Throttle locks - Kawasaki Versys Forum
Go Back   Kawasaki Versys Forum > Kawasaki Versys Motorcycle Talk > General Kawasaki Versys Discussions
General Kawasaki Versys Discussions For discussions on anything and everything related to the Kawasaki Versys.
Thread Tools Display Modes
  #1
Old 04-08-2008, 09:29 PM
AlexDz AlexDz is offline
Default Throttle locks
Anybody fitted one of the universal (or any other) el-cheapo throttle locks to their Versys yet?
Old 04-09-2008, 04:17 AM
jnor's Avatar
jnor jnor is offline
Default
I've put them on other bikes. I don't use them anymore, I put a crampbuster on mine when on the highway, I can't stand it on there all of the time, but on long trips on the highway it's fine. Throttle locks bother me anymore. The crampbuster is only $10.00, and go on, and off easy.
__________________
09 Versys
If you don't think you need a helmet.......
You probably don't............
  #3
Old 04-09-2008, 10:19 AM
Brother Verse Us's Avatar
Brother Verse Us Brother Verse Us is offline
Default Manic Salamander Throttle Lock
I added a bar-end throttle lock to the Versys made by Manic Salamander. The 8mm kit fit great and looks good. I had intially thought of painting the bar ends black, but I think I'll leave it as is...at least for now. Here is the link for Manic Salamander:
http://http://www.manicsalamander.com/throttle_lock.htm
Unfortunately it doesn't meet the criteria of cheap, as the set cost $100. I have a $30 universal throttle lock on my KLR, but wanted to try something different for the Versys.
Some people have mentioned using a large Caterpillar o-ring with success. Someone had listed the part number and posted pictures, but I can't remember which site it was on.
  #4
Old 04-09-2008, 01:14 PM
Default
I saw the Manics, and of course there's the original bar-end lock, the Throttlemeister--but those would preclude the use of any handguard that wraps around to attach to the bar-end bolt. I'd like to stick with the type that go between the grip and the control housing. Problem with those is that depending on the bike it may require doing some grinding on the throttle sleeve.
The Cat o-ring I recall from my Concours days, and in fact the only one I ever saw in use was on a Connie. Looked nice too, big fat yellow o-ring. I never did put in the time to figure where the hell to get one though, and it has the same problem that it would not work with the above handguard type.
What about non-wraparound handguards, has anybody used those? That would leave the end of the grip available for other uses.
  #5
Old 04-09-2008, 04:02 PM
Bad-Tat Bad-Tat is offline
Default
Alex,
With the proper spacers you can put handguards on a throttlemeister. I have had one on my F650GSD since 2001.
__________________
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
  #6
Old 04-10-2008, 10:28 AM
Default
Originally Posted by Bad-Tat View Post
Alex,
Any chance of posting or sending a picture of your F650 setup? I have to admit I'm having a tough time visualizing it. BTW, are the Versys bar ends standard Kawi 8mm bolt types?
  #7
Old 04-10-2008, 02:05 PM
Default
Yes, the Versys uses 8mm bolts for the bar ends.
  #8
Old 04-11-2008, 08:09 PM
Enemy Zero's Avatar
Enemy Zero Enemy Zero is offline
Default
I just ordered the one from Manic Salamander. I'm hoping it works well. I had a throttlemeister on my F650GS and it made such a difference on long trips.
This one was expensive but it seemed easiest to fit on and use.
  #9
Old 04-19-2008, 12:40 AM
rjmorel rjmorel is offline
Thumbs up throttle locks
For $100 you can buy a real cruise control that works like a car's cruise control. Look for a Audiovox CCS-100. They've been put on Suzuki DR650, Honda Pacific Coast, Kawasaki Concourse, as well as others. I have one on my DR650 and it's the greatest for highway travel and you can literally ride for hours on end without adjusting the throttle if the traffic and road conditions allow and you don't fall asleep. Heres a link to my DR650 Audiovox installation. You may need to join the Yahoo Dr650 group temporarily to view it but it's still there last time I checked. When/if I sell my DR I would like to get the Versys as my next bike as I mainly do highway and gravel road type riding and I will put an Audiovox CC on it also. Rob
http://sports.ph.groups.yahoo.com/gr...os/browse/e739
  #10
Old 05-08-2008, 08:52 PM
dstarman dstarman is offline
Default
AlexDZ,
I posted a Free Versys manual for 2007 and I would guess its good for 2008 as well. My point is in the manual you can find any spec you need as far as size, torque etc.
