DIY - Oil Change/Oil Filter - Page 15 - Kawasaki Versys Forum
View Poll Results: What oil filter do you use?
Purolator Pureone or Purolator ML 44 17.67%
FRAM 17 6.83%
WIX 12 4.82%
Bosch 16 6.43%
Smart Tech 2 0.80%
Super Tech 35 14.06%
Mobil 1 16 6.43%
K&N 45 18.07%
OEM 53 21.29%
Something else 27 10.84%
Multiple Choice Poll. Voters: 249. You may not vote on this poll
 26Likes
post #281 of 297 (permalink) Old 08-10-2016, 01:03 AM
Originally Posted by bwwoodard View Post
Follow up, regarding my post above (#77).
So, I decided to take a look first hand. After some reading at the FJ09 forum, where this was a reported issue, I had envisioned finding a nut-type configuration at the base of the oil filter mounting bolt, where it attaches to the engine: WRONG! It's threaded into the lower engine case on my 2011 650 Versys, creating virtually no protrusion (as compared to the reports of the FJ09 issue, where the oil filter base bottomed out on mounting bolt nut before achieving adequate seal).
This being the case, there should be no issue in using the PL14612, correct? It was my understanding that the PL was a great filter for this application in all other regards, aside from potential interference as mentioned above.
Invader: your thoughts?
I'll try to attach a couple photos I took. One is from front to show there isn't a shoulder nut between the filter base and the engine case. The other is from the side, to show virtual flush mounting (no protrusions beyond engine block, except threads themselves).
Well it looks like it can be a problem after all... I guess I could've left my original posts up.
I oughta mention I've been using a Denso 150-1000 "First Time Fit" oil filter for many years now, problem-free.
(Tall version: 150-1001)
Denso oil filters employ an innovative Torque Stopper case design that prevents over-tightening and simplifies installation.
https://http2.mlstatic.com/filtro-de...1_052016-F.jpg
http://densoautoparts.com/filters/oil-filters
Ketch likes this.
post #282 of 297 (permalink) Old 08-10-2016, 07:33 PM
bwwoodard's Avatar
Yep, it seems that the concave feature may cause other bikes to have mounting problems. While the concave feature (itself) doesn't affect Versys, the further most part of the threads (interior) may be the issue; there appears to be a noticable difference. See my observations noted in the photo (submitted by kballowe) below. Whether my hunch is right or wrong, sounds like this newer filter needs to be avoided.
As usual...Invader is right
Thanks for posting kballowe.
Oil Filters | DENSO Auto Parts
bwwoodard is offline
post #283 of 297 (permalink) Old 08-11-2016, 08:45 AM
So, what exactly is the issue with this filter? What ever the issue is, is it just suspected that it might cause a problem? Or has it actually caused a problem in the Versys 650?
Mine seems to be working fine on my 2008 V, after a few thousand miles.
quexpress likes this.
trialsguy is offline
post #284 of 297 (permalink) Old 08-11-2016, 09:05 AM
quexpress's Avatar
I was going to ask the same question. I keep looking at that last pic but don't understand the problem.
I still have a full deck.
I just shuffle slower.
Note: I have no time to waste because Iím older at this moment than Iíve ever been before,
Ö and itís the youngest Iím ever going to get.
quexpress is offline
post #285 of 297 (permalink) Old 08-11-2016, 10:23 AM
bwwoodard's Avatar
RESPONSE #1: go back to the range of post #79 in this thread, for more info. This report seemed to be a nonissue until a Versys owner posted an issue this week. Based on his photo, I'm speculating that the filter on the left appeared to "possibly" have an area creating contact with the end of the male threads {and with the reddish-pink plastic/rubber material at the end of the filter internal threads}. Without having the filter to physically examine, it's just a theory as to why he can't tighten the filter adequately to seal and prevent an oil filter leak. That is the issue as I understand it-- potential leak at seal from inability to properly tighten.
RESPONSE #2: If yours isn't leaking, that's good. It's been challenging, at best, to grasp a full understanding of this report and if the Versys was affected.
post #286 of 297 (permalink) Old 08-11-2016, 11:23 AM
My newest purchase of a Bosch 3323 did indeed show the metal surface to be convex instead of concave like the last 3323 I took off. After bwwoodard did some research it appreared the V's don't have a problem because there is not a nut at the top of the male part (I know that sounds dirty) like on some other bikes. I proceeded with the newer 3323 and have had no problem. The size of that red part shown in the pics throws another question mark in to what may be causing the problem. I am going to follow Invader (always a good idea) and get some of those Denso filters.
cjcintucson is offline
post #287 of 297 (permalink) Old 08-12-2016, 03:43 PM
quexpress's Avatar
Smile
This tells us that the filter does not bottom out on the engine case and therefore allows the rubber gasket to seal correctly.
That is the anti-drainback valve.
