Head Light Assembly - Kawasaki Versys Forum
Old 11-17-2012, 09:53 AM
versysnewbrunswick's Avatar
versysnewbrunswick versysnewbrunswick is offline
Default Head Light Assembly
I love my 2011 but I have a small problem with the head light assembly - it leaks. I have put my bike up for the winter so now would be a good time to tackle this. I want to pull the assembly out and clean down inside of it. I have the fairings off but i cant seem to see where to get the assembly out. Has anyone else run into this with their head light ? After i clean it i am planning on sutting silcone around where i think it leaks.
Old 11-17-2012, 11:04 AM
chid's Avatar
chid chid is offline
I know it's not the same, but it's similar. Look at this thread how I opened the headlight assembly (and put it back )
http://www.kawasakiversys.com/forums...ad.php?t=15364
hope it helps.
Versys 2009 Green
Old 11-17-2012, 12:31 PM
Chances are if it leaks the rubber seal around the connector at the back of the light is loose and just not attached properly. If you bike is under warranty I would take it to the dealer to see what they say. Not a normal issue.
Old 11-17-2012, 01:54 PM
i got the assembly out but now i can not separate the two to clean the lens. Seems to be leaking at the top. Asked the dealer last year and his response was from Kawasaki that it is not a sealed beam so not covered under warranty. The first photo is where I think the cleaning agents are getting in and the second one you can see the streak marks inside
ID:	16217   Click image for larger version
ID:	16218   Click image for larger version
Old 11-17-2012, 02:10 PM
chid's Avatar
put it in the oven.
read my topic and you'll see. I don't remember the temperature and time.
not difficult.
Versys 2009 Green
