two Brothers Slip-On V.A.L.E.ô Exhaust
Two Brothers Juice Box
Arrow Headers
Motowerk Lowering kit w/Flatfoot
SW-MOTECH Crashbars/Engine Guards w/Hwy Pegs
SW-MOTECH mirror wideners
Rear Spool Sliders
~Comming soon~
Front Axel Sliders
Red LED Body Kit
1980 Kawi KZ1000 LTD
  #10
Old 03-14-2009, 07:13 PM
Default
Forget the factory settings, they are bogus (for the stated weight). I weigh about 150 lbs. and I get very little sag in the front at the factory settings. It's a bit better in the rear, but not by much. The guy who spec'ed the springs didn't talk to the guy who wrote the manual...
The best advise I can give you is to measure it. Sit on the bike and figure out how much sag you get front and rear - you can start at the factory settings if you wish. Add or remove preload to get you into the right range if it's not right and measure again. With a passenger (and a combined weight of 450, if I read it correctly) you are probably looking at max preload in the rear, maybe in the front too.
Hope this helps,
Gustavo
  #11
Old 03-28-2009, 12:04 AM
AlbertaJeff AlbertaJeff is offline
Default
Thanks Gustavo for the Thread. I found it very helpful. I'm 210 lbs and I have the rear pre-laod set on 6 and the front I have screwed in 9 turns. This sets me @ 26% on both front and rear. I went for a ride and am now just playing with the dampening. Any suggestions, I adjusted both min and max and haven't found the sweet spot yet.
  #12
Old 03-28-2009, 12:16 AM
Default
Jeff - damping is a lot harder to fine tune than sag, because it can't really be done on a static bike. You have to ride long enough in one setting to see how the bike behaves under different conditions you ride through regularly. You wont be able to set it up to handle everything brilliantly, the Versys doesn't have a wide or fine enough range of adjustment. I think you are doing the right thing - set it up at one extreme or the other and see what happens. Then make some changes and go out again.
Gustavo
__________________
  #13
Old 03-28-2009, 12:29 AM
Default
Thanks again, this was a great help and I'll pack a flat head screwdriver with me! Yes, there isn't much adjustment. 4 turns on the front and 15 on the back. Usually are the dampening adjustments the same for the front as the rear? Like both set at 30% or both set at 75%? Or are they going to be different? Like you said I suppose it will depend on the personal driving conditions and habits! Thanks again.
  #14
Old 03-28-2009, 02:27 PM
Default
Jeff - you don't have to setup both ends the same. It rarely actually works out to be a similar setting that works, since those are two very different components. Do one at a time so you can tell what the changes you've made feel like, otherwise you may end up mixing feedback from changes and wasting time trying to "fix" symptoms you think come from a change at one end, when in fact they root cause is at the other.
Gustavo
__________________
  #15
Old 08-13-2009, 12:10 AM
dbocz's Avatar
dbocz dbocz is offline
Default
Is that "in 9 turns" from the factory setting or 9 turns from all the way out?
Thanks to the information,,,
dbocz
  #16
Old 08-13-2009, 12:31 AM
Default
It is 9 turns from min pre-load (all the way out). The factory setting is 7 turns out (from max pre-load, or fully in) or measuring the way Jeff did, 8 turns in. But it's really meaningless, it's much better to measure the sag and set that as your starting point.
Gustavo
__________________
  #17
Old 08-14-2009, 09:59 PM
tim_brown tim_brown is offline
Default
I'm 210 lbs and set my rear preload to max and damping to max.
For city street riding and quick acceleration I think it feels better than the default middle position.
If the default preload is for 150 pounds and its' position is 5 then I figure 30 pounds per click up to a max of 210 pounds, so I'm set at 7 and max.
I did your test (alone too) and the default setting seems to sink in about an inch but I haven't adjusted it yet.
Does my reasoning for the rear adjustment make sense to you?
  #18
Old 08-14-2009, 11:26 PM
Default
Tim - Your reasoning would make sense, if the settings Kawasaki calls "standard" were correct for the advertised weight. But, having measured it, I know they are not. A 150 lbs. rider gets the correct rear sag in the second or third setting, not the fifth. Not sure I remember measuring someone who is 210, so the best way to set the baseline is taking the measurement of you (with your gear) on the bike.
Gustavo
__________________
  #19
Old 08-24-2009, 06:17 PM
Lcon2 Lcon2 is offline
Default Help with front measurement:
Excellent write up, but I can't seem to get my front shocks within the proper parameters. Maybe l am measuring from the wrong points, but using your photo it appears that the measurement to the top of the zip tie is roughly 135mm. Taking 150mm minus 135mm and I am left with 15mm - what am l doing wrong?
Thanks
  #20
Old 08-24-2009, 09:41 PM
Default
Lcon, I think the key is in this paragraph:
I just reworded it, because it seems I confused a few people with the original version. If you can't measure it, use a total length of 170 (based on measurements I did on several Versys, 170 seems to be fairly close to representative. It's better if you verify by measuring, though), not 150. So when you say you measured 135 exposed inner fork leg, it means you could have as much as 35mm of sag, not 15 as it seems by using the total travel as the overall available length.
Hope this helps,
Gustavo
__________________
Tags
forks, preload adjustment, sag, springs, suspension settings
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Suspension Tuning xcbikeman Technical Discussion 5 05-29-2011 07:00 PM
Passion Red or Carbon Fiber Hugger w/ Black Body Panels and Black Wheels??? WillieFlo Modifications - Cosmetic 18 04-07-2010 02:10 PM
Suspension Setup dstarman Technical Discussion 1 02-25-2010 08:41 PM
Suspension help tapntx Technical Discussion 10 11-05-2008 04:35 PM
2 Up Suspension settings Nexxus General Kawasaki Versys Discussions 0 05-07-2008 08:16 AM
Advertisements
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
