Oxford Heated Grip Install - Kawasaki Versys Forum
Old 11-23-2012, 07:44 PM
revrandy revrandy is offline
Default Oxford Heated Grip Install
I am getting ready to install heated grips on my V. A couple of questions for those who have done it.
1) Where did you mount the control? The mounting bracket included in the kit doesn't fit (handlebar mount).
2) If I wire it directly to open power relay near the front of the bike, do I need to purchase a relay or can I just wire it directly? After having someone dick with my grips on a previous bike and subsequently kill the battery, I am a huge fan of wiring it into the ignition.
All help appreciated.
Thank you.
Old 11-23-2012, 08:01 PM
Ziggy's Avatar
Ziggy Ziggy is offline
I wired my heated grips directly to the battery with the wiring harness provided in the kit.
The control is mounted using 3M double face adhesive tape as shown in the picture.
AMA Life Member
Old 11-23-2012, 08:19 PM
Thanks, never thought of that location for the controller.
Old 11-24-2012, 07:46 AM
V-COASTER's Avatar
V-COASTER V-COASTER is offline
on the 2010-up there is a switched power source for accessories already there from the factory. The two leads are on the left side of the bike hanging down behind the fairing. All you need is one female and one male bullet connector. The power is already on a switched relay so you dont have to worry about killing your battery like I did one day at work.
2013 Versys1000 burnt orange
Old 11-24-2012, 11:06 AM
EricB EricB is offline
One of those "U" bolts that you can get at any hardware store will allow handlebar mounting.
Old 11-24-2012, 01:42 PM
1) Where did you mount the control? The mounting bracket included in the kit doesn't fit (handlebar mount). If it does not they may have sent you the wrong mount.
Thank you.
These have to be powered directly from the battery due to the high current draw. Attaching them to say the running lights will blow fuses. You can install an automotive relay for just a few dollars to ensure they turn off when the bike is turned off.
http://www.teamrocs.com/technical/pa...lay_basics.htm
Old 11-24-2012, 01:54 PM
I mounted mine on the dash, to the left of the buttons on the instrument panel. It covers up one of the fasteners on the dash, but that's no biggie. They're not super easy to turn on while moving, so I usually make sure they're on before I take off.
Old 11-25-2012, 04:07 PM
colodak colodak is offline
I have a fuze block installed under the seat, so the power source is switched from the key and won't kill the battery. Mine is mounted with 5lb indoor/outdoor double sided tape on the handlebar mounting cap like in Ziggy's pic.
I've left mine on accidently many times and not worried becuase the controls shut off when the key is turned off.
'09 Candy Plasma Blue Versys 650 (the fastest color)
Blk Spool/slider kit
Givi DS 450 Windshield
t-rex front sliders
SW motech engine guards
HT Teton Panniers
Acerbis handguards
Avon Distanzia tires
Garmin Zumo 665
dual power usb/12v plug
Givi trunk on custom mount
Old 11-25-2012, 09:59 PM
I attached my controller to the dash with the included double-stick tape. When that eventually failed, I used hot melt glue.
I've also had a bar-mounted Oxford controller on a previous bike. Bar mount might be easier to turn on at night. More wiring and crap to the bars though.
Old 11-25-2012, 11:26 PM
HAWKSHOT99 HAWKSHOT99 is offline
I mounted mine with the included bar mount no problem.
08' Versys
Old 11-26-2012, 05:35 AM
Did you use a U-Bolt to hold it in place? On my v-strom, the included mount worked with the mirror bolts, they don't fit on the versys.
Old 11-26-2012, 09:21 AM
I dont think so. I only used what came in the package. I am not near my bike right now, but will try and take a closer pic later today.
08' Versys
Old 11-26-2012, 11:50 AM
Here is pics of my Oxford controler mounted. I used the mirror/clutch mounting.
I may have bent the "platform" up a few degrees but dont remember exactly as it has been several years.
Sent from my SGH-S959G using Motorcycle.com Free App
ID:	16301   Click image for larger version
08' Versys
Old 11-26-2012, 11:51 AM
forgot the side view picture. Here it is.
08' Versys
Old 11-26-2012, 02:24 PM
naudan naudan is offline
Do you have a picture of what your talking about? And which lead is which?
Also -- is that strong enough for the power draw of heated grips?
Farkles:
Givi Tall Windscreen, Givi Top Rack and Case, Givi V35 Bags and Mounts, Givi QuickLock Tank Connector+Bag, Oxford Heated Grips, Nuvi 550 w/ Ram Mount, Barkbusters Full Wrap + Storm, Motowerks Flatfoot, Spools and Tank Protector, Bobbed Fender, Grip Puppies, 12v SAE Socket, Packjack, Airhawk 1 (med), Scala Rider G4, Contour Roam2
Next Stop: 44Tooth Sprocket (To be installed)
Old 11-27-2012, 07:07 PM
Its the Pleats Its the Pleats is offline
I mounted my controller the same way as above and it works great.
One quick recommendation. A few weeks after installing them, the left grip stopped working. I jiggled all the wires and it started working again. A few days later, both grips stopped working. More jiggling and the right one started working again but not the left. I had the v in for a service and they fixed the left grip for me by rewiring the connector. A week later it stopped again.
Right, f$ck this. I pulled every connector and soldered them up. The whole system is one continual unit now with no joins and it works a treat!
Maybe i got a dodgy unit but those connectors are ****e!
Sent from my iPhone using Motorcycle.com Free App
Old 12-30-2012, 06:34 AM
Well - I just installed my Oxford Heated Grips -- got them for Xmas
The install took awhile. Although easy from a technical standpoint, it was hard because of the following:
1) Getting the grips on was ridiculously hard. Talk about a snug fit? It took a ton of twisting and pushing.
2) Wiring. They give you very little extra wiring. Kind of annoying. I could have used another 4 inches to give it a little extra play. Please - no puns here
3) The controller. Should I looked here again to see what people did. Ended up just using 1 screw from the clutch side to hold it. I bent the metal a bit to get it into a position I liked.
Overall I am super excited to try it out. I directly connected to the battery because I don't have any relays to have it done via a switched power source.. Just have to be careful I guess.
Now if this snow would just melt a little I can try them out along with my new Tourmaster Transition Jacket
Farkles:
Old 12-30-2012, 10:46 AM
If you lubricate the grips with hair spray they will slide on easier. Leave them 24hrs after and the hair spray will cure with the grips to hold them in place.
Sent from my LG-P500h using Motorcycle.com App
Old 01-02-2013, 03:44 PM
So my review after using the grips: Amazing.
I went for a ride (28 degrees outside) and I had no problem riding around ~45mph average for around 1.5 hours.
The heated grips are amazing, no issue at all with keeping my hands warm (mind you I have barkbusters and thicker style gloves for winter).
I only had to go back and forth between 75% and 40%.. 75% is really really hot. I didn't even try 100% but that has to be crazy hot.
These things literally just enabled me to go from ~30 mins to -- well who knows?? So excited to extend my riding season by so many months for only $80. Well spent.
Farkles:
Old 01-02-2013, 06:38 PM
dmason's Avatar
dmason dmason is offline
Here's a tip: instead of trying to PUSH the grips on (all the while pushing the bike away from you, which is counter-productive), stand on the other side of the bike and PULL the grips on. Along with the aforementioned hairspray they will slide right on.
Also, I had WAY too much wiring in my Oxford kit (Sport version) and had no problems mounting the switch bracket to both bolts of my clutch mount.
