hbars with more rise, less pull back.. - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > General Kawasaki Versys Discussions
General Kawasaki Versys Discussions For discussions on anything and everything related to the Kawasaki Versys.
Thread Tools Display Modes
  #1
Old 11-06-2012, 01:42 PM
kojack's Avatar
kojack kojack is offline
Default hbars with more rise, less pull back..
anyone replace their bars with ones with a little more rise and little less pull back?
Old 11-06-2012, 05:29 PM
oldkawboy's Avatar
oldkawboy oldkawboy is offline
2008 Kawasaki Versys
Default
I have one of these because I never could find a bar that I liked.
http://www.twistedthrottle.com/handl...er-20mm-height
The riser has really worked well for me.
Dan
  #3
Old 11-06-2012, 06:16 PM
kojack's Avatar
Default
I will have to try those. may offset the pull back..
  #4
Old 11-06-2012, 11:17 PM
andrewhtf's Avatar
andrewhtf andrewhtf is offline
Default
You can adjust how much pull back you like with rox risers no?
__________________
Current : Maroon 2011.
- Front Fender Extender - Radiator Guard - 19mm Nissin radial master pump - Nissin 4-pot caliper - SS Brake lines - Osram Nightbreakers H7 - LED 30w spotlights & 3w DRLs - Rear Hugger - Givi crash guards - Yoshimura TRC Carbon - Dynojet PC5 - Scottoiler - R1 shock with Ohlins 14.2 kg/mm spring - Imitation Givi Windshield - Rear Givi rack with 35ltr Givi top box - Bosch dual tones.
Up next :
- Osram Hyper Rallye 65W high beam - Protaper SE ATV Low - Handguards
  #5
Old 11-07-2012, 12:08 AM
invader invader is offline
Default
Absolutely, Andre... Rox adjustable pivoting riser/adapter.
http://www.advdesigns.com/roxadhabarri.html
  #6
Old 11-07-2012, 06:28 AM
Zatx's Avatar
Zatx Zatx is offline
Default
Yep.. I use 2 inch Rox Risers and love them!
__________________
May the road always curve in front of you.
  #7
Old 11-07-2012, 08:49 AM
kojack's Avatar
Default
Not exactly...im talking about the actual angles in the bars...I like my bars straighter. the bars are bent back on the v....
  #8
Old 11-08-2012, 12:50 AM
andrewhtf's Avatar
Default
Ah, my bad, it is that kinda pull back u mean...
__________________
Up next :
  #9
Old 11-08-2012, 11:12 AM
Jeff S's Avatar
Jeff S Jeff S is offline
Default
Me too. The angle of the V bars is the only thing that really bothers me about this bike's ergo's. Kojack: if you find suitable replacement bars, likely paired with ROX risers, post a photo here...
__________________
Cheers, Jeff
Two weeks in the western US
2010 Versys
SW-Motech crash bars & bash plate
SW-Motech quick lock rear rack
Two seahorse 720 cases / panniers
Givi wind screen
  #10
Old 11-08-2012, 12:43 PM
fasteddiecopeman fasteddiecopeman is online now
Default
FWIW - when I had my Bandit I HATED the stock bar angles, as they put my hands to sleep. Put 'drag-bars' on with risers (1.5" or so) and LOVED it!
__________________
  #11
Old 11-10-2012, 06:19 AM
kojack's Avatar
Default
freddie, I may go the crusier route...there is a multitude of bars available maybe ape hangers...ha ha! I am going to get the specs from the stockers, and size up what I can put on, using or not using a riser.
  #12
Old 11-10-2012, 09:59 PM
Default
Just think - you could mount your apehangers UPSIDE down for a really DIFFERENT look, altho' you might hit your chin on the tank....
__________________
  #13
Old 11-11-2012, 02:56 AM
andrewhtf's Avatar
Default
This is as close as the stocker dimension i could search.
Originally Posted by Velocibiker View Post
Those numbers on the OEM bar didn't look quite right to me so I just got back from pulling the bar off my '08 on doing my own measurements.
Now, based on ProTaper's description of Height, Width, Rise & Sweep, these are my numbers:
A = 760
B = 130
C = 75
D = 190 (center to center where the OE bars are knurled = 85)
E = 90
All measurements were made as close as possible from center to center. So, depending on how you measured, the numbers may/will be different.
Some of my pictures - it doesn't work well since pictures are not 3D and what your eyes see vs. what the camera sees is pretty different.
Width
__________________
Up next :
  #14
Old 11-11-2012, 07:04 AM
Ivan V Ivan V is offline
Default
As per Andrewhtf's post, stock measurements are close to this:
(I measured them off the bike and got similar numbers)
OEM:
A: 760
B: 130
C: 75
D: 190
E: 90
F: 240
I currently have these, but I prefer stock. I like more sweep and sportier bend. It may work for you Kojack. Or the 'High' version.
ProTaper SE ATV Low:
A: 813
B: 140
C: 88
D: 228
E: 84
F: 206
I want to try Renthal Road High bars. Maybe with some riser.
A: 710
B: 140
C: 88
D: 228
E: 84
F: 206
Handlebars change the character of the bike dramatically and you can't tell much from these dimensions if you haven't tried anything but stock. Buy some cheep/sellable ones to give you an idea.
Forum Jump
Advertisements