__________________
Cheers,
David
Greeks never wrote obituaries---they only asked one question---Did this person lived life with Passion?
  #11
Old 05-10-2008, 06:09 PM
Default T meister Pic
Pix of Throttlemeister with handguards.
ID:	68   Click image for larger version
Name:	F650 TM 1.JPG
__________________
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
  #12
Old 12-15-2008, 11:51 AM
joshmedley's Avatar
joshmedley joshmedley is offline
2008 Kawasaki
Send a message via MSN to joshmedley
Default
bad tat, what do you think of your set up? been toying with getting the throttle meister or the kaoko, and don't want to give up my bark busters....what are you thoughts on yours?
  #13
Old 12-15-2008, 01:45 PM
crazydave58's Avatar
crazydave58 crazydave58 is offline
Default throttle lock
if u want a cheap throttle lock then u won't get cheaper than this.....rubber o-ring 99 cents
  #14
Old 12-15-2008, 06:00 PM
Default
Josh,
I have both the Meister and Kaoko. I like the Kaoko better as it is a hex shape for better grab to turn it on and off. Bark Busters will work with either. Just need spacers in the case of the Meister and longer bolt on the Kaoko's.
__________________
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
  #15
Old 12-16-2008, 08:30 PM
JERRYES JERRYES is offline
Default
BAD TAT noticed the nor mar tire changer. What do you think about it and how it works. Is it worth it? noticed you have a lot of bikes so definitely would be worth it for you.
  #16
Old 12-16-2008, 09:20 PM
Default
Jerryes,
The No Mar works great as long as you use lots of lube. Much better than my 30 gal grease drum, especially for Dakar rims with not much drop center and small (10-12") rims. For me it's well worth it.
__________________
Bill
Versys
F650GSD
FLSTSCI
XR650L
Tri Scrambler
XR50
SRX600
Zuma 125
T100R
Aero 50
EZ90
PA50
States by MC
  #17
Old 01-06-2009, 08:17 PM
AvaChava's Avatar
AvaChava AvaChava is offline
Default O-ring solution
Hey Dave;
I have GOT to do something until I make up
my mind what friction/handguard/windshield
combo to get. What do you do, just roll it
out to use and back over the grip? Heck,
I might even have an o-ring that will work.
  #18
Old 01-06-2009, 09:24 PM
yes avachava.......just roll the 1 1/8 inch rubber o-ring onto the grip....it takes a little practice , but it works..I got the o-ring at a hydraulic supply store..
  #19
Old 01-07-2009, 11:49 AM
Machog's Avatar
Machog Machog is offline
Default
AC, this Vista cruise fits on the Versys and will work with handguards windshields etc.
Machog
  #20
Old 01-07-2009, 01:23 PM
AvaChava's Avatar
Default
Yeah, thanks, I saw that but a guy pulled in to
the dealership when I bought my V and he swore
by the Throttlemeisters. I figured I'd get some to
try but also want a set of Barkbusters or some of
the other good handguards. Then I'll be adding
a Givi or something and hear there can be interference
problems. Before I lay out $350 or $400 I'd like to
find out for sure all that stuff will go together.
The O-ring will get me through the week;
the Vista Cruise may get me through the
indecision...
Thanks to both of you guys for input.
I've been cruising back threads here
collecting opinions and pictures. And
links. But there's just so many hours
in a day and before I ask any more
questions I need to finish my homework.
I'm totally blown away by the number
and variety of modifications I'm seeing
here. I don't guess ANYBODY rides a
Versys the way it comes out of the box,
do they? Ha ha, love it!
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SW-Motech Quick Locks -- any good? Wordguy Modifications - Cosmetic 26 02-09-2009 03:09 PM
Brake locks, U-locks, what's your choice? DeepVoid General Kawasaki Versys Discussions 1 08-29-2008 02:53 AM
What NEP throttle lock? leshall Modifications - Performance 11 08-19-2008 10:08 AM
What throttle lock? leshall Modifications - Cosmetic 8 08-09-2008 11:57 AM
brake locks vladimirpoopen General Kawasaki Versys Discussions 3 06-22-2008 06:18 PM
Advertisements
1199 Panigale Forum Honda Africa Twin Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
BMW Scrambler Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
