Irritating buzzing - Kawasaki Versys Forum
Old 12-12-2012, 10:27 PM
bigdaddy's Avatar
bigdaddy bigdaddy is offline
Default Irritating buzzing
Hey all. Am experiencing this irritating buzz whenever I am accelerating between 2k to 4.5k rpm, or somewhere thereabouts. I think I have all the screws tightened, and the sound seems to come from the front. Can anyone tel me what the heck is wrong and how to fix this? Thanks guys.
Old 12-12-2012, 10:47 PM
http://www.kawasakiversys.com/forums...read.php?t=620
Old 12-12-2012, 10:53 PM
bigdaddy's Avatar
Thanks Invader!
Old 12-12-2012, 11:47 PM
Hope you cure your buzzing or consider ear plugs...
Old 12-13-2012, 12:51 AM
Just tube it!
Old 12-13-2012, 08:08 PM
sanderm sanderm is offline
Remove the windscreen and see if the buzzing is still present. I have a 2012 and when I removed the stock screen there was zero buzz. Once I replaced the screen with a MRA windscreen the buzzing was eliminated by about 80%.
Old 12-16-2012, 08:49 AM
bigdaddy's Avatar
I do use them religiously
Old 12-16-2012, 08:50 AM
bigdaddy's Avatar
Just tube it!
Will do mate!
Old 12-16-2012, 08:51 AM
bigdaddy's Avatar
Am using a GIVI windshield now. Tightened the screws yesterday. Will continue to monitor for buzzing.
Old 12-16-2012, 10:25 AM
Just tube it!
If its 2010 or newer! Other stuff if older!
Old 12-17-2012, 01:22 AM
bigdaddy's Avatar
Any specific references on therads for 2010 and above?
Old 12-17-2012, 01:12 PM
naudan naudan is offline
Big -- Consider this an XMas Gift. I learned this from another forum member. Took me 10cents and about 1 minute to fix the buzz. Ever since I have been HAPPY AS HELL.
Let me know if you dont understand the directions.
http://www.kawasakiversys.com/forums...8&postcount=17
Farkles:
Givi Tall Windscreen, Givi Top Rack and Case, Givi V35 Bags and Mounts, Givi QuickLock Tank Connector+Bag, Oxford Heated Grips, Nuvi 550 w/ Ram Mount, Barkbusters Full Wrap + Storm, Motowerks Flatfoot, Spools and Tank Protector, Bobbed Fender, Grip Puppies, 12v SAE Socket, Packjack, Airhawk 1 (med), Scala Rider G4, Contour Roam2
Next Stop: 44Tooth Sprocket (To be installed)
Old 12-17-2012, 07:14 PM
bigdaddy's Avatar
Will definitely give this a try!
Old 12-17-2012, 10:45 PM
Tigerpawed Tigerpawed is offline
Ah man, you made my evening. Thanks! Nice to know the effort to document and write up is appreciated. Merry Christmas!
One cannot enlighten the unconscious.
Old 12-18-2012, 08:23 AM
Tubing mine did nothing (2011). I've never fixed the buzz... so I just use really good earplugs and now the buzz is gone.
Old 12-19-2012, 12:27 PM
If it's been buzzing for a long time, take the cowlings off and you'll be able to see where it needs some rubber pads.
Old 12-23-2012, 07:31 PM
2daMax's Avatar
2daMax 2daMax is offline
If this has not been covered, here's what I did to mine using just rubber pieces from a used inner tube rubber.
http://www.kawasakiversys.com/forums...76&postcount=9
The result is 0% bezel vibrations for the last 4k km.
Present Ride: 2011 Versys Spark Black
Previous Ride: Kawasaki Ninja 250R 2008 Plasma Blue
My V's Farkle Log: http://www.kawasakiversys.com/forums...214#post146214
