DIY Molded Ear Plugs? - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > General Kawasaki Versys Discussions
General Kawasaki Versys Discussions For discussions on anything and everything related to the Kawasaki Versys.
Thread Tools Display Modes
  #1
Old 11-28-2012, 12:06 PM
Slow-Steady Slow-Steady is offline
Default DIY Molded Ear Plugs?
I did a quick search and came up with several threads about ear plugs, but I waned to get some more feedback on the DIY molded ones. I use the cheap foam ones now and I'm considering getting/making a set of molded ones.
What brands have you guys used, and how do you like them? It looks like Radians seems to be common brand on the net.
How long do they last if you wash them regularly?
Anyone tried molding in ear buds for music?
I have also read that it may be worth it to contact my local hearing aid place and see if they make molded ear plugs, anyone else go that route?
Thanks,
Mitch
Old 11-28-2012, 01:01 PM
MTS MTS is offline
Default
I use the foam ones. Just wonder how good the others are?
The foam ones are very effective!
Sorry not much help but, there is a pretty long thread on this, and all kinds of them!
__________________
  #3
Old 11-28-2012, 01:03 PM
BLACK DOG's Avatar
BLACK DOG BLACK DOG is online now
Default
I've tried & sort of failed on the diy route
Currently use ear-pro sonic defenders
I will eventually end up with custom made plugs
I've seen custom mades with drivers molded in but feel isolated when I have any earbuds drowning out the voices
steve
  #4
Old 11-28-2012, 01:17 PM
PSORngr PSORngr is offline
Default
I have a pair of molded ear plugs. I got them done at the international motorcycle show when they came into town at the beginning of the month. I really like them so far. I may be a bit used to this type of thing though since I had molded ear plugs as a kid for the pool (I had major ear problems as a kid).
I had mine made by a local guy that's been doing it for years. Supposedly they should last for up to 10 years. A variation with sound drivers were available, but they are really expensive. I paid $60ish for mine. The music playing ones were something like $300-$400.
I'd also recommend asking a hearing aid place. Might be able to use some insurance if you go through them.
  #5
Old 11-28-2012, 02:49 PM
Default
Thanks PSORngr. I was planning on going to the international motorcycle show in Minneapolis, MN in January.
I think I will check out my local hearing aid place and if I come up dry there, I can just plan on getting them at the show.
BlackDog, you do make a valid point about the voices.
Mitch
  #6
Old 11-28-2012, 08:19 PM
Sprocket's Avatar
Sprocket Sprocket is offline
2010 Kawasaki Versys
Default
The memory foam ones mold to your ear when you insert them. Just scrunch up by rolling between yoru fingers, insert in ear, and let them expand to fill the ear canal.
  #7
Old 11-29-2012, 12:21 AM
kimel's Avatar
kimel kimel is offline
Default
If your health plan covers hearing aids it will probably cover professionally made silicone plugs. My last set cost me $7. The set before that, $6. Go see a good audiologist and have them done right. Your hearing is too precious to waste. I lost hearing in one ear and recently had it restored. You done realize what hearing in stereo is worth.
__________________
2009 Kawasaki Versys
SWM Engine Guard; Givi Windscreen on a MadStad bracket; Motowerk Peg Lowering kit & Stand Big Foot; ProTaper ATV Low bars; Stebel horn; KTM Duals Rear Rack...and more to come
  #8
Old 11-29-2012, 02:22 AM
kiwitourer kiwitourer is offline
2007 Kawasaki Versys 650 2007
Default
I use the Earmould brand. Thick liquid silicone pumped into your ears and sets. I use them for clay bird shooting and motorcycling. Excellent. I had my first set made in 2003 and still going strong. At a shooting event they are fitted numerous times during the day. The agent who made them, makes them with ear phones fitted. Great idea. Easy to clean, durable.
Easiest way to clean them is to suck the wax of when you moisten them before fitting. Tasty. Check out shooting suppliers. There will be agents right throughout the country. You could even become an agent yourself. Easy to do. Hope this helps
  #9
Old 11-29-2012, 08:30 AM
Newsshooter Newsshooter is offline
Default
I've used the radians, they work fine, I've also gotten them made at the motorcycle show, more colors and a bit softer and more comfortable than the radians. And lastly I got a set done by an audiologist. Any place that does hearing aids will be able to do them. They will do the same thing as what you get at the motorcycle shows, then those molds are sent out to make the ear plugs. The roll up foam and silicon plugs always seem to fall out of one ear when putting on a helmet. The custom plugs don't do that and will last a long time. I have 1/2 a set that is over ten years old, the other half is now a radian's plug I did myself.
  #10
Old 11-29-2012, 11:42 AM
Default
My wife and I each had a set professionally made (around $50 per set), mine for on the V, hers for my snoring.
