Second post ... advice needed - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Member's Lounge > Member Introductions
Thread Tools Display Modes
  #1
Old 12-07-2012, 09:34 AM
jadeinplay jadeinplay is offline
Default Second post ... advice needed
hi, unfortunately I cannot post outside this forum, so my question goes out ...
I have seen that there are after market handlebar raisers and those that absorb the vibration too.
Is this a viable option? When I first got my Versys I hardly felt any vibration, now I feel it on my hands, seat and feet ... ! Is this standard on a Versys? My ER6 also had the vibrations ... maybe it is just our &*(*& roads here?!
Old 12-07-2012, 09:58 AM
goat12's Avatar
goat12 goat12 is online now
Default
The mainstay of the vibration on the Versys seems to come from the parallel twin engine configuration. Speedy makes a nice anti-vibe riser:
http://www.shop.motowerk.com/Anti-vi...ANVB-HB-RS.htm
__________________
2011 Versys
Sw Motech crash bars, Loobman chain oiler
Sw Motech Pelican im2600 removable rear case/alurack
EP radiator guard, FendaExtenda, Xena XX14
Zeta Armor hand guards, XC led turn signal covers
Motowerks flatfoot, Motowerks peg lowering kit
Kryptonite NewYork Noose,Kryptonite New York Legend
Venhill SS brake lines, Backoff XP brakelight modulator
Tapp-Lite usb charging port, Osram Hyper 65w bulbs
Michelin Pilot Road 2 tires
  #3
Old 12-07-2012, 02:28 PM
Sprocket's Avatar
Sprocket Sprocket is offline
2010 Kawasaki Versys
Default
If you have excessive vibration do a throttle body sync. It will reduce vibration. Should be done annually anyway.
  #4
Old 12-10-2012, 09:49 AM
Default
Thanks guys ...
Question ... what is a throttle body sync - never heard of it before?
  #5
Old 12-10-2012, 10:33 AM
CanadianFZ6's Avatar
CanadianFZ6 CanadianFZ6 is offline
Default
Originally Posted by jadeinplay View Post
Thanks guys ...
You must be new to motorcycles (or at least multi cylinder ones).... Multi cylinder motorcycle engines since the dawn of time need a carb sync and now the more modern throttle body sync (fuel injection) once in a while... Unlike a car that uses a central throttle body, motorcycles uses one for each cylinder... From time to time these individual throttle bodies/carbs need adjustment so that they are supplying the same ratio of fuel/air ratio as each other.... Hence "balancing" the throttle body term is used to describle this process... The process is described in the routine maintenance section of your manual...
__________________
'10 Versys (Black) ***SOLD***
'09 Yamaha FZ6 (Blue)
Forum Jump
Advertisements
