This is just a FAQ reference for this issue.
It appears to be one of the most common Versys problems.
In short, it seems to happen eventually with almost all Versys models. Kawasaki put out a fix in June of 2007 which involved placing some foam dampers on the affected parts. Newer bikes appear to come with this foam, but the problem still seems to crop up again over time.
The quick fix is to install new foam (or 'damping' material) on the affected parts. Some dealers will do this for you under warranty, but it's a pretty easy DIY project.
Previous discussions on this forum:
http://www.kawasakiversys.com/forums/showthread.php?t=487
http://www.kawasakiversys.com/forums/showthread.php?t=553
http://www.kawasakiversys.com/forums/showthread.php?t=430
http://www.kawasakiversys.com/forums/showthread.php?t=290
http://www.kawasakiversys.com/forums/showthread.php?t=112
http://www.kawasakiversys.com/forums/showthread.php?t=1625
Discussed on other sites (registration may be needed to see pictures):
http://www.versys.co.uk/index.php?option=com_smf&Itemid=45&topic=2927.0
http://www.versys.co.uk/index.php?option=com_smf&Itemid=45&topic=1500.0
http://www.subirimagenes.com/imagen-de-recall-1923009.html
