Crappy downshifting, shifter not returning - Page 2 - Kawasaki Versys Forum
Old 05-09-2012, 03:12 PM
clivecoo clivecoo is offline
I fitted a grease nipple to mine, should be a factory item.
Old 05-10-2012, 05:37 AM
toofer toofer is offline
Very interesting mod, and damn practical too.
Old 05-10-2012, 04:43 PM
Originally Posted by clivecoo View Post
I fitted a grease nipple to mine, should be a factory item....
Good idea! I've been kind of thinking along those lines for next time I go "in there".
Old 06-01-2012, 01:32 PM
Pretbek's Avatar
Pretbek Pretbek is offline
Originally Posted by Pretbek View Post
I understand grease should be used, with that center groove and all, but I used a thin layer of moly paste. We will see how that goes.
Still enjoying how light and smooth the shifting is now.
To get back to all on this item: Moly doesn't work so well.
After one month and about a dozen deep muddy puddle crossings the shifter is sticky again.
This time I will clean it and use the regular grease that I should have used in the first place, in stead of moly paste.
Old 07-17-2012, 12:14 PM
burnedstar burnedstar is offline
2009 Kawasaki versys
Glad I found this thread!
I added a grease nipple as per Clivecoo (in my hall of fame mod now )
And also followed the recommendation from Retro Rocketeer to adjust the pedal.
Wow! what an improvement!
Old 08-10-2012, 07:22 PM
Timberdog's Avatar
Timberdog Timberdog is offline
I just did this today as my V started shifting poorly awhile ago. As stated, a huge improvement. Thanks to you all for contributing these posts. Recommend doing this for anyone with shifting troubles.
Old 11-13-2012, 08:25 PM
sambamboo's Avatar
sambamboo sambamboo is offline
+ 1 on timberdogs comments, took all of half an hour and the difference now is amazing no more missed gears or false selections. 5 thumbs up.
Just curious on the 'Nipple Mod' I'm assuming you need to tap the hole and cut a thread for it.. did you need to file anything off the threaded end of the nipple to allow it to sit so neatly. (does it protrude though?)
