Rough Idle - Kawasaki Versys Forum
 1Likes
  • 1 Post By Naitramde
post #1 of 8 (permalink) Old 04-29-2017, 05:50 PM Thread Starter
Naitramde's Avatar
Rough Idle
Wondering if anybody had an idea...
After the bike is warmed up, when sitting at a light I'm noticing a slight rough idle. It comes and goes in about 2 second intervals where the you can feel the whole bike slightly shake then smooth, then rough, smooth out, rough, smooth, rough...etc. The rough is not discernible when under power, just at no load idling.
- Makes no diff with clutch engaged or not.
- I've cleaned/re-oiled the air filter (although I'm not sure of the air cleaners integrity, its a aftermarket BMC).
- Increase idle to 1500, this just increased the frequency of the rough patch.
- I use good gas, 91+ octane.
- getting close to 13k miles.
It doesn't really bother me but I just don't want it to be a precursor to a bigger problem. Any thoughts would be appreciated.
mbclark222 likes this.
2011 Versys 650
Naitramde is offline
post #2 of 8 (permalink) Old 04-29-2017, 06:27 PM
Your idle is a little high...https://www.manualslib.com/manual/95....html?page=119
post #3 of 8 (permalink) Old 04-29-2017, 06:28 PM
penwright1166's Avatar
Try a new fuel filter, shake old one out in your hand and see if you have water coming out on your hand
Thxs Sam
Sent from my SM-N910V using Tapatalk
penwright1166 is offline
post #4 of 8 (permalink) Old 04-29-2017, 09:14 PM
Fuel Filter??
Thxs Sam
What make and model of bike do you have that has a removable fuel filter. My 2016 650ABS Versys has a fuel filter which is part of the fuel pump.
post #5 of 8 (permalink) Old 04-29-2017, 11:43 PM
Replace spark plugs and inspect coils. Inspect valve clearances and adjust if out of spec. Set idle to 1,300 rpm, then vacuum synchronize throttle bodies.
NGK CR9EIA-9 Laser iridium
http://www.rockauto.com/en/parts/ngk...park+plug,7212
Denso IU27 Iridium Power (with removable nut on threaded terminal stud)
http://www.rockauto.com/en/parts/den...park+plug,7212
invader is online now
post #6 of 8 (permalink) Old 04-30-2017, 05:39 AM
Lol sorry I made a mistake no fuel filter 2 many years as boat and none fuel injector bike teck.
post #7 of 8 (permalink) Old 05-01-2017, 09:43 AM Thread Starter
Naitramde's Avatar
I do keep the idle at 1300. I just bumped it up to see if that changed anything.
Thanks for all the wisdom. I will check those things and post back when I know something.
2011 Versys 650
post #8 of 8 (permalink) Old 05-09-2017, 11:54 AM
I had the exact same problem, bike will be idling just fine and all the suden the RPM will drop just a little and come back to normal.
I also noticed that when trying to keep a constant low speed (20-30mph) the bike jerked.
I replaced the spark plugs and cleaned and re-oiled the air filter and now she runs better than ever:
My old spark plugs didn't look bad at all but obviously they were missing feon time to time causing a missfire and RPM drop.
Murquiza is offline
Human Verification
