How much metal in used oil is normal? - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 12-26-2012, 06:42 PM
trashysquid's Avatar
trashysquid trashysquid is offline
Default How much metal in used oil is normal?
An awkward sounding question, but I ask since I saw a small amount of fine metal shavings (about .5mm or less) on the magnetic oil plug I got for my V while changing the oil today. 5K miles on the clock for a crate 2009.
Also wondering if I should change the coolant since the bike is three years old even though it's low miles, and debating whether or not to buy a Therm-o-Bob since I ride no matter what (it's finally cold in south Texas now)...thanks.
Old 12-26-2012, 06:47 PM
MTS MTS is offline
Default
My two cents! Metal shavings in first 10k is ok. These bikes are tight!
Stock load antifreeze is really good! Change per manual!
Thermobob! Yes!
__________________
  #3
Old 12-26-2012, 06:58 PM
Fastoman Fastoman is online now
2009 Kawasaki Versysy
Default
At 5K you should not get metal in oil. Keep monitoring &
  #4
Old 12-26-2012, 10:24 PM
ScottyNeal ScottyNeal is offline
Default
I got a small amount of metal filings on my magnetic drain plug up to 10,000 miles. Nothing much after that. I still get various kinds of small debris in the drained oil, and I'm nearing 20,000 miles; and the bike is continues to run great.
  #5
Old 12-26-2012, 10:26 PM
invader invader is offline
Default
So it's the second oil change? What mileage was the first one at?
Bike and coolant are now just over 4 years old. Manufacturing month and year is on VIN sticker. The original coolant is not usually long-life, so it is due.
  #6
Old 12-27-2012, 02:04 AM
fdale's Avatar
fdale fdale is offline
2010 Kawasaki Versys
Default
The coolant does not break down, but the additive package it contains does. So a good rule of thumb is every 2 years.
Brake fluid is hygroscopic and so should be changed because it will absorb water - takes it from the air - so I do mine at the same time as antifreeze.
Engine oil every 5000 Km
  #7
Old 12-27-2012, 05:47 AM
David RSparky3 David RSparky3 is offline
Default
If you change the oil when its HOT, it helps get the stuff out from initial running.
First oil change I get a whole bunch of junk.
A little in the second, then almost none after that.
Second oil change for me is 1,000 miles.
David
  #8
Old 12-27-2012, 04:19 PM
Default
This is oil change #4 (400, 2000, 3347, 4947). I change it when the oil gets really dark in the sight glass. Might seem excessive, but I like working on the bike. I'm also running Shell Rotella-T 15-40. Also noticed that my local Wally-world quit carrying the ST7317 (longer) filters, so I might have to go online now.....
Forum Jump
Advertisements
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
