What size valve stems? - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 12-03-2012, 03:31 PM
Jeff S's Avatar
Jeff S Jeff S is offline
Default What size valve stems?
I'm sick of dealing with the stems on this bike - it's nearly impossbile for me to reach it with my compressor and tough even to just check the pressure. I'm about to replace the tires, and want to put on 90 degree valve stems. But, in ordering them, there are 8mm, 10mm and 11mm valve options. Which does the Versys take? It's not in the service manual (that I can see anywhere...).
__________________
Cheers, Jeff
Two Weeks in the West | Palo Duro | One Week Denver Loop
2010 Versys
SW-Motech crash bars & bash plate
SW-Motech quick lock rear rack
Two seahorse 720 cases / panniers
Givi wind screen
Old 12-03-2012, 03:56 PM
cuff's Avatar
cuff cuff is offline
2007 Kawasaki
Default
Not sure but can you measure? I would guess 10mm. If it's 8 you could open up the hole. If it's 11 I'm sure the 1mm wouldn't matter much with a threaded stem.
__________________
Falling down is your bodies way of saying you just screwed up.
IBA# 38547
  #3
Old 12-03-2012, 03:58 PM
Jeff S's Avatar
Default
Yeah - I could measure, but that'll require removing the current valve stems, which means pulling off the tires, and I want to replace the tires and stems at the same time. Seems 10mm is the most popular, some valve stems are only offered in that size...
__________________
Cheers, Jeff
2010 Versys
Givi wind screen
  #4
Old 12-03-2012, 06:05 PM
Default
Get EACH size, then return for credit the ones you don't need.
__________________
  #5
Old 12-03-2012, 07:47 PM
invader invader is offline
Default
11.3 mm
  #6
ultra ultra is offline
Default
11mm
  #7
Old 12-03-2012, 07:58 PM
Default
11.3 mm
  #8
Old 12-03-2012, 08:30 PM
Default
I think we answered the exact same time, but invader is correct of course.
Forum Jump
Advertisements
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
