Cold helmet warning - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > Rider's Gear
Thread Tools Display Modes
  #1
Old 12-07-2012, 03:28 PM
ray h ray h is offline
Default Cold helmet warning
Well I broke my AFX140 modular yesterday morning. I left it in the garage Wednesday night (26 degrees f) for some reason, usually I bring it inside the house with me. I went to put it on yesterday morning and snapped the plastic trim pieces along the botom edge of the helmet. I was wearing a neck warmer so I've been spreading the bottom of the helmet to get it on over that, I've put it on 100 times the very same way before but this time the helmet was 26f and the plastic was super brittle.
The AFX was my winter helmet because the anti-fog shield actually works and it does a much better job of not fogging then my HJC CL-MaxII does.
It's been a bad helmet year for me, I dropped my Bell earlier this year and it landed right on one of the vents and broke it off so I replaced it with the AFX, now I break the AFX putting it on (it's probably not even 6 months old). I couldn't bring myself to buy another one this year so the HJC will be my new winter helmet. I can't put up with the fogging though so I did buy myself a Xmas present, I just installed a pinlock shield. Rather expensive ($58 for shield and insert) but it was cheaper than a new helmet.
If your helmet has any plastic parts, do yourself a favor and keep it warm.
Old 12-07-2012, 06:27 PM
twowheeladdict twowheeladdict is offline
Default
Makes you wonder what would happen if you hit the pavement while riding to work.
__________________
My Kawasaki's
  #3
Old 12-07-2012, 07:03 PM
Default
I know, I thought the same thing. I'm sure the plastic parts are very brittle on my way to and from work at that temp.
The only comforting thing is that I would consider the plastic trim pieces to be non structural, I don't think the integrety of the helmet is compromised much if any but I would definately have plastic pieces flying everywhere if I were to hit the pavement hard.
  #4
Old 12-07-2012, 09:47 PM
twowheels twowheels is offline
Default
I've replaced plastic parts on my Arai on two separate occasions. They break at pretty much any temperature if you drop your helmet on a hard surface. They supply the parts free of charge. Other brands such as Scorpion, HJC, Bell, etc. supply the parts but may charge a nominal amount for them. No need to replace a helmet just because of a broken plastic vent or other minor issue, these are easily replaceable. Dropping an empty helmet from just a few feet is not going to compromise it's integrity. In most cases you will need to contact the warranty service provider directly rather than the store though to buy parts.
__________________
My goal is to live forever, so far so good.
  #5
Old 12-07-2012, 10:09 PM
genehil's Avatar
genehil genehil is online now
Kawasaki 2011 Versys
Default
Ahhhh... Florida.
__________________
GeneHil - Panama City, FL
2011 Kawasaki Versys
Vietnam: Dec67-Dec68 & Jul69-Dec72
  #6
Old 12-07-2012, 11:50 PM
Mursili's Avatar
Mursili Mursili is offline
Default
It does make me think about the response of the foam in the helmet at low temperatures. I assume that both the DOT and Snell do not specify a low temperature for testing.
Either way it would seem that the foam will not be so brittle as the plastic housing, but it may behave differently than the tests that show that your brain will not be injured...
__________________
When it comes to havoc, no one wreaks like me! - Dr. Heinz Doofenshmirtz
I will never be good and that's not bad.
  #7
Old 12-10-2012, 08:53 PM
HAWKSHOT99 HAWKSHOT99 is offline
Default
Snowmobile helmets are the same thing as a motorcycle helmet. Also my ski helmet uses the same foam as my motorcycle helmets.
__________________
08' Versys
  #8
Old 12-11-2012, 12:45 PM
Default
...PLUS, the heat from your head will warm up the foam....
__________________
  #9
Old 12-13-2012, 10:07 PM
Tech-Diver's Avatar
Tech-Diver Tech-Diver is offline
2010 Kawasaki Versys
Default
Pinlock system is worth double the price for the increased safety, decreased hassle, and the comfort factor...
  #10
Old 12-14-2012, 07:17 AM
Thumper's Avatar
Thumper Thumper is offline
Default
Originally Posted by genehil View Post
Ahhhh... Florida.
Shhhhh, already too many people now!
__________________
IBA #23562
http://www.youtube.com/user/Thump52
Forum Jump
Advertisements
