New kickstand - Kawasaki Versys Forum
Old 11-12-2012, 08:12 AM
oldkawboy's Avatar
oldkawboy oldkawboy is offline
Default New kickstand
After some measuring I figured the second generation ('08-'13") KLR650 would fit my Versys.
I was wanting a larger foot but wasn't crazy about the options I had seen.
Perfect fit and I'm very pleased.
Dan
Old 11-12-2012, 08:22 AM
jimS jimS is offline
Kinda like that. Were there any installation problems?
Old 11-12-2012, 10:53 AM
Just make sure you re-use versys's spring instead of the klr's.
Old 11-12-2012, 10:03 PM
Tech-Diver's Avatar
Tech-Diver Tech-Diver is offline
Stand & Bike look great not to mention the GarageMahal, nice to see you haven't forgotten the V with all your other toys!
Best,
Sam
Old 11-12-2012, 10:35 PM
oldkawboy's Avatar
Hey Sam great to hear from you.
Over the years I've had several bikes and can honestly say I've enjoyed the Versys more than any other!
Simply a great bike.
Take care & ride safe,
Dan
Old 11-15-2012, 08:04 AM
2daMax's Avatar
2daMax 2daMax is offline
It looks good.
Present Ride: 2011 Versys Spark Black
Previous Ride: Kawasaki Ninja 250R 2008 Plasma Blue
My V's Farkle Log: http://www.kawasakiversys.com/forums...214#post146214
Old 11-15-2012, 09:34 PM
Regarding sidestands:
IF you put a larger front tire on (Metzler Tourance 130/80x17 for instance as I and many others have), the stock stand will work, and be TOO short in reality - but I'm pretty sure will be the correct length IF you've lowered your bike.
That set-up has your bike leaning left quite a bit more than stock.
Old 11-16-2012, 03:08 AM
Ivan V Ivan V is offline
Here's one on Ebay:
http://www.ebay.com/itm/09-KLR650-KL...1162c3&vxp=mtr
About half the price of a new item.
I'd get it if it weren't for the pesky PayPal.
Old 11-18-2012, 05:23 PM
Default KLR side stand.
Also fitted a KLR 650 side stand. I fitted a speedies lowering block so i shortened my side stand. I simply cut the foot of at the weld, cut 1 inch of the stand and welded the plate back on. It looks original and is a far better, more stable stand than the Versys. You need to use the "KLR SPRING" not the Versys spring. The spring mount on the KLR stand is in a different spot.
