clutch cable snaped - Page 2 - Kawasaki Versys Forum
post #21 of 33 (permalink) Old 12-05-2009, 06:39 PM
tomla's Avatar
Originally Posted by Shatrat View Post
PTFE is fairly inert and non-toxic.
If it overheats it forms Perfluoroisobutene, but if your clutch cable is over 500 degrees you have other problems.
http://www.fluoridealert.org/pestici...ition.prod.htm
I remember reading an interview where the guy who invented teflon said it was unstable after about 380 degrees, which is why you wont find a teflon pan in my house....
tomla is offline
post #22 of 33 (permalink) Old 12-07-2009, 05:00 PM
The clutch cable breaks at the nipple that engages the lever because without adequate lubrication, the nipple binds in the lever and doesn't swivel properly. This flexes the cable back and forth and fatigues it to the point of breakage. It needs to be lubricated with waterproof grease. I use just a dab of wheel bearing grease. Anything less just won't work well. I've done this for many years. It used to be common knowledge.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #23 of 33 (permalink) Old 12-09-2009, 01:57 AM
LAVersys's Avatar
You might be right... So far, I have used the blue teflon and WD40 and they don't seem to last long... Around 200 miles or so, the nipple binds thingy needed to be lubed again or it start making rubbing noises... Just lubed again tonight with teflon blue stuff since I only got that and WD40.
I will try on my other grease stuff soon...
Current bike
09 Kawasaki Versys
Previous bikes
07 Suzuki GSXR 1000
07 Yamaha FZ1
06 BMW K1200 GT
05 Suzuki Vstrom 650
01 Yamaha Vstar 650
90 Yamaha FZR 600
7x Yamaha Enduro 125
LAVersys is offline
post #24 of 33 (permalink) Old 03-02-2011, 12:52 PM
3rd cable
42,000 on bike and my cable broke on the way to work.Also I'll have to replace the handle as it too has given out.Had to order both as thsy don't seem to be a stock item here in Phoenix. I couldn't understand why "all of a sudden "my cable starts fraying without giving me any problems.Thanks for the thread,this cable will be greased,lubed and annointed with oil for longer life.The cables seem to last a year and this is my 3rd year.
azunion is offline
post #25 of 33 (permalink) Old 03-02-2011, 12:59 PM
LoneRanger's Avatar
Dupont's PTFE teflon lube is also a know neurotoxin, and should be used with caution.
I use it all the thyme an it neber hurnt me won liddle bit.
LoneRanger is offline
post #26 of 33 (permalink) Old 03-02-2011, 02:16 PM
You might want to see that the cable nipple rotates freely in the lever before you install it. What I do is use chain lube on that nipple, and hit it just a little when I lube the chain.
09 Versys
00 KLR
USN 1959-65
ttpete is offline
post #27 of 33 (permalink) Old 03-02-2011, 05:10 PM
kurt's Avatar
I think the idea is to use a light lubricant like WD40 or similars... some lub that repels water and dirt from inside the housing.
Lubs with wax are not good because the wax is dry inside the housing and will not let it run freely, inside... you know what I mean?
Same feeling as the throttle cables (remember to lubricate it too... both)
kurt is offline
post #28 of 33 (permalink) Old 03-02-2011, 05:38 PM
TTPETE and others Thanx. Another point that may be a no brainer to most is to not leave the cable adjuster slots(by the lever)pointing up. Rain gets in.
Slot pointing down after adjustments are made is better.
post #29 of 33 (permalink) Old 12-18-2012, 06:00 AM
qorray's Avatar
Old post new problem for me. My clutch cable just went south, thanks to you guys on this forum I have a solution.
qorray is offline
post #30 of 33 (permalink) Old 12-18-2012, 12:35 PM
Two recommendations:
Lube the cable, yes. But also apply grease to the cable end, where it goes into the lever, as ttpete says.
Buy two clutch cables: one to replace the broken cable, and another to carry with you at all times.
2009 Versys
2004 EX-500
Holden is offline
post #31 of 33 (permalink) Old 12-18-2012, 01:01 PM
Good advice! Same for the brake cable?
yychow0812 is offline
post #32 of 33 (permalink) Old 12-18-2012, 01:34 PM
genehil's Avatar
I have my spare clutch cable already routed and zip tied to the operational cable. In the event of a snap I will be back in business in no time. As for the brake cable... It's not a show stopper and gets a lot less wear and tear that the clutch cable. I don't have a ready-to-go backup for that one.
GeneHil - Mount Dora, FL
2011 Kawasaki Versys
genehil is offline
post #33 of 33 (permalink) Old 12-19-2012, 05:54 PM
WHICH brake cable...?
Human Verification
