Ballistic Batteries EVO2 now with Balanced Charging Capabilities - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Platinum Vendor Area > Riders Discount
Thread Tools Display Modes
  #1
Old 10-21-2011, 02:33 PM
RidersDiscount's Avatar
RidersDiscount RidersDiscount is offline
Platinum Site Sponsor
2009 Yamaha YZF-R1
Default Ballistic Batteries EVO2 now with Balanced Charging Capabilities
Ballistic Performance continues to lead the way with innovative lightweight batteries for motorcycles, ATVs and other applications where power and weight are important factors. Now, Ballistic has introduced a new connection scheme that perfectly compliments their Battery Management System (BMS): Intelligent Digital Balance Charger. This additional connection allows the user to charge each cell within the battery individually for a balanced charge and peak performance. Furthermore, balanced batteries can be expected to last twice as long as batteries that are only charged by your machine’s generator system. And should you choose to forego the Ballistic BMS charger, you can still charge every Ballistic Performance EVO 2 battery in the conventional manner as directed by the included instructions.
Ballistic Performance EVO2 batteries are available in four different sizes: 4-cell, 8-cell, 12-cell and 16 cell.
These hand-made in the USA lithium iron phosphate batteries are engineered to be extremely light, durable and powerful with every component designed specifically for use in high-performance powersports applications. If you’re looking to save a significant amount of weight, and improve your machine’s starting performance, look no further than Ballistic Performance EVO2 batteries. Often, our machines are designed to be as light as possible yet they still employ rather arcane lead-acid batteries that comparatively, weigh a ton. Depending on the application, you can expect to save up to ten pounds of weight just by switching batteries! This is a considerable amount of mass that will be noticeably absent the first time you ride the bike with this battery installed.
From a maintenance standpoint, a conventional lead-acid battery will lose much of its charge, even during short-term storage which is why trickle chargers are so popular today. Ballistic Performance EVO2 lightweight lithium iron phosphate batteries have a very low self-discharge rate and can easily withstand indoor storage for a year or more with no recharging required to start your bike afterwards!
Another big advantage of this aftermarket motorcycle battery, other than its light weight - is its power output performance. Pound-for-pound, conventional lead-acid batteries do not transfer electricity nearly as efficiently as Ballistic Performance batteries and consequently, must be built oversized to make up for this. The result is a battery that weighs significantly more yet provides less starting power output than a Ballistic EVO2 battery.
For those of you concerned with properly securing a Ballistic Performance battery in your ride, each battery comes packaged with a foam carrier that can be cut and shaped perfectly for installation. And with the addition of a BMS Intelligent Digital Balance Charger, Ballistic Performance batteries can be kept at true peak performance year-after-year.
If you’re unsure of which battery is best for your application, call our expert John at 866.931.6644 x 812 or send a note to FORUM at RIDERSDISCOUNT dot COM with BALLISTIC EVO2 BATTERIES in the subject line, let us know what machine you have, and we’ll get back to you right away.
New Ballistic EVO2 batteries come with a BMS plug in right between the leads.
This port is designed to allow users to plug in a Ballistic BMS Intelligent Digital Balance Charger for peak charging performance and extended battery life.
Other than the addition of this extra charging port, there is little difference between the latest EVO2 battery and its predecessor. Each EVO2 battery comes fully charged out of the box, simply plug in and you’re ready to go. The high-strength chassis provides a durable package for the LiFePO4 cathode that’s up to the challenge of starting high-compression engines. Plus its small size frees up room within your bike’s battery box for popular aftermarket tuning equipment like a Power Commander or a Bazzaz Performance tuning kit.
Fret not, those of you that have already purchased a Ballistic Performance EVO2 battery without the balancer feature. This charger can also be used to keep your Ballistic Performance battery in top running condition.
Four, eight, twelve and sixteen cell batteries are available to suit a wide range of applications. From dirtbikes and ATVs to high-compression V-twins – if you’re unsure of your needs, call us for advice on what best suits your application.
And where maximum power is required, we now have 16-cell Ballistic Performance batteries in stock.
__________________
Check us out on facebook and become a fan
www.RidersDiscount.com
For the best service, call us M - F 10a - 6p est. Ask me about our specials.
Call MIKE toll free at 866.931.6644 ext 804 OR his direct line at 616-965-2027
Old 10-24-2011, 03:54 PM
Mt. Versuvius Mt. Versuvius is offline
Default
Could you suggest the right size for the Versys, and PM me a quote? Will my battery tender work to charge this battery? Thanks.
  #3
Old 10-25-2011, 08:30 AM
2009 Yamaha YZF-R1
Default
An 8-cell Ballistic Battery is recommended for the Versys. PM on the way.
No special charger is needed however you do not want to use a battery tender. You want to charge the battery with just a normal battery charger.
Here are the charging instructions from Ballistic's website:
"Ballistic Batteries are very different in chemistry and construction from a traditional lead acid batteries. Ballistic Batteries do not require regular maintenance charging or a special charger, and will only lose less than 10% of their total charge over a (12) month period of static use. They are compatible with your vehicles charging system and can be used in a ‘total loss’ application.
When charging a Ballistic Battery with an external charging device, the following input specifications must be adhered to:
Standard Charge: 2A @ 13.8-14.4V for 45 minutes
Maximum Charge Rate:
4 Cell (101-100) - 10A @ 13.8-14.4V for 15 minutes.
8 Cell (101-103) - 20A @ 13.8-14.4V for 15 minutes.
12 Cell (101-105) - 20A @ 13.8-14.4V for 15 minutes.
DO NOT: Do not charge a Ballistic Performance Component Battery above 14.4 Volts. This will damage the battery. Do not charge or attempt to maintain charge with a trickle charger. Do not allow the battery to be completely drained, this will damage the cells. If your powersports vehicle has a parastatic draw like an alarm of similar devices, disconnect the battery.
Failure to adhere to these charging specifications or exceeding these limits may cause battery failure and will void any potential warranty claim."
__________________
  #4
Old 12-05-2011, 01:01 PM
2009 Yamaha YZF-R1
Default
These 8-cell batteries are in stock and shipping.
__________________
  #5
Old 01-16-2012, 03:07 PM
2009 Yamaha YZF-R1
Default
A 3 year warranty is standard on these batteries! Made in the USA so you know as well.
__________________
  #6
Old 05-09-2012, 11:28 AM
2009 Yamaha YZF-R1
Default
Spring bump for a great battery.
__________________
Forum Jump
Advertisements
