Front tire wear - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 11-27-2012, 02:09 PM
twowheels twowheels is offline
Default Front tire wear
When I replaced my front Michelin PR2 this spring the tire was down to the wear bars but the rear still had some life. Ended up replacing the rear 3 months later due to a flat.
It seems to be the same senario again, this time with the Pirelli Scorpions. Just noticed today my front tire is approaching the wear bars on a few spots on the left while the rear looks almost new. Guess I make more left hand turns. The front wearing faster than the rear seems unusual but I think common to this bike. Anyone else notice this?
Little disappointed in the quick wear of the Scorpions (7000km/4400mi), think I will replace them with Micheline PR3s unless someone can suggest another long wearing tire.
__________________
My goal is to live forever, so far so good.
Old 11-27-2012, 07:18 PM
motociclista's Avatar
motociclista motociclista is offline
Default
I have never had a front tire wear out faster than the rear tire, on the Versys or any other motorcycle I've owned.
Are you doing a stoppie at every traffic light and stop sign?
__________________
Visit www.theridesofar.com to learn more about my book, The Ride So Far: Tales from a Motorcycling Life, published by Whitehorse Press. Read a sample chapter of the book or check out the blog.
  #3
Old 11-27-2012, 10:23 PM
RockyMoto's Avatar
RockyMoto RockyMoto is offline
2009 Kawasaki Versys
Default
As Motociclista says...I HAD never had a front tire wear out faster than the rear tire before on any bike I have ever owned...this with 30 years riding experience and close to 350,000 miles under my belt. A lot of the time, I have even been able to get two rears for every front on other bikes.
When my stock front tire wore out before the rear (front was shot, rear had 2,000-2,500 miles left) on my brand new V, I assumed it was just crappy tires. When my second set ('Stone BTO-23's) did the same thing, I was convinced there was a problem with the suspension or set-up--despite the bike handling flawlessly. Since then I have tweaked every suspension/chassis adjustment I can think of (sometimes screwing up the handling in the process) to no avail--my front tire is always worn out first on the V. I get "cupping" on the sides of the front before the rear shows wear, eventually the tread on the sides just gets bald while there is still tread in the center. I am closing in on 40K miles on the V and have gone through 6 or 7 sets of tires and the same thing happens every time, regardless of tire brand (some--the BTO-23 and Conti Motion) seem "better," but it is always the front that goes first on this bike for me.
__________________
Ride to live, live to ride.
2010 Yamaha YZ 250F
2008 Honda CRF 450
2006 Honda CR 250R
I've owned a Maico.
  #4
Old 11-27-2012, 10:34 PM
davidg davidg is offline
Default
Pretty sure your mileage will vary: I've never worn out a front first before.
I got about 12k miles from my previous Metzeler Z8 rear. 14.5k miles and still going on the Z8 front.
What tire pressures have you been using?
  #5
Old 11-28-2012, 07:51 AM
Kawa007's Avatar
Kawa007 Kawa007 is online now
Default
I also usually change 2 rear tires for one front tire. And the last 10+ sets I bought were Michelin PR2 (just love em!). The only exception is on my MT-01. Both rear and front have worn down at the same pace. On the Versys with my K73 Heidenau tires, the rear is like 50% worn and the front is like new.
  #6
Old 11-28-2012, 08:16 AM
andrewhtf's Avatar
andrewhtf andrewhtf is offline
Default
Dont the metz z8 rear came with only 150 while the verysy stock is a 160 tyre?
__________________
Current : Maroon 2011.
- Front Fender Extender - Radiator Guard - 19mm Nissin radial master pump - Nissin 4-pot caliper - SS Brake lines - Osram Nightbreakers H7 - LED 30w spotlights & 3w DRLs - Rear Hugger - Givi crash guards - Yoshimura TRC Carbon - Dynojet PC5 - Scottoiler - R1 shock with Ohlins 14.2 kg/mm spring - Imitation Givi Windshield - Rear Givi rack with 35ltr Givi top box - Bosch dual tones.
Up next :
- Osram Hyper Rallye 65W high beam - Protaper SE ATV Low - Handguards
  #7
Old 11-28-2012, 09:26 AM
Default
The Z8 rear is stock 160 size
  #8
Old 11-29-2012, 06:00 PM
Mursili's Avatar
Mursili Mursili is offline
Default
I have found with my Versys that I wore out the front tire at the same rate (or a little faster) than the rear tire if I was riding up in the mountains here more with a lot of twisties. The more straight highway riding that I do the longer the rear lasts with respect to the front.
__________________
When it comes to havoc, no one wreaks like me! - Dr. Heinz Doofenshmirtz
I will never be good and that's not bad.
  #9
Old 11-30-2012, 08:18 PM
Question
There is something going on here, but damned if I know what.
__________________
  #10
Old 12-01-2012, 09:37 PM
Default
twowheels - this is a serious question: how much do you weigh? Do you keep any extra weight on the front end?
__________________
  #11
Old 12-02-2012, 07:23 AM
kiko's Avatar
kiko kiko is offline
Default Front tire wear?
I recently learned that the front wheel is directional, there is an arrow on the wheel near the hub. Maybe your wheel is mounted backwards. I don't know if that is of any importance to tire wear, but thought I would mention it.
edit: I just looked at my front wheel and the arrow is located on the left side hub near the axle inside the brake disc rotor. It is embossed into the casting of the wheel hub. My front wheel does not have a directional arrow on the right side hub.
  #12
Old 12-02-2012, 07:31 AM
invader invader is offline
Default
It also depends a lot on riding style and braking technique; how hard you brake and brake bias (front in relation to rear).
  #13
Old 12-03-2012, 12:06 AM
Default
Fully geared I weigh about 180lb. I also check my tires about once every 2weeks and never let them get more than 1psi off of the stock recommended 32psi/36psi. I believe it is most likely my riding that has the biggest effect on this. I ride very little on divided highway and most of my riding is city and twisty rural roads were there is a lot of turning and lane switching. I virtually never exceed the speed limit by more than 10%.
__________________
  #14
Old 12-03-2012, 02:45 PM
Smash's Avatar
Smash Smash is offline
Default
May I recommend bumping up that front tire a bit? I run 36/38 locally and 38/40 for touring (all solo, but loaded for camping) on my Bridgestone BT023s. The PR3s are supposed to be a slightly better tire than the BT023s, but the 'stones are cheaper. Quite a few like the Shinko Ravens too, although I haven't tried them.
__________________
2 weeks vacation does not make a life
2006 Ninja 650R - his
2000 ZR-7 - hers
  #15
Old 12-03-2012, 10:18 PM
Default
Originally Posted by Smash View Post
38/40 for touring
That's about what I've been using too.
Tags
front tire, pirelli scorpion trail
Forum Jump
Advertisements
