Bike tracking left when hands off handlebars - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > General Kawasaki Versys Discussions
General Kawasaki Versys Discussions For discussions on anything and everything related to the Kawasaki Versys.
Thread Tools Display Modes
  #1
Old 11-10-2012, 01:31 AM
yychow0812 yychow0812 is offline
Kawasaki Versys
Default Bike tracking left when hands off handlebars
I noticed recently that my bike was tracking slightly left when my hands are off the handlebars (just for a few seconds, to adjust gloves or stretch out hands etc, not for showing off). I wonder if this is just due to the camber of the roads? (in Thailand, we ride on the left hand side, like in the UK and Aus).
I did drop my bike once on the right, from 1 km/h (rookie, front brake error). Could this have twisted or bent the forks in any way? To compensate and offset any twists, I dropped it on the left side from 0 km/h by not fully deploying the side stand.
Any ideas?
Old 11-10-2012, 06:19 AM
MTS MTS is offline
Default
I'm not sure but I wouldn't drop your bike to try and correct possible frame or handle bar damage!
It is possible you have bent your forks, where they tie in to the frame.
__________________
  #3
Old 11-10-2012, 07:38 AM
invader invader is offline
Default
Haha. It was unintentionaly dropped on the left "by not fully deploying the side stand."
Maybe you just need to release the twisting tension in the forks by turning handlebar with side of tire leaning on a wall or tree/post... Or maybe something is bent. Have it checked by a pro.
  #4
Old 11-10-2012, 08:51 AM
Kawasaki Versys
Default
Yes, unfortunately, it was unintentional Having said that, neither of the two drops were severe or dramatic as they seemed to happen in slow motion
Releasing the tension by turning the handlebars with side of tire leaning on something hard? Sounds scary, as I wouldn't know how hard to turn it incase I broke.
Best bet I guess would be to take it to the service shop for a look. Luckily, it's not as if the bike is skittling across the road, more like a slow drift which made me think initially it could just be the road camber.
  #5
Old 11-10-2012, 10:53 AM
Default
After a fall, if the front wheel seems offset with handlebars, you can sometimes release that offset tension in the front suspension and let it regain its balanced center that way.
  #6
Old 11-10-2012, 11:20 AM
Boricua's Avatar
Boricua Boricua is offline
2008 Kawasaki Versys
Default
Keep the hands on the handle bars.
And don't drop the bike anymore
  #7
Old 11-10-2012, 02:19 PM
scooter650's Avatar
scooter650 scooter650 is offline
2007 Kawasaki Versys
Default crooked
sometimes the wheel will twist in the forks slightly to one side (more so on dirt bikes) if the bars hit the ground hard. Just find a pole or fencepost (that's what I used dirtbiking on the farm) and tap the side of the wheel that it pulls towards against the side of the pole to adjust the bars back to straight. Loosening the pinch bolts for the forks on the triple tree makes it easier, depending how much adjustment is needed.
  #8
Old 11-10-2012, 03:13 PM
Kawasaki Versys
Default
  #9
Old 11-10-2012, 03:16 PM
Kawasaki Versys
Default
Thanks for all the good suggestions. Will give it a try asap. Is it enough to just release the tension from the lower triple clamp? Should I loosen the bolts first on one side, retighten and loosen the other side or is it ok to loosen both sides at the same time? (I know that it's definitely not advisable to loosen both the top and lower clamps at the same time)
  #10
Old 11-10-2012, 03:49 PM
Default
Yeah I think you could loosen just the lower clamp, then twist the handlebar back and forth and let it find its natural center, while holding the front wheel between your legs if possible.
  #11
Old 11-11-2012, 01:02 AM
Kawasaki Versys
Default
I just checked the marks on the swingarm, they seem to be well off, making the tyres point to the right. Is this what's making the bike track left?
ID:	16177   Click image for larger version
  #12
Old 11-11-2012, 02:52 PM
Default
It CERTAINLY ain't helping! Check your rear alignment.
__________________
  #13
Old 11-11-2012, 03:40 PM
Default
Your rear wheel is pointing slightly to the right, which makes it pull to the left.
  #14
Old 11-12-2012, 07:03 AM
2daMax's Avatar
2daMax 2daMax is offline
Default
Don't trust too much on the alignment markings, they are not accurate. Use a chain alignment tool to align the rear sprocket with the chain/front sprocket.
__________________
Present Ride: 2011 Versys Spark Black
Previous Ride: Kawasaki Ninja 250R 2008 Plasma Blue
My V's Farkle Log: http://www.kawasakiversys.com/forums...214#post146214
  #15
Old 11-12-2012, 10:54 AM
Kawasaki Versys
Default
I need to get myself down to Penang to STLee's place, for chain aligning and throttle syncing . Only problem that it's about 1,400 km!!
  #16
Old 11-12-2012, 10:57 AM
Kawasaki Versys
Default
Finally took my bike to the local Pirelli dealer for alignment and wheel balancing. Tested a bit of freehandling on the way back and bike seems to be tracking straight now.
Thanks to all for your input. I've learnt a great deal as always. Cheers!
Forum Jump
Advertisements
Honda Grom Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
