Some electrical problems - Page 2 - Kawasaki Versys Forum
 13Likes
post #21 of 49 (permalink) Old 12-20-2016, 08:31 AM
Small Update / ECU / Fuel Pump, ECU Fuse
Trouble shooting 101
Electrically, if the bike runs, the fuse for the ECU drives the ECU Relay, the ECU relay supplies power to the fuel pump relay and also drives the stick coils.
That is the end of the good news. The MK-1 was a hardwired display, the newer versions like the MK-3 are plug in socket.
All the information I have leads back to a bad frame ground or broken frame ground, since you say you have checked that, the next thing would be to pull the ECU and check the sockets. The ECU has 2 sections, one drives all the components needed to run the bike, stick coils, crank shaft pos. sensor etc., the lower section is the display, F1 indicator, tach,speedometer, etc. Since non of those lower section are working, it points to a bad ground, or you damaged the ECU adding the charger outlet, there is a warning about not working on the bike with the power on, how that relates to your problem is only a possibility that you had a static charge that damaged the ECU, having said that I am still leaning towards a bad ground/ bad connection.
From here on it gets difficult and expensive, it is possible the display is gone/ damaged, also possible the ECU is damaged. How any of this occurred by adding a charging outlet is beyond me, again, you are certain your wiring added is in parallel ??
craxz likes this.
post #22 of 49 (permalink) Old 12-21-2016, 02:18 AM Thread Starter
Some of the lower section IS working, like F1 light, neutral etc.
Ive seen use of this parallell connected charger in this thread, so it should work, but now Im moving towards me using an inapropriate charger, I will lift the battery and check.
kali68 is offline
post #23 of 49 (permalink) Old 12-21-2016, 04:38 AM Thread Starter
I noticed a red/black striped wire not connected to the battery, I thought that one was connected to another charger quick connector (one was left by the previous owner) but maybe this is the grounding for the instrument cluster...
Quick test to be done this evening
kali68 is offline
post #24 of 49 (permalink) Old 12-21-2016, 09:55 AM
Red Black , I doubt that is a ground, there is a wire near the frame ground and I think that is the test wire for error codes.
post #25 of 49 (permalink) Old 12-22-2016, 02:30 AM Thread Starter
Nope, this wasnt the cause. Have to dig deeper...
kali68 is offline
post #26 of 49 (permalink) Old 12-30-2016, 04:10 AM Thread Starter
Hi
Where do I find the ECU?
kali68 is offline
post #27 of 49 (permalink) Old 12-30-2016, 06:47 AM Thread Starter
Ive the cluster out and up on my workbench, nothing seems to have been smoked or short curcuit... Mystery continues.
kali68 is offline
post #28 of 49 (permalink) Old 12-30-2016, 07:31 AM Thread Starter
Did the first test in the service manual, according to that the cluster needs to be exchanged...
Or is it possible to send somewhere and get it repaired?
ID:	110738   Click image for larger version
kali68 is offline
post #29 of 49 (permalink) Old 12-30-2016, 08:28 AM Thread Starter
Anyone know if its possible to adjust mileage in case I have to buy a new cluster?
kali68 is offline
post #30 of 49 (permalink) Old 12-30-2016, 08:29 AM Thread Starter
Can this be a result of a stator problem, maybe?
kali68 is offline
post #31 of 49 (permalink) Old 12-30-2016, 08:43 AM Thread Starter
Can there be any micro fuses installed in the instrument cluster itself?
kali68 is offline
post #32 of 49 (permalink) Old 12-30-2016, 09:10 AM
Digging Deep/ Beyond Beginner
First thing today, that is one really short and indecisive test, 3 seconds on, then off, not much time. So the circuit has a set ( display segments) and a reset 3 seconds later ( clear segments), either function or not all segments show, then unit is toast. The biggest problem I am having with this, isn't what appears to be the failure of major components, but what caused it?? There are several cautionary notations in the manual about disconnecting with the power on could cause ******. Adding that charger circuit shouldn't have caused this, unless it was in series with the battery, from what you are doing, I can't see anyway you would have done this, however I have done somewhat stupid things like that, I am partially dyslectic .
post #33 of 49 (permalink) Old 12-30-2016, 09:14 AM
Ecu
Hi
Under the seat, look below the latch for the seat, massive amount of wires on the foot brake side going into it. And it is no fun getting out.
post #34 of 49 (permalink) Old 12-30-2016, 09:40 AM
Magic Smoke Escaped
As in the title, that cluster is all surface mount, as to the mileage, I think that is from the ECU.Can you post what happens when following the test in the manual, and also a close up shot of the cluster board. Generally if there was a micro fuse, downstream devices failed and caused the fuse to blow, that way protecting the wiring and upstream devices connected, such as the ECU. What does that mean?? Generally when a board failure occurs , many components are affected, surface mount was never meant to be repaired, between labour , parts adn a warranty, not cost effective. However, the cluster may have it's own voltage regulator and that may be the only thing damaged. As I said earlier , need more info of what you found etc.
post #35 of 49 (permalink) Old 12-30-2016, 09:41 AM
Stator No
As the title says.
post #36 of 49 (permalink) Old 12-30-2016, 11:42 AM
Hi
I connected a CTEK charger quick connector to my battery, so I can charge the battery without having to unplug the battery, but after first charge the instrument panel and tacho went dead.
Tacho stays at zero, there is light on the instrument panel, but no symbols what so ever. Any clues to what causes this and how to fix it?
Regards,
Kari
Double check you got the polarity right on the connection harness, sometimes the charge plug in can reverse this from what you think it is. It does this with my charger. Check with a voltmeter, not just the color code of the wire, which can sometimes be wrong. If the polarity was wrong, you may have destroyed the battery trying to charge it.
Disconnect the charger cable from the battery and connect the charger to it and turn the charger on. Measure the voltage at the wires that normally attach to the battery, with them unconnected from the battery. You will be measuring the voltage coming from the charger. The meter should read either -13.5 volts (reversed) or +13.5 volts (correct).
If your battery does not read 13v or more unloaded, at rest, it is either uncharged or toast - if it was recently charged. A good battery should be able to charge to 13v or more.
post #37 of 49 (permalink) Old 12-30-2016, 12:00 PM
If the red (actually orange) wire W/black stripe has a bullet connector on the end, It is the self diagnosis terminal. It is used to retrieve diagnostic codes.
Skypilot 69 is online now
post #38 of 49 (permalink) Old 01-02-2017, 07:17 AM Thread Starter
Continue investigation...
Ive tried to separate the curcuit board from the front panel, but I cant open it up and check the front side of the curcuit board. There are two screws and a plastic clip, but the curcuit board doesnt come apart even after unscrewing and flipping the clip.
kali68 is offline
post #39 of 49 (permalink) Old 01-02-2017, 09:14 AM Thread Starter
Does the ER6 instrument fit? Or are there aftermarket instruments to buy?
kali68 is offline
post #40 of 49 (permalink) Old 01-02-2017, 09:36 AM
Kawasaki Versys KLE650 KLE 650 Meter Instruments Gauge
There is another member on the forum parting out a 2009, not sure if it is compatible with your bike, I sent a PM to him with your user name.
Tags
charger problem, ctek, no tacho, panel dead
Human Verification