My set are uncomfortable under my helmet, and BOTH of us just use the foam plugs that are good for 33 decibles now, so $100 wasted...!
__________________
  #11
Old 11-29-2012, 01:57 PM
Default
This has me thinking that maybe I should try a cheap pair of the DIY Radians for about $15. That way I can try them under my helmet and even just wear them around the house to see how the long term comfort it.
If I'm happy with them I'll just keep them, or look at a better professionally made pair. If I don't like them, at least I will not have wasted money on a expensive custom set.
Mitch
  #12
Old 11-29-2012, 08:30 PM
Default
When you get a set made to fit under your helmet, tell then not to have the silicon protruding to far out of your ear. That's what I did and they work fine.
  #13
Old 11-29-2012, 10:38 PM
andrewhtf's Avatar
andrewhtf andrewhtf is offline
Default
This hardly contribute to the thread, but just for sharing, I am using foam type earplugs. Doesnt seal out the noise totally, sufficient to muffle a major part of noise. Just what i wanted since total deafness is not what i want while riding. With the exhaust blaring and wind noise singing around the helmet, i dont want to listen to music.
I wear a balaclava hence has no issue with foams falling out while putting on helmet.
__________________
Current : Maroon 2011.
- Front Fender Extender - Radiator Guard - 19mm Nissin radial master pump - Nissin 4-pot caliper - SS Brake lines - Osram Nightbreakers H7 - LED 30w spotlights & 3w DRLs - Rear Hugger - Givi crash guards - Yoshimura TRC Carbon - Dynojet PC5 - Scottoiler - R1 shock with Ohlins 14.2 kg/mm spring - Imitation Givi Windshield - Rear Givi rack with 35ltr Givi top box - Bosch dual tones.
Up next :
- Osram Hyper Rallye 65W high beam - Protaper SE ATV Low - Handguards
  #14
Old 11-29-2012, 11:33 PM
genehil's Avatar
genehil genehil is offline
Kawasaki 2011 Versys
Default
I like the foam plugs... Cheap to buy and I don't have to keep track of them. I have a stash of ten or twelve under the seat and never have to worry much about misplacing any... And I've found they work well for me - noise wise.
__________________
GeneHil - Panama City, FL
2011 Kawasaki Versys
  #15
Old 11-30-2012, 07:17 AM
offcamber's Avatar
offcamber offcamber is offline
Default
I tried the do-it yourself ones and frankly I wasn't really happy. They didn't seem to work as well as the foam ones. Foam earplugs are cheap and disposable. More sanitary then reusable plugs. Just my 2 cents of course YMMV
__________________
" I don't care about shinny chrome or loud exhaust, I don't ride to be seen, I ride because I want to disappear"
Halfthrottle
  #16
Old 11-30-2012, 07:36 AM
BLACK DOG's Avatar
Default
an added bonus of the disposables is that some have a connecting cord
with those I don't have to worry about pushing them too far in and losing them in the void between my ears
  #17
Old 11-30-2012, 09:19 AM
Lours_Polaire's Avatar
Lours_Polaire Lours_Polaire is online now
Default
LOP
  #18
Old 12-01-2012, 12:24 AM
davidg davidg is offline
Default
I tried the guys who make the custom ear plugs at the Progressive International Motorcycle Shows. One advantage of those guys is if the plugs don't work for you, you get a quick and full refund. At least I did.
People have widely varying ear canal shapes. If the roll up kind don't work well for you, there's some chance molded ones won't also. I don't know if a good audiologist might do better than the guys I tried. I know the custom ear plugs at the motorcycle show work for a lot of people. And they do custom ear buds too.
What worked for me was this no-roll ear plug sampler kit, which lead me to Leight Pilot ear plugs. Best plug evah. For me. YMMV.
  #19
Old 12-01-2012, 09:04 AM
skatefriday skatefriday is offline
Default
I have custom made plugs from an audiologist and I love them. I can't wear foam plugs, but the custom silicon are almost like having nothing in the ear and clean up easily. I have however, never worn them under my helmet. (I don't find cruising around town on the V to be all that loud).
  #20
Old 12-01-2012, 09:07 AM
Capn Kirk Capn Kirk is offline
Default
I bought a set at Gander Mountain that I use both for shooting and riding. It comes as a 2 part putty. You mix the 2 parts together and push it into your ear and it cures in about 10 minutes. then you pull them out and let them sit and finish curing.
I use mine when I mow, shoot (under my muffs), and ride. Highly recommend trying a set to see if they work for you. Mine are much more comfortable than the foam type.
http://www.gandermountain.com/modper...Plugs&i=415810
Forum Jump
Advertisements
