Won't know landed USA cost until the shipping logistics are figured out, and that depends if it is a bulk shipment or one at a time to each buyer
You guys should get together for a group buy. If I had some idea of quantity I could give you a landed price. Think in the region of 125 USD painted flat black - cheaper if gel coat
My bike is a 2011 and we do not have any earlier versions in Thailand. All I can make is what I know fits my bike.
I have looked through the forum quite a bit now looking for a place and a price for these beaks. I got the honda pxc150 front grill assembly and havent put it on yet because I dont want to make any alterations knowing that i really want one of there fine lookin' beaks that dont require any changes to the original plastics. Forgive me if I am beating a dead horse here, but the facebook link in this post doesn't take me anywhere and the is so much information and posts/threads on beaks that my head is starting to spin just trying to find a place to buy one. I think whoever made these did an awesome job and really helped the V have a finished look. That said, I want mine lookin' like that!
I'd like to see how it's mounted and if it's reversable in the case I sell the bike and new buyer wants it stock...but very interested, 125USD sounds reasonable.
Depending on what happens in the next month or so I could be convinced to get on board. Sadly I know I can't make any decisions until after January 1 2013.
Trying to figure out what it would look like on the maroon 2011 Versys.
It is a 3 piece affair, the beak itself and 2 side panels to blend into the stock anteater nose.
Reversible no problem
Will post a pic when back from my ride next week as off in the morning
My bike is 2011 maroon but I thought to either do it in flat black to match the other plastic bits (mine is all blacked out) or completely repaint the bike incorporating some spiffy graphics on the beak.
I think flat black for now as it is riding season in Thailand, and will do a complete paint makeover in rainy season which summer in N. America
After 6 weeks, one of the Malaysian Vendors finally came through and I just received one of these Malaysian made beaks. Unfortunately is is a steaming, ill fitting, POS.
Nothing fits properly, especially the big uneven gaps where the new side pods blend into the stock anteater nose. The beak portion is flimsy, unsupported, and cantilevered off the side pods. Brackets are flimsy, shoddy, and IMHO just not up to long term use and vibration.
To my knowledge there are 3 Vendors and perhaps they are all not like the one I got, but that is it for me and ripped off once, twice shy
A total waste of money (200 USD landed at my door in Thailand) and the Vendor is taking the typical SE Asian attitude of 'very sorry but no returns". Sorry for what - knowingly selling something that is not proper, or ripping me off?
It has pissed me off so much that I am now using this useless POS as a basis to do it right. It is now all cut up, and fibreglassed in place on my bike so that it fits, and the final body work is being done now, so that a proper mould can be made.
I hope to be able to offer the Versys community a proper product that I use on my own bike around Christmas time.
Well that sucks. Sorry to hear it went down that way. Appreciate the fact that you're still interested in making hem the right way for the rest of us, though!
:thumbup:
Sent from my SCH-I535 using Motorcycle.com Free App
Got the side panels made now and I think I may just forgo the beak on my own bike and go with this anteater nose solution.
It is not finished and still needs a bit of work for a really good mould, and some quality brackets, but this is just about there.
Most likely will paint it red to match the anteater nose, although black is also OK.
On to the beak section tomorrow for those that really want a beak
I like the anteater, it's more 'form follows function' than the beak, which is ornamental and probably adds some additional wind noise. Just my 2 centavos.
I have designed it in such a way that the same mould is used for the filler only or filler with beak, so easy to add on later or just use the parts bit you prefer
Will finish up these fillers today and then on to the beak
Hoghead, seems like you've gotten the older version instead of the improved version. The older one uses some metal bar to hold it in place while the newer one mounts direct to the body plastics using bolts and drilled holes. Take a look.
The Malaysian design Rev1 used a wimpy bit of plumbers strap to the filler piece alone, and the beak bolted to the filler. Not an ideal design
I thought of bolting the filler piece to the existing body work as shown in the white example of Malaysian Rev 2, but I am not keen at all on cantilevering this entire fibreglass part with an overhanging beak off the existing ABS bodywork. I am also not convinced that this ABS to Fibreglass bolted connection will stand up over the long term with vibration and shock.
The existing body work is not exactly designed nor mounted to take the additional weight of a heavy fibreglass part hung off the front- time will tell I guess
I think that a more secure independent mounting will be better with vibration, and am bolting the beak to the filler piece as you show in Rev 2, with a proper bracket coming off the headlight framework at the beak to filler interface. Another long bracket, using the same pick up point, will come off both sides of the headlight framework to support the leading edge of the beak The trailing edge of the filler piece is mounted to the bike frame using an aluminium bracket - not as clean looking, or inexpensive, as bolting to the stock ABS body work, but I believe more reliable
Will post some new pics when the mould work is done
This "improved" Rev 2 version still does not fit very well. Note the beak to filler fit and how the body lines are not carried through on the new bits
The first run of beaks is now done and looks pretty good right out of the mould.
I am in the Philippines right now boating and beering with my buddies and will send some pics and FOB costs when I get home Feb 14
Related Threads
Kawasaki Versys Forum
507.6K posts
81.9K members
Since 2008
A forum community dedicated to Kawasaki Versys motorcycle owners and enthusiasts. Come join the discussion about performance, touring, modifications, classifieds, troubleshooting, adjustments, reviews, maintenance, and more!
