Moisture in headlight - Kawasaki Versys Forum
Old 12-07-2012, 09:48 AM
goat12's Avatar
goat12 goat12 is online now
Default Moisture in headlight
I noticed this morning that my headlight assembly seems to have some moisture in it. Have you guys run into this at all? How bad is it/how tough a fix?
2011 Versys
Sw Motech crash bars, Loobman chain oiler
Sw Motech Pelican im2600 removable rear case/alurack
EP radiator guard, FendaExtenda, Xena XX14
Zeta Armor hand guards, XC led turn signal covers
Motowerks flatfoot, Motowerks peg lowering kit
Kryptonite NewYork Noose,Kryptonite New York Legend
Venhill SS brake lines, Backoff XP brakelight modulator
Tapp-Lite usb charging port, Osram Hyper 65w bulbs
Michelin Pilot Road 2 tires
Old 12-07-2012, 11:45 AM
Someone posted about changing his lights to projectors, and detailed how you take the housings apart, and re-attaching them.
Old 12-07-2012, 12:02 PM
Daedalus62's Avatar
Daedalus62 Daedalus62 is offline
Pardon my opinion, but honestly that seems way overkill... If it's just a little moisture, maybe you could try to stuff a rag through the lamp hole (with the help of some long soft object?) and work it around to clean the moisture?...
Most important... Try to find how/why the moisture got in there in the 1st place... A bad lamp/housing joint?... The rubber piece that goes in the back of the lamp, not properly fitted?...
My 2 cents
Cheers
Old 12-07-2012, 01:34 PM
anders55 anders55 is online now
My 2 cents
Cheers
"The rubber piece that goes in the back of the lamp, not properly fitted?..." Thatīs what it is probably all about. Washing/spraying water "from behind" could be the cause. Just drive around the block and watch the moisture evaporate... IMHO
Old 12-07-2012, 07:52 PM
stlee29 stlee29 is offline
2008 Kawasaki KLE 650 Versys Blue/Silver
The moisture normally does go off after the headlight's warmed up. Seen this for a car though.
My V Blog: http://www.kawasakiversys.com/forums...ead.php?t=4763.
Old 12-08-2012, 02:13 AM
2daMax's Avatar
2daMax 2daMax is offline
Mine has this misting occasionally but it goes away. I don't see it anymore or maybe I've not paid attention to it.
Present Ride: 2011 Versys Spark Black
Previous Ride: Kawasaki Ninja 250R 2008 Plasma Blue
My V's Farkle Log: http://www.kawasakiversys.com/forums...214#post146214
Old 12-08-2012, 04:20 PM
RickySpanish's Avatar
RickySpanish RickySpanish is offline
I always thought this was normal. The whole assembly isn't sealed/air tight. There's a vent somewhere.
If you try cleaning the moisture out, be sure not to rub the shiny reflective backing too much.
But again, not a big deal.
Versys 650
KTM 690 enduro r
KTM 450 xcw six days
Old 12-08-2012, 06:07 PM
goat12's Avatar
Thanks for the info. I was trying to figure out if there was indeed a vent somewhere. Seems to have dissipated a day later.
2011 Versys
Old 12-09-2012, 08:23 PM
Fastoman Fastoman is offline
That will be me , but for a little moisture just run the headlight a few blocks and it will disappear and you dont have to break the seal . just check the rubber housing at the back and you are good.
Old 12-14-2012, 05:16 AM
versysnewbrunswick's Avatar
versysnewbrunswick versysnewbrunswick is offline
My headlight assembly has a crack in it right behind the gray bar that goes across....trying to get Kawasaki to replace it. Had to my dealer when it was on warranty but he would not look at....so when i put the bike up this year for winter I took it apart to see what was going and found the crack.
Old 12-20-2012, 01:29 PM
zedseven50 zedseven50 is offline
Condensation happens, comes but goes. Happened on my Zed and the V. Recently replaced the original headlamp units on my BMW E39 5 Series with pukka HELLA 'angel eye' units. Occassionally happens to them to a small degree, but soon goes. Still the best mod I've done to the car so far. Apologies for posting pics of my car, I just love those lights..!
ID:	16405   Click image for larger version
ID:	16406   Click image for larger version
