Just found the Honda NC700XA on Honda's web site. Also see review. It looks like a direct competitor to the Versys with the same size and type of motor, similar ergos, same size tires, etc.. It even has a cool gas tank used for lockable storage. Actual gas fill hole is is under seat.
Engine Type Liquid-cooled parallel-twin
Displacement 670 cc
Bore & Stroke 73 x 80 mm
Compression Ratio 10.7:1
Valve Train Chain driven SOHC, 4 valves per cylinder
Fuel Delivery PGM-FI electronic fuel injection
Transmission Six-speed
Final Drive O-ring sealed chain
Front Suspension 41mm telescopic fork; 153.5 mm (6 in.) travel
Rear Suspension Single shock, Pro-Link swingarm; 150 mm (5.9 in.) travel
Tires 120/70ZR - 17 radial front; 160/60ZR - 17 radial rear
Brakes Front 320 mm wave disc with triple-piston caliper; rear 240 mm wave disc with single-piston caliper. Combined Braking System with ABS
Ground Clearance n/a
Seat Height 830 mm (32.7 in.)
Wheelbase 1,540 mm (60.6 in.)
Curb Weight 218 kg (480 lb) including required fluids and full tank of gas - ready to ride
Fuel Capacity 14.1 litres
Displacement 670 cc
