finally got the Signet Q....but! - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > Rider's Gear
Thread Tools Display Modes
  #1
Old 12-13-2012, 08:25 AM
Purificator's Avatar
Purificator Purificator is offline
Default finally got the Signet Q....but!
Hi All,
I shared my deception about my head shape and how I struggled getting an appropriate helmet...(please see : http://www.kawasakiversys.com/forums...ad.php?t=21571 and http://www.kawasakiversys.com/forums...ad.php?t=21525).
as per the recommendations of the fellow in this forum, I orderd an Arai Signet Q that I have just received this morning (after a very long 4 days of delay in shipping...)
I crossed my fingers and then tried it.....WOOOOOOOOOOOOOW!!!! that has really nothing to do the those that I tried before! (CMS, Scorpion, Shark and HJC), it feels solid, and fitls like a glove!!
BUT!!!!
I ordered an XL but it seems that it is a little bit big (although I used the size chart of Arai)...it is just a little loose, it does not snug like I would have imagined....what I did now is that I have put a piece of tiny fabric (about 3 mm tick) around my head and wore the helmet over it........BINGO!!!!! the fit was JUST PERFECT DE PEFECTO!!!!
NOW!!!
obviously I can't go down to L size...because I ordered it from abroad (USA) and the cost of return shipping is very high...and I'm not sure if L size will fit since it is almost 1.5 cm smaller according to the size chart (that I don't trust anymore!)...
so what do you recommend me guys? here are the options:
1- put a 3 mm sponge (same quality as the one used in the liner) directly inside the shell (after I make wholes on the sponge that match those in the shell for vents and those where the liner is fixed) and use 2 or 3 spots of glue to firm it up...I know people will say using a glue that contains chemicals might compromise the safety of the helmet but I will see the best way to fix it...
2- wear a cap....but where I live it is almost 25 degree all the year so I guess it will overheat my head...
3- get the liner of the L size....I red somewhere on internet that you can downsize from XL to L by using the liner of L because most of the companies (including Arai) are using the same shell for L and XL...
Any suggestion or recommendation?
I'm attaching some pics so you can see the fit...
Thanks a lot!
ID:	16368   Click image for larger version
Old 12-13-2012, 09:36 AM
prim8 prim8 is offline
Default
I don't really have a recommendation other than if you're afraid of the glue to try using hot glue.
There shouldn't really be vapors to speak of and there's a ton of uses for hot glue so it's good to have.
  #3
Old 12-13-2012, 11:29 AM
Sprocket's Avatar
Sprocket Sprocket is offline
2010 Kawasaki Versys
Default
Originally Posted by Purificator View Post
Hi All,
BUT!!!!
NOW!!!
Thanks a lot!
When you paying that much for a helemt exchange it. It will be worth it in the long run. Also the padding will pack down over time making it even looser. Also suggest ordering a dark smoke visor for those sunny days. I love my Aria. You should not have enough room to squeeze in the tip of you baby finger between your forehead and the helmet or at the back of the helmet behind your neck.
  #4
Old 12-13-2012, 11:46 AM
Default
I paid only 250 USD for my like new Signet Q XL...I can return it for refund but it will cost me 230 USD to ship it back to USA and they don't have L for an exchange...
here are the picture of the fit tests:
1- side twist: looks good to me
2- chin pushed up: almost good
3- fingers do not go under my forhead
4- ONLY the flip from back to front that caused all the worries I have so far...
ID:	16370   Click image for larger version
ID:	16371   Click image for larger version
  #5
Old 12-13-2012, 01:28 PM
Stud Muffin's Avatar
Stud Muffin Stud Muffin is offline
Default
Head shape is important. I bought a Shoei RF-1100 that by the measurements was my size. However when I got it, the cheek pads were way too tight. I'm not sure if they are available for your lid, but Shoei had pads +/- 2mm in a few incremental sizes above and below my size. I got the next size thinner from stock and all is good. Except, the head shape thing. My nose just touches the chin guard. Yes I have a large beak but I didn't consider that when judging my head shape. I may have to go to an AGV as they look a little longer in the shnozz area.....
  #6
Old 12-13-2012, 01:39 PM
Default
the one I got is based on my head shape. the fact that the helmet moves from back to front that much (3rd photo) means that the helmet is a bit too long oval...
there is crown and cheek pads for this Signet Q...the default size is 7mm...and the biggest size I can customize is 12mm...I doubt it it will make a difference....again the big issue is how the helmet moves from back to front making the forehead covering almost my eyes....I might try the sponge as ultimate solution to see how it goes...
  #7
Old 12-13-2012, 01:58 PM
Default
I'd suggest adding that 3mm foam here-and-there, bit-by-bit, and see how it works out. I would personally be very leery of gluing it with hot glue - it MIGHT melt into your foam damaging it; and it MIGHT leave a high point that will hurt and drive you nuts!
__________________
  #8
Old 12-13-2012, 02:04 PM
Default
I will not glue it without making sure first that it works and fits perfectly...then the glue is a whole different story...I dont' want to buy the crown pad of 12 mm (5mm more that the standard 7mm) and I'm afraid that it might not work and I end up spending more and more...