IMHO this will not be a problem. On this page: Purolator mentions:
1. Changing the base plate from a concave to a convex design (as it shows in your photo);
2. Slightly increasing the height of the gasket.
IMHO the same was applied to the Bosch 3323. I will therefore try it on mine at the next oil change.
I agree. You can't go wrong if you do that.
post #288 of 297 (permalink) Old 08-17-2016, 08:02 PM
Changed the oil & filter on mine today (picked it up this week, used with 1500 miles on it).
I had an extra paint strainer from painting a hood for my Camaro, so I drained the oil through it.
Worked pretty well. There were a couple black flecks in the strainer, but I also dropped the drain plug bolt into it, so I don't know if it came from the inside or outside... Looked pretty clean.
If your local auto parts store sells automotive paint, they may give you a couple strainers. If not, you can buy a box of 100 @ Harbor Freight for $5.
cohocarl is offline
post #289 of 297 (permalink) Old 12-05-2016, 02:30 PM
I had just purchased three Bosch 3300 filters when I read the original reports last year about the design change causing leaks on the V. I avoided using them for the stated reasons, but today I thought that I should try fitting one as I needed to change the oil.
It fit perfectly and does not leak on my '08 Versys.
Smiley is offline
post #290 of 297 (permalink) Old 12-05-2016, 03:12 PM
quexpress's Avatar
Excellent!
Please come back with more feedback after having it on your Versys for a few hundred kilometers.
post #291 of 297 (permalink) Old 12-05-2016, 05:51 PM
I will certainly do that, but it might be a while before I can ride again. Although I do have heated Gerbing gear, I no longer have the appetite (or the body) to ride in cold weather. I ride for pleasure now, not for bragging rights.
Ten years ago I rode at least once every month of the year for 2 years in a row and that was in years with some bad weather. I remember when I was seventeen, riding my YDS-3 Yamaha home from a party in a January snowstorm. Insanity! and I made it home unscathed. Glory days indeed.
I will update on the Bosch 3300 later, but it certainly appears to seal well after an oil change and having the engine idle until hot. I do hope it works because I have two more of them. I don't surmise any problems from the reports that I have read and from my personal experience. It is a very well constructed oil filter that I have trusted for many years.
But then again, ever since the infamous bad Fram filter early internet days expose, has anybody here reported an engine failure due to a faulty oil filter? And how would you even know if it were so?
onewizard and quexpress like this.
Smiley is offline
post #292 of 297 (permalink) Old 12-05-2016, 06:23 PM
Merged with existing sticky "Oil Change"
New is DIY Oil Change/ Oil Filter
post #293 of 297 (permalink) Old 12-05-2016, 07:02 PM
Good move Glen. Thanks for organizing and grouping the various threads, it makes it far easier for researching.
Smiley is offline
post #294 of 297 (permalink) Old 12-05-2016, 08:41 PM
quexpress's Avatar
We're on the same page Smiley!
post #295 of 297 (permalink) Old 04-12-2017, 12:22 PM
chrisfla1's Avatar
I'm about to change my oil, and I bought a Kawasaki oil filter. Am I crazy? Doesn't anyone here use a Kawi filter? I plan to switch to full synthetic.
2007 H-D Electra Glide (laid it down Oct. 2nd 2016 with almost 95K miles; may she rest in pieces)
Iron Butt Association
LAMA DAMA since 2014
Injuries: 20 broken bones & 14 metal pieces
Old woman riding since 1982
The fear of death follows from the fear of life. A (wo)man who lives fully is prepared to die at any time.
Mark Twain
chrisfla1 is offline
post #296 of 297 (permalink) Old 04-12-2017, 02:02 PM
Not me. Only the one that came on the bike.....
First Oil Change 600 miles by weljo2001, on Flickr
I've used the same PCS-1 Re-Usable oil filter since 2010 on 3 different bikes now....
chrisfla1 likes this.
post #297 of 297 (permalink) Old 04-13-2017, 10:22 AM
I have seen a lot of comments about this oil and oil filter change thing. I went to my local dealership and purchased an OEM filter and gallon of Kawi 10-40 oil in the black container. Total cost $29. I also purchased the 14 flute attachment for the OEM filter. The bike is a 17 and has a 24 month warranty. I figure the OEM products are fine and they are inexpensive. They give me a 15% discount on everything in the shop sine I bought the bike there.
Smiley likes this.
Lurch71 is offline
Tags
filter, oil
Human Verification
Similar Threads
Tire change? NVcaster Technical Discussion 21 11-04-2008 05:46 PM
Oil change milage NVcaster Modifications - Performance 7 09-30-2008 05:43 PM
2 things must change dmc51 General Kawasaki Versys Discussions 5 07-12-2008 08:33 AM
First oil change lost84001 Technical Discussion 5 05-09-2008 12:03 AM
Oil and filter change dstarman Technical Discussion 1 05-08-2008 04:39 PM
