Saw a new BMW K1600GT with front long bar LED running lights and an ad for some Philips 5 light LED running lights and I was inspired. Ordered the kit from Amazon yesterday and I will take a shot at mounting them on the front of the bike on either side of the radiator. Will send pictures of the process if it turns out well ( or you will never hear from me if it doesn't ). Wish me luck.
i installed just what you describe in blue, down both side radiator tanks of my blue 09 and also along the rear seat support rails (just inside the passenger peg supports) last year IMO looks good.
Yeah, I am just looking for some added visibility that looks decent. Was going to go the TwistedThrottle Denali route but they are a tad expensive and I don't do much ( if any ) after dark riding.
That is slick. *How did you do that and what did you use?
Now you just need a colder light for your top running light to match!
Am working on it. Cant seem to get my hands to the base of the bulb without taking off the sides.. I dread having to open up all the plastics just to replace one single bulb.*
For the rear, i used a pair of 2" LED strip that came with adhesive at the back, *stuck inside the housing and tapped the wyre to the plate lighting line.
Metal bar with a 90 degree bend, Bolted onto the side shroud like this.
However it was not as bright as i hoped for, am thinking of either adding another pair or remake another bar so the bulb sits further out instead of hidden below the covers, for maximum visibility.
__________________
Current : Maroon 2011.
- Front Fender Extender - Radiator Guard - 19mm Nissin radial master pump - Nissin 4-pot caliper - SS Brake lines - Osram Nightbreakers H7 - LED 30w spotlights & 3w DRLs - Rear Hugger - Givi crash guards - Yoshimura TRC Carbon - Dynojet PC5 - Scottoiler - R1 shock with Ohlins 14.2 kg/mm spring - Imitation Givi Windshield - Rear Givi rack with 35ltr Givi top box - Bosch dual tones.
Up next :
- Osram Hyper Rallye 65W high beam - Protaper SE ATV Low - Handguards
I'm not sure if you got my pm replies as the ipad kept on giving a blank page everytime i hit the submit button, but here's the pic af a different mounting option.
Here's the way they mounted something bigger. I am thinking of doing the exact same metal mount so my lights will sit further out, as it is kinda hidden now
Instead of the halogen lamp that draw whole lot more power, u can use this instead.
Well, I was able to get some LED lights on the bike.
Some details :
- I used the crash bars as a mount point for the top using a rubber-lined 1 inch clamp and some 3/32 ( I think ) aluminum strips that I bent to fit.
- The bottom of the strips are velcroed to the radiator and, after a couple hundred miles, are keeping the lights pretty tight.
- I ordered some Phillips Daylight 4 LED DRL's. I got the kit from Amazon and it was about $90. Support for these is via 800 number, there was no information on-line other than the manuals.
- I wired them to the Fuzeblock ( unswitched ) but did not follow the instructions. They say to run a second red wire to a "switched" circuit to trigger when the lights will come on. The control box even has a neat blue LED that lights up when you find it. When I connect that up, the lights never come on.
- These lights are designed for a CAR which ( I think ) explains the fact that when the bike goes into a "hot idle", the lights will go off. Blip the throttle and they come back on
- As a feature ( I think ), the lights will stay on for about 5 seconds after you turn off the bike. Kinda cool.
- These are BRIGHT lights. During the day, they are visible. At night, they act almost like little driving lights. They light up about 20 feet in front of the bike in a white light. The wife reports they are brighter than the headlight even though they are aimed down.
Overall, I like them. We'll see how durable the mounting system is but I think it increases my visibility ( which was my goal ) and they look unique. The picture doesn't do them justice.
I have 2 LED strips green, and angel eyes LED that I put the on green.
I mounted them on the bottom of the fairings, I wanted to accentuate the curves of the bike, I think it looks nice.
Everybody looks at them (even the police men) and at night are amazing.
I wired them with the turn signal, they go OFF when the turn signal goes ON.
I couldn't make a good photo for them, look 10 times better than the photo
Just remembered this and thought I would make a note. The way that I installed the LEDs was to put them on the "unswitched" side of my powerbox. When running like this, they would come one when I fired up the bike and they would stay on a brief amount of time when I shut it off. I am just speculating here but I believe that the voltage stayed high enough for a short amount of time to keep them on.
My speculation is well-founded. When I went to store the bike for the winter and hooked up the battery-tender, the lights came on and STAYED ON. I had to switch the lights to the "switched" side of the power box to correct. Not sure if anyone else has run into this but keep them lights switched...
I'm loving it every time I go out at night, the cut-off from the projector is AMAZING!
And to keep it on topic, I wired the LED strips with a relay, so when I put the turn signal, the LED strip and the turn signal are flashing alternatively. cool!
I had no problems until now, it's everything I was expecting!
If you have any more questions, shoot!
I've ordered a pair of these http://www.ebay.co.uk/itm/3308067844...84.m1497.l2648 and they arrived today. I've fitted them to the bike, but I have to wait on the light switch coming before I can wire them up. A mate has a set on his scoot, so I know they're plenty bright enough.
__________________
Good luck exploring the infinite abyss
