hbars with more rise, less pull back.. - Kawasaki Versys Forum
Old 11-06-2012, 01:42 PM
kojack's Avatar
kojack kojack is offline
Default hbars with more rise, less pull back..
anyone replace their bars with ones with a little more rise and little less pull back?
Old 11-06-2012, 05:29 PM
oldkawboy's Avatar
oldkawboy oldkawboy is offline
I have one of these because I never could find a bar that I liked.
http://www.twistedthrottle.com/handl...er-20mm-height
The riser has really worked well for me.
Dan
Old 11-06-2012, 06:16 PM
kojack's Avatar
I will have to try those. may offset the pull back..
Old 11-06-2012, 11:17 PM
You can adjust how much pull back you like with rox risers no?
Old 11-07-2012, 12:08 AM
Absolutely, Andre... Rox adjustable pivoting riser/adapter.
http://www.advdesigns.com/roxadhabarri.html
Old 11-07-2012, 06:28 AM
Yep.. I use 2 inch Rox Risers and love them!
Old 11-07-2012, 08:49 AM
kojack's Avatar
Not exactly...im talking about the actual angles in the bars...I like my bars straighter. the bars are bent back on the v....
Old 11-08-2012, 12:50 AM
Ah, my bad, it is that kinda pull back u mean...
Old 11-08-2012, 11:12 AM
Me too. The angle of the V bars is the only thing that really bothers me about this bike's ergo's. Kojack: if you find suitable replacement bars, likely paired with ROX risers, post a photo here...
Two weeks in the western US
Old 11-08-2012, 12:43 PM
FWIW - when I had my Bandit I HATED the stock bar angles, as they put my hands to sleep. Put 'drag-bars' on with risers (1.5" or so) and LOVED it!
Old 11-10-2012, 06:19 AM
kojack's Avatar
freddie, I may go the crusier route...there is a multitude of bars available maybe ape hangers...ha ha! I am going to get the specs from the stockers, and size up what I can put on, using or not using a riser.
Old 11-10-2012, 09:59 PM
Just think - you could mount your apehangers UPSIDE down for a really DIFFERENT look, altho' you might hit your chin on the tank....
Old 11-11-2012, 02:56 AM
This is as close as the stocker dimension i could search.
Originally Posted by Velocibiker View Post
Those numbers on the OEM bar didn't look quite right to me so I just got back from pulling the bar off my '08 on doing my own measurements.
Now, based on ProTaper's description of Height, Width, Rise & Sweep, these are my numbers:
A = 760
B = 130
C = 75
D = 190 (center to center where the OE bars are knurled = 85)
E = 90
All measurements were made as close as possible from center to center. So, depending on how you measured, the numbers may/will be different.
Some of my pictures - it doesn't work well since pictures are not 3D and what your eyes see vs. what the camera sees is pretty different.
Width
Old 11-11-2012, 07:04 AM
Ivan V Ivan V is offline
As per Andrewhtf's post, stock measurements are close to this:
(I measured them off the bike and got similar numbers)
OEM:
A: 760
B: 130
C: 75
D: 190
E: 90
F: 240
I currently have these, but I prefer stock. I like more sweep and sportier bend. It may work for you Kojack. Or the 'High' version.
ProTaper SE ATV Low:
A: 813
B: 140
C: 88
D: 228
E: 84
F: 206
I want to try Renthal Road High bars. Maybe with some riser.
A: 710
B: 140
C: 88
D: 228
E: 84
F: 206
Handlebars change the character of the bike dramatically and you can't tell much from these dimensions if you haven't tried anything but stock. Buy some cheep/sellable ones to give you an idea.
