Sluggish power output - Page 2 - Kawasaki Versys Forum
post #21 of 23 (permalink) Old 11-20-2012, 05:32 AM
Hades's Avatar
Again, Kawasaki Versys forum to the rescue...awesome place...... I too notice a slight vibration on my bike. Time to go change the sprockets as well since its already 24K km. Cheers all....
Hades is offline
post #22 of 23 (permalink) Old 01-03-2013, 07:04 AM
Andreas56's Avatar
Hi there... check your Air filter too.... if that is clogged up somewhat - that would lead to poor air flow into the Carbi and -then you get one unhappy Versys...
Andreas56 is offline
post #23 of 23 (permalink) Old 06-10-2013, 02:58 PM
I like to compare the chain coming off to the chain I am putting on. You can visualize stretching by laying them on a clean surface side by side. Also, hanging the used chain and observing lateral slack.
I recently had a 86 VFR that had the chain tensioners installed inside out. When I tried to reassemble the same way, I simply could not make it fit. When I inspected closer, the wear indicator stickers were facing the inside. I turned them around and the rear wheel slipped right into place. However the chain quickly weared after this, and is being replaced. I am betting that chain will have a considerable amount of lateral slack.
09 Green
lgajohnymac is offline
Human Verification
