Front Sprocket Nut Trick - Page 2 - Kawasaki Versys Forum
 7Likes
post #21 of 42 (permalink) Old 11-14-2014, 08:43 AM
kohburn's Avatar
me?
no I went with a fresh 15t front and a 44t rear
kohburn is offline
post #22 of 42 (permalink) Old 12-14-2016, 11:29 PM
Thought this thread could use a revival.
All I have to say is "CENSORED"!!!!!!!!!
This is one of the many reasons I will never buy another Kawasaki. 120 ft-lbs? Really? This started to spin on my 27mm socket using a 3' 1/2" drive breaker bar. Using the method as described by others.
Had to order a new nut after the nut would not come off. Dealer wanted 2 hours to replace the nut, I did it in 45 minutes.
Stupid tight, when there is a safety built in.
Advice? Take it to the dealer and pay them for an hour.
Urbanengineer is offline
post #23 of 42 (permalink) Old 12-14-2016, 11:57 PM
It's a piece of cake when you know what you're doing with proper tools.
post #24 of 42 (permalink) Old 12-15-2016, 12:21 AM
Smile Soon to be a How to
Done
post #25 of 42 (permalink) Old 12-16-2016, 09:41 AM
As with anything, once it's done you are an expert. I feel like if I have to change another Versys' front sprocket I'm going to have to buy a replacement swingarm (wood through wheel).
post #26 of 42 (permalink) Old 12-16-2016, 09:50 AM
Impact Socket/ Deep Socket
Somewhere I have a post that makes it even easier, for now I will explain it, use the deep socket but jam a rag below and around the socket, like having someone hold it in place, have it in gear and move the rear wheel so that the tension is on the lower chain, place a piece of wood/ rubber, anything that will hold the tire in place. Do Not put a piece of wood between the swing arm and wheel, unless you want to replace the swing arm and chain at the same time .
And here is proof swingarm cracked
Urbanengineer likes this.
post #27 of 42 (permalink) Old 12-16-2016, 11:57 AM
FWIW - out of three Vs bought new, when I had to change the countershaft sprockets, the '08 was easy (Craftsman 1/2" air-impact wrench), the '09 was NOT (tried w/ an air-impact Ingersol Rand that can go to 500'/# on removal, then went to the Kawi shop who removed it for a case of beer), and a '15, which AGAIN was easy (the air-impact Ingersol Rand again).
Succeeding removals on all THREE were easy, as I torqued the nuts to the "factory recommended torque values"....
post #28 of 42 (permalink) Old 12-16-2016, 12:02 PM
Going back to the initial posting... He used his torque wrench as a breakover bar? With an extension pipe on it? Oookay...
....ride like the one-eyed Jack of Diamonds with the Devil close behind...
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility, it's right. If it disturbs you, it's wrong until either the machine or your mind is changed."
-Robert M. Pirsig
bcalan is offline
post #29 of 42 (permalink) Old 12-16-2016, 06:02 PM
You mean do not use a thin piece of steel? I use a padded length of wood that is large enough.
post #30 of 42 (permalink) Old 12-16-2016, 09:21 PM
Invader Logic
Pray tell why are you changing your sprocket so often, that you have made a special piece of padded wood specifically for this??
post #31 of 42 (permalink) Old 12-16-2016, 09:57 PM
LOL! I replaced my countershaft sprocket twice, when I simply wrapped a wood stud of the right dimensions with an old blanket.
post #32 of 42 (permalink) Old 12-23-2016, 10:03 PM
Well it cannot get worse then this I suppose - I'm glad I cut mine off before I broke the stupid swingarm.
I say it again, Kawasaki has a problem with quality control - Ninja 500 Speedo cables anyone?
So 1200 Foot-tons I suppose. I torqued to 90 and then bent the washer up.
post #33 of 42 (permalink) Old 12-23-2016, 10:35 PM
It's not overtorqued at the factory... It just tends to stick a bit from initial assembly.
post #34 of 42 (permalink) Old 03-19-2017, 02:36 PM
TEK
TEK's Avatar
Anyone have the nut details, part no#, ?
Proverbs 3:5 Trust in the Lord with all thine heart; and lean not unto thine own understanding. 6 In all thy ways acknowledge him, and he shall direct thy paths.
TEK is offline
post #35 of 42 (permalink) Old 03-19-2017, 06:45 PM
Is this nut a righty or a lefty?
Duffy is offline
post #36 of 42 (permalink) Old 03-19-2017, 07:43 PM
Normal, counter clockwise. Just changed to 16 tooth a couple of days ago on my 2016. I've had problems on other bikes changing front sprockets, so this is not unique to the Versys. No problem with 1/2 inch Air impact, zipped right off.
quexpress likes this.
Buffalo_Bob is offline
post #37 of 42 (permalink) Old 03-19-2017, 08:33 PM
quexpress's Avatar
Clockwise to tighten (righty) and counterclockwise (lefty) to loosen.
I still have a full deck.
I just shuffle slower.
Note: I have no time to waste because Iím older at this moment than Iíve ever been before,
Ö and itís the youngest Iím ever going to get.
quexpress is offline
post #38 of 42 (permalink) Old 03-20-2017, 06:12 PM
If I don't have someone to hold the rear brake, I stick a pipe through the wheel and the swingarm.
HondaGalToo is offline
post #39 of 42 (permalink) Old 03-21-2017, 10:34 AM
You can ALWAYS find someone to hold the rear brakes ON if you can wait a bit.
WAY-Y-Y better than replacing a cracked swingarm....
post #40 of 42 (permalink) Old 03-21-2017, 12:39 PM
Holy crap, just read through the rest of this thread. I've changed many a counter sprocket, but not yet on the V. Didn't realize the torque was so high, and that swingarms cracked with a method I've used in the past.
Thanks for the heads-up. Rear brake it is. Or I finally break down and get an impact wrench...
Human Verification
