Head Light Assembly - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 11-17-2012, 09:53 AM
versysnewbrunswick's Avatar
versysnewbrunswick versysnewbrunswick is offline
Default Head Light Assembly
I love my 2011 but I have a small problem with the head light assembly - it leaks. I have put my bike up for the winter so now would be a good time to tackle this. I want to pull the assembly out and clean down inside of it. I have the fairings off but i cant seem to see where to get the assembly out. Has anyone else run into this with their head light ? After i clean it i am planning on sutting silcone around where i think it leaks.
Old 11-17-2012, 11:04 AM
chid's Avatar
chid chid is online now
Default
I know it's not the same, but it's similar. Look at this thread how I opened the headlight assembly (and put it back )
http://www.kawasakiversys.com/forums...ad.php?t=15364
hope it helps.
__________________
Versys 2009 Green
  #3
Old 11-17-2012, 12:31 PM
Sprocket's Avatar
Sprocket Sprocket is offline
2010 Kawasaki Versys
Default
Chances are if it leaks the rubber seal around the connector at the back of the light is loose and just not attached properly. If you bike is under warranty I would take it to the dealer to see what they say. Not a normal issue.
  #4
Old 11-17-2012, 01:54 PM
Default
i got the assembly out but now i can not separate the two to clean the lens. Seems to be leaking at the top. Asked the dealer last year and his response was from Kawasaki that it is not a sealed beam so not covered under warranty. The first photo is where I think the cleaning agents are getting in and the second one you can see the streak marks inside
ID:	16217   Click image for larger version
ID:	16218   Click image for larger version
  #5
Old 11-17-2012, 02:10 PM
chid's Avatar
Default
put it in the oven.
read my topic and you'll see. I don't remember the temperature and time.
not difficult.
__________________
Versys 2009 Green
  #6
Old 05-20-2013, 09:10 AM
Default
update...I took my headlight assembly to my local dealer last fall and it just happened the kawi rep was there that day...he took some pictures and i waited all winter but now i have a new one installed on my bike...looks good and thanks to my dealer
Forum Jump
Advertisements
