Speed & Tacho signals - Kawasaki Versys Forum
Thread Tools Display Modes
  #1
Old 11-05-2012, 04:44 AM
vianaj vianaj is offline
2008 Kawasaki Versys
Send a message via MSN to vianaj
Default Speed & Tacho signals
I'm willing to build a DYI Gear Indicator...
For that I need to know the ratios between ECU pin 6 Speed Sensor signal and ECU pin 47 Tachometer signals. Those signals are also available at cluster pins 5 and 6...
I know that speed sensor output 4 pulses per sprocket rev., because the sensor senses a square nut concentric with sprocket.
I do not know the relationship between crankshaft (ECU pins 13, 30) and Tachometer signal, but I will use this last one. Timing rotor has 22 teeth, therefore Crankshaft Sensor signals might output 22 pulses by revolution, but this signal is differential and pulses do noy have all the same duration. For the Tacho signal, the service manual refers that 133Hz will display 4000 RPM. Well, 4000 RPM is 66.6Hz hence, this signal might be 2 pulses per revolution.
If anyone has already checked those signals, comments are welcome. Thanks. Jose.
Old 11-05-2012, 06:58 AM
genehil's Avatar
genehil genehil is offline
Kawasaki 2011 Versys
Default
So how long have you worked on the Mars rover?
__________________
GeneHil - Panama City, FL
2011 Kawasaki Versys
  #3
Old 11-05-2012, 10:06 AM
Default
Till now, just on papers! :-)
  #4
Old 11-06-2012, 01:34 AM
andrewhtf's Avatar
andrewhtf andrewhtf is offline
Default
Why not buy a cheap, magnet based, gear indicator?
__________________
Current : Maroon 2011.
- Front Fender Extender - Radiator Guard - 19mm Nissin radial master pump - Nissin 4-pot caliper - SS Brake lines - Osram Nightbreakers H7 - LED 30w spotlights & 3w DRLs - Rear Hugger - Givi crash guards - Yoshimura TRC Carbon - Dynojet PC5 - Scottoiler - R1 shock with Ohlins 14.2 kg/mm spring - Imitation Givi Windshield - Rear Givi rack with 35ltr Givi top box - Bosch dual tones.
Up next :
- Osram Hyper Rallye 65W high beam - Protaper SE ATV Low - Handguards
  #5
Old 11-06-2012, 09:55 AM
Default
There are advantages and inconvenients in both GI either based on lever position or speed/tacho ratio...
V gearbox is too stiff... not very precise... therefore I think the GI will count even when gear is not engaged...
For such system, I would prefer to use an internally installed optical fiber laser detector instead of magnetic hall effect ones.
Let's see...
  #6
Old 11-06-2012, 11:09 AM
Default
__________________
  #7
Old 02-13-2013, 12:55 PM
ibonneau ibonneau is offline
Default
Some posts just make me feel dumb.
I hope you can make it and then explain how to all us simple people
  #8
Old 02-13-2013, 01:04 PM
Zatx's Avatar
Zatx Zatx is offline
Default
Just reading that made my head hurt. I'd just spend the $104 on a gear shift indicator and call it good, but I admire your gumption (I'm not technically old enough to use that work appropriately).
__________________
May the road always curve in front of you.
  #9
Old 02-13-2013, 01:29 PM
paretlane paretlane is offline
Default
I saw one on eBay for $24 shipped.
http://www.ebay.com/itm/Blue-Univers...-/250868414833
Forum Jump
Advertisements
