Hello From Media PA - Kawasaki Versys Forum
Old 12-10-2012, 09:51 AM
Default Hello From Media PA
After many years of thinking about getting a motorcycle, I finally did it. Just bought it this weekend from a forum member and rode it back home in the rain. Quite a scary drive since I was getting used to the bike and not having on one in quite a long time. Hopefully there will be some mild days this winter so I don't have to wait too long to ride it again.
This was a bike my friend and I brought back to life senior year in college. CM450 1984.
I am also in the process of moving, so when that is done I can catch up with maintenance and be ready to ride. The information on this forum really helped me decide on a Versys.
Old 12-10-2012, 10:01 AM
kiwi 41 kiwi 41 is offline
Welcome and good intro.
Old 12-10-2012, 10:11 AM
Welcome! Starting out in the rain kinda sucks! I think you will love the V!
Old 12-10-2012, 09:19 PM
Fastoman Fastoman is offline
Old 12-10-2012, 10:27 PM
Mark Jags's Avatar
Mark Jags Mark Jags is offline
Mark Jags
marksmotogear.com
09 Blue V
03 H-D Sportster - 50K miles and counting...
08 Bonneville - wife's bike
Old 12-11-2012, 04:57 AM
Old 12-11-2012, 12:50 PM
As I am looking for a new front tire, it seems like I will have to raise the fender. What are the options for extending the brake lines to make it fit?
Old 12-11-2012, 02:21 PM
you do not have to extend the brake lines... here is what I did...
  • go find a brake line that is longer then yours, I got mine from an old honda shadow.
  • Make sure its clean
  • take the exisiting short line connector off (save the banjo bolts) *the one that goes over to the left caliper
  • Use the extended banjo bolt from the right caliper (where the two lines used to meet) and use it up top on the master cylinder with your new brake line, along with the existing right side brake line.
  • Use the bolt that came out of the master cylinder in your right caliper, since now there is only one line going
    to it.
  • use the same bolt from the left caliper, that was in it before
  • bleed the line very well, and add more fluid
Old 12-11-2012, 05:11 PM
So basically use the double banjo bolt to have a line for each caliper going straight from the master cylinder?
Does this have any negative effects on braking performance?
    to it.
Old 12-12-2012, 10:54 AM
no, it actually improves braking performance because the fluid doesnt have to go to one caliper and then to the other... it is just a straight line
*btw do you still have that lil 450?
Old 12-12-2012, 11:23 AM
No. It originally belonged to my friends brother so he kept it. It was in really bad shape after sitting for years in a garage by the beach. Rode it a bit in college after doing just enough work to get it running on the cheap. Its a bulletproof motor. Lots of cleaning the carbs, fresh fluids, new plugs and cranking it to take all of the junk out and it started and ran fine.
He still has it, but needs so much work that it does not get out much. I showed my GF one the other day and she really liked it so I might try to find one for her. Really nice and simple bike to mess with.
Old 12-12-2012, 02:54 PM
well if, whoever owns it now, wants to get rid of it on the cheap... lemme know, I like it
Old 12-12-2012, 10:19 PM
Why do you have to raise the fender to put a new tyre on?
Old 12-13-2012, 09:11 AM
So that I can fit a tire with a higher sidewall.
Right now I just want some good weather so I can ride this Sunday. I've been away from home all week and I am itching to take it for it's second ride.