  #9
Old 12-14-2012, 01:59 AM
Default
Good morning everyone!
ok so today I received the Evo Tech radiator guard (no worries it is not )
when I opened the box I saw this: (phone 1)
after that I was like hummmmmmmmmm .... tarrraaaan!!
so I started cuting it (see photo 2)...I guess you know what it looks like
so I have put some on the comfort liner on the sides and of course inside the cheek pads...
result: MUCH MORE FIT ! after 20min sitting in front of the TV to feel is something is wrong and guess what: FELT LIKE OEM FIT! :P
NO GLUE NO change whatsoever to the shape of the helmet or otherwise, just a tender sponge added to the areas where there is already a sponge...
Cost : 0.00 USD
But!
I have put some on the back of the comfort liner to reduce the roll off movement...it did work! but after 15 min I started filling a pressure on that spot
However, that was because I cut a small piece so that I felt the difference around the same area of the back of my head...I will cut a bigger piece and see how it feels
once I finish with all the tests, then I will have a dedicated shop to use the EXACT same sponge (cut with the same precision) on the cheek pads and the sides of the comfort liner :P
ID:	16376   Click image for larger version
ID:	16377   Click image for larger version
ID:	16378   Click image for larger version
  #10
Old 12-14-2012, 09:39 AM
Sprocket's Avatar
Default
Were can I buy an Arai for $250?
  #11
Old 01-08-2013, 02:29 AM
Default
Hello again,
it has been a while...I ended up selling the Arai at cost...I bought the Bell RS-1 and I'm also about to return it....the problem with the latter is that fitted all the way good except the roll off test...the back of my head is smaller so that helmet was not firm and rather there was a play from the back to the forehead when trying to roll it off...
my head shape is a reverse egg and no online store has an idea about which helmet will fit my extraterrestrial head...I spent too much time on internet looking for an appropriate one but I couldn't find anyone who has a reverse egg shape...good that I lost only about 50 USD in the whole thing so far...I will wait until I travel for the company somewhere (may be Dubai or UK) and try helmets there...
Sprocket: I bought it on amazon, sometimes there are good deals over there...
  #12
Old 01-08-2013, 03:27 AM
crow's Avatar
crow crow is offline
2007 Kawasaki 650 Versys
Default
Never buy a helmet you haven't tried on full stop... Top brands Arai and Shoei are world apart in fit and feel .. be it try in store then buy OS whatever...
I did with my Arai dualsport.. tried here bought US- what ever the model its called relative to the country XD3??? I saved $270 buying US but I knew from trying them all on that the Shoei Hornet was very not for me though the Arai's were always a better fit for me....
They are all very, very different in fit with different Shells and Skins to start, inner Liners, ear cut outs, or none GRRR... from the cheaper brands to the most expensive...all with specific comfort values depending only on the head involved including Visor's and release systems etc.
The only way top be sure what really works is try one one in the right size. You ears alone are in a different relationship to your head compared to mine let alone your cheeks and chin.. Never buy a second hand one even if you are sure it's the right size for you and you love... someone else's head had shaped it already and it won't be the same fit especially if he had a bigger head and ruined the fit trying to stuff his Mellon in it...
Arai and Shoei for an example of top line helmets spend millions of $$$ in wind tunnel R&D alone let alone researching the demographic of their targeted customers needs in design and features..
Why do people only prefer the fit of an Arai over Shoei?? Its not coincidental.
Spoken from experience. Arai for on-road.. Thor for off-road... always has been and has nothing to do with the fashion trend of bikes and gear...Sidi boots fit me better Than Alpine Stars but thats just my narrow foot.
  #13
Old 01-08-2013, 04:48 AM
Default
Thanks...
I never touched a used helmet...and I will never do it...
I also know that you need to try a helmet first before buying it...just that when you live in a country where such brands do not exist and you have a bike waiting for you...you do try the online ...it is a hit or miss...for some people it worked very well, for others it did not...life...
  #14
Old 01-08-2013, 08:59 AM
oxman's Avatar
oxman oxman is offline
Default helmets
Im just in the process of getting an arai and i just came from a show where i was measured and fit by the Arai rep .. Well all my helmets of past have been Med size and i have tried med at the dealers and thought thats where i was going to be again . Well after the custom fit im now in a small Siginet -Q . what a nice snug fit
__________________
  #15
Old 01-08-2013, 09:02 AM
Default
you are lucky :P
and yes it is true as on this video
it says that the signet Q came a full size below the "standard" Arai size chart...
enjoy!
  #16
Old 01-08-2013, 10:20 AM
Thumper's Avatar
Thumper Thumper is offline
Default
Polyfil bought at Walmart and used in pillows might work better than foam. It does not retain heat as much and does a good job of holding up to sweat over time. It also has layers that can be seperated easily for a custom fit. I have used it before and it worked for me.
__________________
IBA #23562
http://www.youtube.com/user/Thump52
  #17
Old 01-09-2013, 06:53 AM
crow's Avatar
Default
Thanks...
Sorry mate I didn't mean any offence to you... you are doing it tough there if they charge that much to post back to the US and won't stock Arai's..
  #18
Old 01-10-2013, 08:21 PM
Default
I picked up a couple of AGV helmets this summer, so I've been riding here in AZ with one for the last month or so, instead of the KBC modular I'd been using.
REALLY like this helmet (S-4). Light, warm, GREAT airflow for ventilation.
__________________
Forum Jump
Advertisements
