Not exactly...im talking about the actual angles in the bars...I like my bars straighter. the bars are bent back on the v....
Me too. The angle of the V bars is the only thing that really bothers me about this bike's ergo's. Kojack: if you find suitable replacement bars, likely paired with ROX risers, post a photo here...
Cheers, Jeff Two weeks in the western US
freddie, I may go the crusier route...there is a multitude of bars available maybe ape hangers...ha ha! I am going to get the specs from the stockers, and size up what I can put on, using or not using a riser.
Just think - you could mount your apehangers UPSIDE down for a really DIFFERENT look, altho' you might hit your chin on the tank....
This is as close as the stocker dimension i could search.
Originally Posted by Velocibiker
Those numbers on the OEM bar didn't look quite right to me so I just got back from pulling the bar off my '08 on doing my own measurements.
Now, based on ProTaper's description of Height, Width, Rise & Sweep, these are my numbers:
A = 760
B = 130
C = 75
D = 190 (center to center where the OE bars are knurled = 85)
E = 90
All measurements were made as close as possible from center to center. So, depending on how you measured, the numbers may/will be different.
Some of my pictures - it doesn't work well since pictures are not 3D and what your eyes see vs. what the camera sees is pretty different.
Width
I want to try Renthal Road High bars. Maybe with some riser.
A: 710
B: 140
C: 88
D: 228
E: 84
F: 206
Handlebars change the character of the bike dramatically and you can't tell much from these dimensions if you haven't tried anything but stock. Buy some cheep/sellable ones to give you an idea.
